Who is converting Toro trimmers?
Old 06-18-2006 | 08:58 PM
  #276
Scott Ellingson's Avatar
My Feedback: (146)
Default RE: Who is converting Toro trimmers?
Dave,
Thank You !!!! I just bought a Prather V stack from tower to try. It is the EXACT intake Horizon sells, except on Tower it is $11.99. What a rip off. I think the bell shaped v stacks will be better than the directional ones like the Great Planes ones. Now I know a cheeper place to get them
Scott
Old 06-18-2006 | 09:04 PM
  #277
My Feedback: (29)
Scott,
Your welcome.
Dave
Old 06-19-2006 | 08:34 AM
  #278
Tom in Cincy's Avatar
My Feedback: (16)
Nice find Dave... I second what Scott says. Prather really did a number on us else Horizon has them way under priced.
I was reading in another thread about this Pop Off Pressure adjustment that is made with the needle valve spring. It involves making a pump with a pressure gauge to set the spring tension to 15psi. I think I have most of the stuff to complete the test set but was wondering if anyone here has ever played with setting one. http://www.aerocorsair.com/id28.htm
Tp
Old 06-19-2006 | 08:17 PM
  #279
My Feedback: (29)
Hi Tom,
I haven't done that yet,but I would like too someday, just to see what the values are.
Dave
Old 06-24-2006 | 09:20 AM
  #280
My Feedback: (29)
Hi scott,
I got the v-stacks from Horzion and the are great for the price. The are chaffer at the exit, so you can use them with a standard choke. Very little tapper through.
Dave
Old 06-24-2006 | 01:33 PM
  #281
I odered about 6 items from Horrizon. Got the fuel line...nothing else....not even a word when the rest is coming. When I ordered they said all the items was in stock???????? Capt,n[]
Old 06-24-2006 | 02:18 PM
  #282
My Feedback: (29)
Captain,
I order three v-stacks over the net. They came in about USPS. I wished that I had ordered more. At least you have the low price locked in.
Regards, Dave
Old 06-24-2006 | 02:40 PM
  #283
My Feedback: (16)
I ordered 4 yesterday. They are being shipped from Ca. So I would suspect another box is on its way from the west coast.
Tp
UPDATE: They arrived 6/29/06 and they are the exact same stack as the Prather. Nice find Dave..
Old 07-13-2006 | 10:21 AM
  #284
My Feedback: (29)
Captain,
Did you get your V-stacks from Horzion? They are out of stock again.
Dave
Old 07-13-2006 | 10:34 AM
  #285
My Feedback: (146)
I ordered 50 of them 3 weeks ago. I recieved one. They said it would be 4-6 weeks for thm to get them in. SO 1-3 weeks to go yet
Old 07-13-2006 | 11:02 AM
  #286
My Feedback: (29)
Scott,
Its worth the wait. At 11.99 that would $600. Do you rework your Toro 25 pistons? I'm doing an older 2bbl and it has a hollow wrist pin. The cylinder and block are a little different. Has no squish band and the normal domed piston. It must be generation one.
Dave
Old 07-13-2006 | 11:36 AM
  #287
My Feedback: (146)
Dave,
I never messed with the pistons. Just did some port work. I know there needs to be a little squish band clearence or overheating and detonation can happen. I think .010 is about the minimum clearence.
Old 07-13-2006 | 04:52 PM
  #288
I did get my 2 stacks from Horizon....but it took several days. Capt,n
Old 07-13-2006 | 10:29 PM
  #289
foodstick's Avatar
I know tons of experimenting has been done on this motor.. I have been following the thread and know that I am looking for 11mm walbro carbs.. So far I have located a few used carbs and carb blocks, or (intake manifolds)
Does anyone know of a particular carb mounting manifold that works best with the various walbro carbs? I thought I had read somewhere in this thread or on rc universe that there was a manifold that could be ordered for only a few dollars new at small engine shops. Anyone have a brand an part number to suggest?
I have been having some luck mounting some scavenged manifolds at an altered angle, and modifying them as needed.
thought it never hurts to ask, thanks for any help.
Old 07-13-2006 | 11:08 PM
  #290
My Feedback: (146)
I do not know of any manifold that will fit the Toro. I always made my own out of Delrin or Phenolic. As for carb, I used more 13.5mm carbs than 11.11. I had better luck and more power with a 13.5mm Zama carb. Or a 12.7mm Zama. A G26 uses a 12.7 so it is no way too large.
Old 07-14-2006 | 12:47 PM
  #291
My Feedback: (19)
I have the WT 644 and thr # in the ventury is 32 that would make it 12.71 mm
Old 07-14-2006 | 12:58 PM
  #292
Oldtimer: Do you have a GT 25 with that WT644 carb on it? Thanks Capt,n
Old 07-14-2006 | 01:49 PM
  #293
My Feedback: (19)
No, it is unused, I bought it for a Mac 28 but have not converted it yet.
Old 07-14-2006 | 02:40 PM
  #294
The carb block from the Zenoah G23 fits, although you have to elongate the pulse "channel".
I used the one that Horizon sells that rotates the carb for a straight shot pushrod.
Joe Petro
Old 07-14-2006 | 03:16 PM
  #295
My Feedback: (29)
Hi Joe,
Can I assume that you mounted the G23 manifold on a one barrel Toro? Here is a picture of both types. The 1bbl is on the right.
Dave
Old 07-14-2006 | 06:36 PM
  #296
My Feedback: (19)
Do you have the part# for the twister insulator?
Old 07-14-2006 | 11:18 PM
  #297
My Feedback: (29)
Oldtimer,
Here is the link for the G23 twister manifold.
Dave
http://www.horizonhobby.com/Products...rodID=ZEN12310
Old 07-15-2006 | 05:33 PM
  #298
My Feedback: (19)
Thanks for the link. I got one on order this evening.
George
Old 07-22-2006 | 11:00 PM
  #299
Yep, it was the single barrel.
I really like how this engine runs... Only now I have to add nose weight to my old bipe, as it had a Ryobi 31 on it! I need a 24 ounce heavy hub...
Joe Petro
Old 07-22-2006 | 11:33 PM
  #300
My Feedback: (29)
Joe,
Who would have thought that a 25cc would work better then a 31cc. I guess a thousand RPM is worth something.
Dave
