Another Conversion
Old 02-03-2007 | 03:10 PM
Default Another Conversion
Check out this 1.20 conversion http://tech.flygsw.org/ttpro120conversion.htm Capt,n Also a up-date http://tech.flygsw.org/ttpro120conversion_b.htm
Old 02-03-2007 | 05:40 PM
Antique's Avatar
Default RE: Another Conversion
A few obvious errors, the thrust numbers are not right, he uses the ThrustHp chart..NO WAY...
The ignition is not the same as Dessert ? Aircraft uses, it's a Chinese look alike...Nothing wrong with it, just not accurate...Almost everyone is now using that Chinese ignition, rebranded ...
Old 02-03-2007 | 05:53 PM
RCIGN1: I agree with you on the data. I noticed the mix was 16-1... that would put a lot of oil in there for the rod bearing...ect. But more oil more power. I have a Thunder Tiger pro .46 and it is one powerfull engine. Gave it to my Grandson and he loves it. I never ran the bigger 1.20 Thunder Tiger, but I suppose it may be about the same quality as the China made Super Tiger. Best Regards Capt,n
Old 02-04-2007 | 01:49 AM
andrew66's Avatar
now, if only they would make a head for the super tigre .90 they would have my money in a pinch!
Old 02-04-2007 | 03:20 AM
av8tor1977's Avatar
Talk to Keith at BME engines. They sell a gas/igniton conversion for Super Tiger engines, including the .90....
AV8TOR
Old 02-04-2007 | 10:04 AM
HUummm. I had a like new Supertiger .90 gave to me. It has a broken off exhaust bolt. It seems like making a new gas head for it may be fun!! Capt,n
Old 02-04-2007 | 10:44 AM
My Feedback: (40)
Has anyone considered a gas / glow version, further reducing the weight of the ignition system?
Old 02-04-2007 | 11:47 AM
Do you have a rotary table?
Old 02-04-2007 | 11:54 AM
My Feedback: (40)
flipflop,
Yes I have a rotary table.
Old 02-04-2007 | 11:56 AM
av8tor1977's Avatar
I'm working on a Gas/Glow Super Tiger .90. Should be ready soon.
AV8TOR
Old 02-04-2007 | 12:05 PM
My Feedback: (40)
There are typically several big glow engines (Super Tiger or other) in the classified ads at any given time. A lot of people shy away from these due to the glow fuel consumption rate (real or imagined) and carb / pump problems (real or imagined). Either way this creates an opportunity for the conversion crowd to pursue another line of conversion (from glow to gas / glow) relatively cheaply. Just one opinion...
Old 02-04-2007 | 12:14 PM
My Feedback: (40)
Av8tor,
How are you going to determine which is the right carb for the conversion?
Old 02-04-2007 | 12:40 PM
I believe the stock glow carb on a Supertiger .90 should be ok for at least a good test. You can aways make an adapter for a small pump carb. Capt,n
Old 02-04-2007 | 01:36 PM
w8ye's Avatar
My Feedback: (16)
A carb from a Weed Eater 21 should be about right?
Old 02-04-2007 | 01:37 PM
I found this Webra ....sounds like it has a needle brg rod! Capt,n http://www.webra-austria.at/neu2007/...07.php?lang=EN ADDED Also like in post #11 foamcut has a very good idea....there is going to be a lot of conversion options for gas/glow or just gas. Everyhing for just about anybody!!!
Old 02-04-2007 | 06:26 PM
KenLambert's Avatar
My Feedback: (107)
I am working on a ST 2300 to gas
Foamcut I am going home and will have your mufflers ready to ship Tuesday and will thow in a couple trottle arms for you to try out
Old 02-04-2007 | 08:25 PM
My Feedback: (40)
Ken,
I'm looking at a ST2300 in the classified as well. That modified head on the Thundertiger 1.20 really grabbed my interest.
I've got a ST3000, an ST2500, and an ST3250 laying around that I've avoided using on my projects until now. The Walbro carb on gas / glow ignition solves the fuel problem without adding an EI.
I'm looking forward to trying the throttle arms.
Sent you a PM as well.
Old 02-04-2007 | 08:36 PM
The gas/glow may not run so good with the high oil content needed for plain bearings. not sure on that????? Capt,n
Old 02-04-2007 | 09:40 PM
KenLambert's Avatar
My Feedback: (107)
I am puting needle bearings in mine I have a new one ordered 149. versus 100 for used so I went new . I had been bidding on soom on ebay but they always went for near new price.
Old 02-04-2007 | 09:44 PM
KenLambert's Avatar
My Feedback: (107)
I am also going to cut some aluminum degree wheels on this trip home they are 4" and has a long mark for the 28` line I have them drawn but not cut yet so it will be an experiment I may also anodize the before cutting that might look good, we wil see
Old 02-04-2007 | 09:54 PM
Ken: I am real interested in your projects. The needle bearings will be great....I hope. That is something I wanted to try for a long time. Best wishes for a great turnout. Capt,n
Old 02-04-2007 | 11:23 PM
My Feedback: (40)
Ken,
Keep us informed on the needle bearing swap.
Old 02-05-2007 | 12:46 AM
av8tor1977's Avatar
Check this website for Super Tiger gas conversions:
http://www.aero-sports.com/airhobbies/services.html
However, a good while back I e-mailed them twice about the conversions, with questions about how they were handling the fact that the crank pin wasn't hard enough to work with roller bearings. They never e-mailed me back.
Keith at BME engines is selling a converted Super Tiger .90, (That's where I got mine.) He doesn't convert customer engines however, and I'm not sure if he is going to offer more than just the .90....
Keith?
AV8TOR
Old 02-05-2007 | 01:01 AM
I think that gas/gow fuel with 6-8% oil content should work great with these big bore engines, also maybe the stock carb will be easyer to fine tune because of the methanol content, this is just a guess.
Maybe is time to experiment again I have a Magnum 1.8 that is begging to be converted to gas/glow
Old 02-05-2007 | 11:01 PM
tim220225's Avatar
Ken are you still making mufflers for conversions? Last I heard you were selling your stuff.
