Sebart Wind 110
#627
My Feedback: (8)
RE: Sebart Wind 110
Unfortunately my camera stinks, so only two pics worthy of posting. One that didn't make it was just of the equipment I used - a rotary tool with a side cutting bit (like a drill bit) for heavy removal, a grinding stone for lighter removal, and a sanding drum for finishing.
Right now I have the countersink screws in there, they are lighter and give more clearance for the prop adapter, I'm just not crazy about countersunk screws against the non-countersunk silicon board; not sure what will end up there.
#630
1 Post
RE: Sebart Wind 110
I just recieved my CC USB cable n CC85Hv ..... i am new to this , so can any of you tell me how to program and it works ..?? and i been told that the newer version of the software would not work ??!!
only the old 1.56version works well .... how am i going to get it to download this 1.56v ??? ....................
#632
FL
RE: Sebart Wind 110
The current version of Castle Link software is 3.241 and the current firmware for your CC85HV is 3.20.
I just downloaded it last night and updated my ICE100 firmware to 3.21 (only for ICE100 ESC) to fix the data logging download bug.
#633
1 Post
RE: Sebart Wind 110
ORIGINAL: gaRCfield
I think they are up to [link=http://www.castlecreations.com/downloads.html]version 3.24[/link]; it doesn't make sense that only 1.56 will work properly. They have instructions, downloads, and FAQ on their website. I sent a PM too.
#634
My Feedback: (36)
RE: Sebart Wind 110
Huison,
Not sure why you are wanting to use the 1.56 version on your ESC. One thing that I have read somewhere is that once you load the newer versions that you cannot go back and load the older versions like you want. Which version did yours come with? If you just recently bought it, it should have a fairly new version installed already. Also, with the newer versions you have a lot more features that you can program, including percentage braking, more options for outrunners, etc. If you have the right controller that is. Just an FYI...
Larry...
Larry...
#636
My Feedback: (8)
RE: Sebart Wind 110
The 1.55 and 1.56 firmware versions were essentially bulletproof to run large outrunners (2500 -3000+ watts) and not have any motor/controller sync (timing issues) a.k.a. screeching. The downside is that you lose some features that the later firmware version have. Not all set ups need to fall back to the 1.55 or 1.56 but some just wont work right with the later firmware. Some do, some don't. Even with the same make and model of motors.
#637
My Feedback: (8)
RE: Sebart Wind 110
For anyone interested, the Airtronics 94761 mini servos don't work so well in the tail of this plane - too small. If I didn't already clip the second set of 'ears' off one of these servos I'd probably return them. Overall length of the servo is 1 1/16", and the cutout inside the stab is over 1 3/8". There is not a lot of room to work, and there is not much material to glue a servo tray to.
I think it's safe to say I'm a little over my head with this project. Luckily I won a little fun-fly plane that I converted to electric for setup practice, as this is my first e-experience.
#638
FL
RE: Sebart Wind 110
Version 3.20 firmware released 1/05/2010 is stated to correct the timing issues with screeching shounds.
This is the exact message for Version3.20 firmware update:
Bug fix: Timing would become overly advanced at certain RPM ranges. This was often reported as a noise somewhere in the throttle range. It also resulted in excessive heat when running in those RPM ranges.
#639
My Feedback: (36)
RE: Sebart Wind 110
Joe,
You might still want to consider mounting full size servos in the rear as you could run into a CG issue since you are going for the larger motor and batteries. You might want to read my earlier post as to what I found out when building mine about this issue. Unless you are planning on removing your stabs.... Just a thought.....
Larry....
Larry....
#640
My Feedback: (8)
RE: Sebart Wind 110
ORIGINAL: hotrod34a
Joe,
Larry....
Joe,
Larry....
#641
1 Post
RE: Sebart Wind 110
gaRCfield , my WinndS with 2 xhitec 5985 metal gear(Elevator) at the back..... still i need 15g of lead at the back to balance it !!
And my heavy 10s Rhino push all the way back to get the cg right .... hemmm ,if you put 2 mini servo . . . would not achiven the right cg ..... !
#643
1 Post
RE: Sebart Wind 110
ORIGINAL: rprice19
so just give it a try , if not ... just change to the latest one will do ....
#644
My Feedback: (8)
RE: Sebart Wind 110
I had a tough time with the CA hinges apparently - I breathed on the rudder before even hooking up the servo and broke one. I wasn't really happy with the way they came out in the first place and this is a good excuse to cut them all and replace with the 1/8" Robart hinges.
Replaced the tail wheel with a Sullivan one too; the rudder leading edge was not tapered to the center of the rudder and thus caused a misalignment. The Sullivan wheels use a spring to compensate for stuff like this, however with the Robart stuff centered on the rudder and not the leading edge should fix the issue.
Got the Airtronics servos mounted in the tail with a little effort, time, and patience. Hopefully the heavier hinges and tail wheel combined with the lighter gear and Rx batteries will help with balancing.
Lipos are on their way, as is the ESC from Tower so should have it hinged and balanced within a week. I figure I have a few options:
-mounting the rudder servo in the tail if it's really far out of balance
-4000mah batteries if it's a bit out of balance
-few grams of lead if it's close
-playing with wheel pants (eliminating?) and wheel sizes
-bigger elevator servos is another idea, doesn't make much sense but it is an option
#645
RE: Sebart Wind 110
Robart hinges are offcourse fine too, but there's really nothing wrong with CA hinges. If you break them, you're probably doing something wrong mounting them.
The trick to CA hinges is that you HAVE to use THIN CA and you HAVE to glue them in at once. Don't do one side first and then the other.
Easiest way to place them correctly is to put a pin through them in the middle and then insert them into one half. After having inserted them all, put on the second half. The pins are there to keep them in the middle. Remove the pins and put a drop or 2 of thin CA on both sides, and you're done.
#646
RE: Sebart Wind 110
Regarding the CC85HV and software versions.
As has been noted in this thread, there is a software version for the Castle Link (the PC interface device) and while it can be the same as the firmware that is loaded into an ESC, this is usually not the case. The Castle Link software will have different versions of firmware for various ESCs, BECs, etc that are supported by Castle Link. The latest Castle Link firmware is 3.241, and the latest firmware for the 85HV is 3.2. As firmware is updated for a specific ESC, older versions of firmware may be dropped. If you look at the history of the Phoenix firmware (on the Castle website under downloads), you can see multiple versions have improvements for running high power outrunners (aka, stuff used in pattern).
I have tested many versions of firmware on the HV85 (outrunners and inrunners). Inrunners run well on pretty much all versions, so run the latest 3.2 firmware (my recommendation). Some combinations of firmware/outrunners really don't work that well (and this is not unique to Castle). At any reasonable power level, the 1.55 and 1.56 were absolutely bulletproof (no screech, maintaining timing at high power). The only firmware I would upgrade to (for outrunners) is the 3.2, which statically achieves the same prop RPM at fewer amps (than the 1.56). With the crappy winter weather in the northeast, I've not been able to fly the 3.2 on pattern outrunners, but it is working well on smaller motors (statically, and flying).
Regards,
Dave Lockhart
Team Castle Creations
Regards,
Dave Lockhart
#649
RE: Sebart Wind 110
I have both and the 30C perform slightly better. They keep a higher nominal voltage. Also they will last longer because they have to work less hard, relatively.
Zippies are good packs. My oldest pack is now coming up on 200 flights, and though it doesn't perform the way it did when it was new, it's still very usable. I suspect I'll get around 250 (total, so about 50 cycles more) cycles out it before I decide to retire it.
#650
My Feedback: (8)
RE: Sebart Wind 110
Well I just ordered one set to start. I want to fly a few flights and see what I think. If I need to shave some weight I'll go with lighter batteries, but I was thinking I would get a little more longevity and power out of the 30C - at least this is what was suggested by the local guys here.
I just put the plane up for a preliminary balance. It still needs the ESC and the Robart Hinges on the tail, and a little more hardware on the stab, but balance was right near the 185mm point!
