Foamies! - RC Electric Foam Aircraft Discuss rc foamie electrics here (i.e. Zagi, Tazz, ProJeti, wingo)
CHRISTEN EAGLE RTF
Old 06-20-2006, 07:06 PM
ea01bg
Default CHRISTEN EAGLE RTF
I just saw this Christen Eagle on e-bay and am considering buying it. Has anyone herre flown this bird?
I think its from art-tech, I have there cessna and have logged tons of hrs on it!
[img][/img]
Completely Pre-decaled Christen Eagle Biplane
6CH Receiver
Electronic Speed Controller
35mhz or 72mhz FM Transmitter
Powerful 1000kv Outrunner Brushless Motor
3 Servos (Elevator, Rudder, and Aileron)
11.1 Volts 1800mAh Li-Poly Battery
100~240v Wall Charger
ID:	480415   Click image for larger version
Old 06-20-2006, 09:26 PM
coolbean
coolbean's Avatar
Default RE: CHRISTEN EAGLE RTF
Does it tell you the weight and what prop it's using?
Old 06-21-2006, 07:00 AM
ea01bg
I dont remeber seeing the prop size on the ad. The weight may have been posted I'll have to check later.
If anyone has flown an Art Tech eagle please post comments. I dont have the time or money right now to get stuck with a dog :-).
Old 06-21-2006, 10:34 AM
coolbean
coolbean's Avatar
I checked it out, it's running a 10X6 prop.. The only thing I see that looks funny is the 10A speed controller. A 1000kv brushless outrunner spinning a 10X6 prop "should" be pulling more than 10A.
Old 06-21-2006, 11:25 AM
ea01bg
I wish I could find someone thats flown one of these!
I just don't have the time or money right now (just crashed my art tech cessna) to mess with something that may be a dog.
Old 06-21-2006, 06:25 PM
ea01bg
I have not found anything on it and no posts rom people that own / fly one. But after reviewing the specs for the 10,000 time I broke out the 150.00 and shipping and its on its way. I'll post something when it arrives / w pics. I bought art techs cessna and was pleased with it. For 109 bucks it was the best plane to cash deal I've ever had. I've seen some negitive press on it ( mostly take off problems ) but I hand launch at my field anyway. I hope that this plane has the same bang for the buck.
Anyone that is thinking of getting this plane and would like to hear my thoughts on it stay tuned ( shipping time 9 days)
Old 06-21-2006, 06:44 PM
coolbean
coolbean's Avatar
It looks pretty good actually.. I found a spec sheet on that motor. It is here.
[link=http://www.rcgroups.com/forums/attachment.php?attachmentid=689687]http://www.rcgroups.com/forums/attachment.php?attachmentid=689687[/link]
It shows that a 10x6 at 11.1v puts it RIGHT AT 10 amps. and plus you've got 4 servos to power... so just be careful to limit full throttle time. The power to weight looks pretty good too. Should be a good flyer.
Old 06-22-2006, 07:27 PM
jmir
Have you seen the E-flite Ultimate FX? It's a similar plane.
I've been flying one for about a month and it flies great. Very easy to hover.
http://www.horizonhobby.com/Products...ProdId=EFL2175
Old 06-30-2006, 09:33 AM
ea01bg
I got the Plane. There was a problem with the Art-Tech Radio gear (Junk) . I replaced it with n old futaba reciver I have. The plane flies great!
Outstand low speed performance, Snap turns and loops. I even got bold and did a littel inverted flying! Plenty of power and 13 - 15 min flight times. The only thing I dont like about it is at 2/3 and over power it tends to drift up and wont trim out. Its nothing a little down elevatior doent cure but I thing I'm going to have to recheck the center of balance.
ID:	485008   Click image for larger version
Old 07-05-2006, 06:25 AM
masoodbm
Hi ea01bg
How r u
I just bought this plane yesterday
I think it is a good plane
the foam is strong enough
battery life is about 15 min which is very good
slow flying is lovely with this plane
it has a fantastic glide
when I bought this plane I thought it was a 3D plane , but I think u can do 3d moves with it
have u tried it
i can t go inverted with it , it always goes up
I think i need to increase the weight of the nose
bye
Old 07-06-2006, 07:22 AM
ea01bg
Mine thends to raise up also. A little more wieght in the nose wont be a bad idea. I think I'm going to do the same with mine at some point until til then I'll just keep working the elevator. I have done some inverted flight with it and it handled fine. The only real problem I had with it was wind. This plane does not handle well in the wind.
Old 08-14-2006, 04:57 PM
Bob Putnam
I got one of these about 3 weeks ago, and -- though there are several problems with the plane the way it arrives -- I have enjoyed it.
They don't tell you a CG, but I figured one out -- and found the plane is extremely tail heavy with the battery in the stock location. Since this is a nice little plastic battery bay, you can't move it forward -- without pretty major surgery. I ended up doing this surgery, and -- though it doesn't look very good -- it flies pretty well.
The stock brushless motor puts out only 105 watts on my Whatt meter -- enough to ROG and fly OK, but it seems to need about 2/3 throttle to stay airborne.
Anyone who gets one should also compare the incidence between the two wings, and also the horizontal stab. These were pretty out of whack one mine, but it's not too hard to even them up. If you have modeling experience, or can get some help from someone who does, and you're able to make some adjustments -- this is a nice little plane, and a fantastic deal.
Old 10-07-2006, 12:00 PM
linkadrip
linkadrip's Avatar
I need parts for a Art-tech Pitts biplane. I was told that the palne is identical to th Christien eagle. Were can a I get these parts.? Any suggestions would be great. i tried to get parts for it from Hobby-Lobby but they just seem to ignore the request for some reason, So i'm looking for a dependable place to get them.[&o]
thanks
ID:	536541   Click image for larger version
Old 10-08-2006, 10:38 AM
Planebeach
Planebeach's Avatar
ORIGINAL: ea01bg
I had the same problem, I replaced it with my Jr reciver. Nice plane, only I cant get it to do knife edge.
Old 10-09-2006, 01:57 AM
linkadrip
linkadrip's Avatar
So were Do you get parts for these Planes anyone?
Old 07-01-2007, 12:36 AM
crazy7
I just bought my Christen Eagle.
For spare Christen Eagle part you could try this link:
[link=http://www.rchobbysyd.nu/catalog/advanced_search_result.php?keywords=christen]Webshop in Sweden[/link]
