Saito FG-60R3
Old 01-11-2016, 10:51 AM
  #351
ALFIEV
So, I thought I'd try a couple of different props on my R60. I have been trying to compare my engine tuning/performance with others but it is hard to do when you run different props. Here's what I've got:
1. XOAR wooden 22 x 10 6000 rpm
2. XOAR carbon fibre 22 x 10 6200 rpm
3. APC 22 X 10 6500 RPM
This all on the same day, same fuel, same tuning. I think I am done running this on the bench. Will wait for the airframe, mount the engine and fly it on the carbon fibre prop. Still think I should be getting a little more out of this engine, 6500 rpm on the APC still seems a little low compared to others, but time to move on.
Old 01-11-2016, 11:29 AM
  #352
hpergm
hpergm's Avatar
6500 on the APC 22x10 is A-OK! Go fly it.
Old 01-11-2016, 11:30 AM
  #353
chorner
The other thing that would be interesting to find out, is actual thrust numbers etc. RPM is one thing, but you would need thrust numbers and even a step higher would be maximum airspeed numbers to check how each prop actually behaves and translates to flight. I wonder if the Xoar props are just wider, and provide more thrust & pitch than say a Mejzlik or APC, or if they are less efficient designs and translate to lower RPM and performance numbers etc. Or vice versa...
I think APC props probably deform a bit towards the tip and flatten out the pitch, and hence provide higher RPM? But that's just speculation on my part. I prefer the Mejzlik props over Xoar myself - much better made props.
I really want to find someone who has the Ray English plenum mod on this engine, and see if the ~500+ rpm performance improvement is infact true.
Old 01-11-2016, 11:34 AM
  #354
hpergm
hpergm's Avatar
You are actually right chorner, the APC obtains higher rpm because of its slender profile near the tips. When I tried to fly the engine at a 35C day, the plane could barely make the first turn at full throttle, despite the fact that the peak rpm on the ground was good and the motor did not overheat (temp sensors). Means that the thinner profile does not pull well in thinner air. Since this is a 4-st with lots of torque, probably a wider chord blade at the tips would fix this kind of thrust deficit...
Old 01-11-2016, 12:23 PM
  #355
SrTelemaster150
SrTelemaster150's Avatar
To really get a true comparison to different engines one needs to make the tests on the same day, preferably a cool day that has consistent temperatures & barometric pressure throughout the tests.
I've seen 300 RPM or more difference from day to day with the same engine/prop/fuel. I usually have an engine of known performance to run as a benchmark.
You seem to be making the same power as my FA-300TTDP running methanol/15% nitro with CDI which is quite good I would say.
Old 01-13-2016, 02:58 AM
  #356
cathurga
Hey guys,
I have been through the run in procedure (details in the Gas Radial thread), but I have been advised to run a break in additive with the Redline oil I used. Unfortunately, here in Dubai, that sort of thing is as rare as rocking horse p00. So I am going to run it as is. My break in procedure also included mounting the engine upside down for the last tank of fuel in rich state. That gave cyls 2 & 3 the opportunity to run hotter as in normal orientation only the 1 cyl was firing as accurately as it should have.
So, now I am going to mount it into a plane and go through the leaning up process, and then she will fly. For the break in, I used a 20x10 prop and since it was never going to over rev in fully rich mode, I assume that the light load would help minimize load. Now that I am putting it in a plane, I cannot find any 22x10 props locally. Would you recommend a 23x8 as a suitable replacement for now? It is going in a very light Yak-55M el cheapo, so it is not going to need a lot of top speed. It is going to be puttering around with some inverted flight, figure 8's etc. I want it running smoothly and reliably before it goes into a warbird.
Old 01-13-2016, 03:53 AM
  #357
hpergm
hpergm's Avatar
No worries, a 23x8 will be OK. Don't forget, this is a 4stroke with plenty of torque to turn longer props. Also, the absence of load during break in is not always beneficial, in that the increased cylinder pressure (load) helps bed-in the rings much better..
Happy flying,
Hector.
Old 01-13-2016, 04:00 AM
  #358
cathurga
Yeah I suppose so, my thinking was that in the richened condition, it wouldn't develop a lot of power to bed in. My thinking was more along the lines of making sure that there was lube sloshing around in there before I put it under significant load....you make a good point, but once it is leaned off for rich(ish) flying, there will be some load on it with the 23" prop. Appreciate your feedback, have followed your run in experiences a lot in the other thread.
Regards
Old 01-14-2016, 07:19 AM
  #359
deadstick79
deadstick79's Avatar
Originally Posted by marksp
Plenty of room in my 30 year old Byron Originals Beech Staggerwing!
Hey Mark,
It might be me but in the pic it looks as if the saito is off-set to the left and a little up! Just thought I'd mention it
Dan
Old 01-14-2016, 08:30 AM
  #360
Timbers
My dream of monitoring cylinder temps has come true, I hope! I bought an Eagletree eLogger V4 from Tower Hobbies, along with the on-board LCD panel, and three remote temperature sensors.
I'm going to either JB Weld or use some sort of thermal adhesive to glue the sensors to the area behind the glow plug. Then I'll hook it all up. I should be able to output to the LCD panel in real-time all three cylinder temps.
Plus it logs the temps for 45 minutes I believe so I'll be able to see what went on in the air.
If I want to get crazy then I can buy the transmitter device and receiver and watch the temps from the ground!
Probably a little overkill but it will be a fun device to have. I'll report on how it runs once I hook it up to my test bench and break the FG-60R3 in. I'm just waiting for a day that it is near 40 degrees, because its currently in the single digits here in Wisconsin. I think that breaking in the engine at this temp would cause the engine to never heat up to proper break-in temperature.
Thanks to all of you who replied with the details on break-in. Can't wait to get started!
Old 01-14-2016, 09:03 AM
  #361
deadstick79
You da Man Timbers I've been building my test stand the last couple days and I'm ready to start the break-in! I really wanted to be able to monitor the temps of each cylinder like Hector does but the sensor he has costs almost $400 so I was a little bummed! Your post couldn't have come at a better time
Is the RC Hobby shop still on the main drag in Waukesha? Used to shop there quite a bit back in the 80s'.
My other favorite shop was Cudahy News and Hobby!
Sure miss flying out at Lakeland and off the ice on Pewaukee
Eh?
Dan
Old 01-14-2016, 09:13 AM
  #362
deadstick79
Forgot!
Which eagle tree unit should I get?
Got their Guardian also and will be setting that up in my 100" Ryan STA
Dan
Old 01-14-2016, 10:36 AM
  #363
Timbers
Yah ABC RC I used to buy stuff there too back in the late 80s and early 90s. They are close down now. Cudahy News and Hobby moved over to Greenfield News and Hobby and that just closed last year. So I buy everything from Tower Hobbies or Horizon now. Yah I was ice fishing on Pewaukee last Winter and I noticed there were guys flying off the ice behind me!
You are right, that fancy meter that the other guy on here has is too expensive and I can't keep it on the plane. So I bought this stuff. I don't know how well its going to work yet, so I'll let everyone know once I have it all setup. Here are the parts I bought:
[TABLE="width: 95%, align: center"]
[TR="bgcolor: #F0F0F0"]
[/TR]
[TD]ETRP8032[/TD]
[TD] Eagle Tree Systems eLogger V4 w/Integrated Connectors[/TD]
[TD="align: center"]1[/TD]
[TD="align: right"]59.49 [/TD]
[TD="align: center"][/TD]
[TD="align: right"][/TD]
[/TR]
[TD]ETRP9010[/TD]
[TD] Eagle Tree Systems Power Panel LCD Display[/TD]
[TD="align: right"]25.49 [/TD]
[/TR]
[TD]ETRP8002[/TD]
[TD] Eagle Tree Systems Micro Temperature Sensor[/TD]
[TD="align: center"]3[/TD]
[TD="align: right"]25.47 [/TD]
[/TR]
[/TABLE]
Don't know if I will JB Weld the temperature sensors onto the big fin behind the glow plug, or if I will use something like "Arctic Silver Arctic Alumina 5g Thermal Adhesive "
Eh?
Dan
Old 01-15-2016, 09:03 AM
  #364
deadstick79
[/TR]
[TD]ETRP8032
[/TD]
[/TD]
[/TD]
[/TD]
[/TR]
[TD]ETRP9010
[/TD]
[/TD]
[/TD]
[/TD]
[/TR]
[TD]ETRP8002
[/TD]
[/TD]
[/TD]
[/TD]
[/TR]
[/TABLE]
Put in the order to Tower! Getting the eLogger and two sensors now with the LCD display and the third sensor supposedly coming at the end of January (backorder).
I'm chompin at the bit so will probably run at least one tank thru her while I'm waitin
Dan
Old 01-15-2016, 10:44 AM
  #365
deadstick79
Before I start this engine for the first time, I want to pull the spark plugs and put some Amsoil in the cylinders, oil the valve assms' and shoot some into the breather!
I know 20mls should go in the breather but how much should I put in the cylinders via spark plug hole?
Old 01-15-2016, 10:55 AM
  #366
Timbers
Sorry to buy up all of the temp sensors, hopefully they come in soon for ya. If you don't want to wait you can always buy one off of Eagletree's website it looks like.
Cool I hope this works out for us! I'm thinking that I will need to secure the temp sensor somehow so it doesn't vibrate too much when the engine is running. I don't want the wires to vibrate out of the sensor part. So I'll have to rig something up when I get my order in.
Ya I'm excited to fire the engine up too. Waiting for some warmer temps here though so the engine can get to proper break-in temp. I'm going to do the same thing, oil the crap out of everything before turning it over.
Dan
Old 01-15-2016, 11:28 AM
  #367
radfordc
My Feedback: (14)
radfordc's Avatar
I ran another tank of gas through my engine yesterday. I kept the engine at full power for most of the run with some periods idling as well. I think I have the needles just about right...it idles at 1400 and then picks up to full power without hesitation. I'm keeping the top end pretty rich for now. With a Top Flite 22x10 the engine peaked at a little over 6000 and I backed it off to 5800 and it seems to still have plenty of pull for my TF P-47. I'm working on getting the engine installed in the cowl today. There is just barely enough room for the engine to fit and it has to be located in exactly the right spot. If I used a 1/4" prop spacer I could move the engine back and get a bit more clearance in the cowl.
Old 01-15-2016, 11:33 AM
  #368
Timbers
Do you have the TF P-47 Tarheel Hal version? I think they are the same anyway. Have you figured out how to make the spinner work on the FG-60R3? I looked at mine the other day and it looks like I may have to drill out the center of the spinner to make it deep enough. Maybe it won't work at all.
Did you find that having the prop hub out 172mm from the firewall like the instructions say will not work for you?
Old 01-15-2016, 01:57 PM
  #369
radfordc
My Feedback: (14)
radfordc's Avatar
Mine is a kit, not the ARF. The back of my prop needs to be 7 3/8" from the front of the kit motor mount.
I was able to make the scale spinner work. I had to bore it out about 3/4" deep on a lathe to get it to clear the Saito prop nut. You can drill it out if you have a 5/8" drill bit. A 1/2" isn't large enough to clear the nut.
Old 01-15-2016, 02:02 PM
  #370
radfordc
My Feedback: (14)
radfordc's Avatar
Here is my spinner.
Old 01-15-2016, 04:03 PM
  #371
deadstick79
Originally Posted by helinut1
Hi all
Got a lot of info from your thread so I thought I would add some back. A couple of months ago I got a Saito FG-60R3 with a specific project in mind. I am building a T-28 80 inch and wanted a radial to go inside the cowel run great sound great and have scale exhaust and prop. My project led me to a Saito FG60 engine . I then read your thread and decided to get the engine and see if I could solve some of the problems tunning . I have talked with Morris from Morris Mini Mototrs and he agreed to making me a Walbro carb set up and adaptor for this motor. i have now got the motor running with this carb and it is fantastic. tunning is easy with a high and low speed needle ,an idle stop screw and Adaptor that they made me. Pulse is from intake pulse that the adapter provides and works great . After breaking in the motor I am getting very even temps on all cylinders and runs fantastic . with a 22-10 APC prop I get 7000 RPM ,i tried to richen as this is at the high end of the range but all it did was start to run bad . I thought it was going to lift the table I had it tied down to. Hope to post some pictures soon and get this plane in the air it should screem in a 23 LB plane. I am also running a Kelio exhaust ring that we customized with 3 outlets on both sides at the scale outlets for the plane . the sound is perfect for a radial scale plane.
I have just ordered this walbro conversion from Morris! Looking forward to it's simplicity
Dan
Old 01-16-2016, 07:21 AM
  #372
deadstick79
worth a look-see!
https://www.youtube.com/user/173shat...view_as=public
https://www.facebook.com/pages/Morri...29927123734795
And here's a pic for the conversion I ordered:
Name:	walbro conversion.jpg
Old 01-16-2016, 09:06 AM
  #373
radfordc
My Feedback: (14)
radfordc's Avatar
Since the engine doesn't come with a choke I made a simple servo operated flapper valve.
ID:	2141822   Click image for larger version
Old 01-16-2016, 07:10 PM
  #374
radfordc
My Feedback: (14)
radfordc's Avatar
Installed the engine and everything fits.
ID:	2141937   Click image for larger version
Old 01-17-2016, 02:37 AM
  #375
scubaozy
I had the same problem with the spinner on corsair ended up buying a cheap and cheerful china made one. Worked out really well.
