Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
Data warning after selecting model
Old 04-10-2016 | 06:49 AM
Si_B's Avatar
Default Data warning after selecting model
My 18mz has been faultless for the past 4 years but it did something today which I need to find out if it was a random glitch o r something more serious.
Just had 3 great flights with my jet, decided as conditions weren't the best to blow some dust off my heli. Switched radio on, went into my model list to select the model I wanted, but when I hit select I got a data warning (can't remember exact wording, could have initialisation fail or something), the alarm was beeping and the screen was flashing a warning to power the tx off. Once I switched it back on, even though the name for the heli is still in the list, the complete models settings have been deleted and reset back to new default aircraft.
I tried selecting another model, no problems, but I need to know if anyone has had this happen before and whether I've got a problem or just had one of those random software bugs.
I'm going to back up the rest of my models as a precaution as I've completely lost all setting for my heli.
Thanks for your help.
Simon
Old 04-11-2016 | 03:42 AM
Si_B's Avatar
Just a quick update. Spoke to a very helpful chap at Futaba support in the Uk. I think I've just been unlucky and had a random glitch and the transmitter has obviously warned me that something had not loaded correctly. The downside is the wiped model memory, but I should have really backed them up (lesson learned there).
If anything else arises I will post back, but I'm pretty confident that I don't have anything to worry about.
Regards,
Simon
Old 04-11-2016 | 06:28 AM
Bax
Yes, sometimes something causes a "glitch" in the software and you lose something. If it happens more than once in a short period of time, the transmitter needs to be looked at by the service center. If it happens only once in a great while, it's not likely something to be worried about.
Old 04-11-2016 | 06:43 AM
Si_B's Avatar
Bill,
Thanks for confirming that. The chap said pretty much the same thing but due to the 18mz being pretty bullet proof he didn't think I had anything to worry about. He also said that this failure could not happen I flight.
Like you say, if it does it again in a short time frame I will send it in to be safe.
Regards,
Simon
