Evolution 58
Old 12-21-2005 | 11:58 AM
Default RE: Evolution 58
Hi,
58 is not in magnesium crankcase, only 45.
Old 12-21-2005 | 06:28 PM
Same weight as the 58 IRS 1820 grams + 165 grams for ignition.
No info on Mag case.
Old 12-26-2005 | 12:50 PM
greyhound man's Avatar
Do you guys recommend using the supplied break in oil or using lawnboy ashless, mobil xtr2 ?, or amsoil dominator, pennsoil air cooled......the list continues. What about preferences after break in?
Old 12-26-2005 | 01:12 PM
DarZeelon's Avatar
Greyhound,
MVVS included the oil with the engine, to facilitate your break-in.
By all means, do use that oil and after your are done with the break-in, use high quality, racing two-cycle oil.
ben beyer's Avatar
My Feedback: (23)
The engine comes with the Mobil 1 MX2T. I'm using it from the beginning, but others are using the pennzoil.
Old 12-26-2005 | 01:53 PM
  #31
rmh's Avatar
rmh
Peensoil is fine --except it does gradually carbon things and does not prevent piston scratches as well as the Mobil .
Old 12-27-2005 | 12:24 PM
  #32
DiscoWings's Avatar
My Feedback: (76)
Wait...
TOm from wildhare rc told me NOT to run the stock oil that came with the engine! Intead he said I should use Penzoil Air Cool 2-stroke oil for break-in and flying?[&:]
Old 12-27-2005 | 07:38 PM
  #33
Panzlflyer's Avatar
My Feedback: (15)
Hey Mvvs says use 2cycle racing synthetic ( even gives you some) and theres plenty to choose from at 32-40:1 so ignore the manufacturer and use a semi synthetic. I take it Tom will warranty it when it has a problem?
Old 12-28-2005 | 09:45 PM
  #34
I'm getting ready to start breaking it in any last great words of advice?...OH and this is the first new gasser for me and first time breaking one in, all my others were already used.
Old 01-01-2006 | 10:40 AM
  #35
a friend of mine just got one of these engines.
but we have a question, there are 3 fuel lines on the carb and one in the crankcase.
i figured one was the carb pressure line and one is the feed line, but whats the third one for?? and how do we make sure which one is which??
also, is the crankcase line a pressure line or a crankcase vent line??
thanks
tony
Old 01-02-2006 | 06:01 PM
  #36
no one has one of these??
tony
Old 01-03-2006 | 01:44 AM
  #37
the inlet closest to the sparkplug is the ambient air press line. it is open to atmosphere. i use a piece of tubing back to the fuselage and seems to work well.
aerowiz
Old 01-03-2006 | 09:09 AM
  #38
Panzlflyer's Avatar
My Feedback: (15)
the crankcase line is the pulse out to the carb to make it pump connect it to the carb.
As said above for the 90o fitting which is on the plate with 4 screws.
3rd is for fuel which on mine is the only one on the side of the carb.
Old 01-03-2006 | 09:30 AM
  #39
DarZeelon's Avatar
Tony, Andy,
The third nipple is placed on the 'float chamber' diaphragm cover and should supply atmospheric pressure.
Nothing needs to be connected to it.
The black nipple is the fuel inlet and is to be connected to the fuel tank line.
The pump diaphragm nipple is closest to the crankcase pulse nipple and should be connected to it, for the carburettor's pump to operate.
Old 01-03-2006 | 09:31 PM
  #40
thanks for the answers guys!!
tony
Old 01-04-2006 | 01:22 PM
  #41
Panzlflyer's Avatar
My Feedback: (15)
The 3rd nipple is best connected to something and led into the Fuselage so it sees constant pressure its easy enough to attach fuel tubing to it and them maybe you wont have changing pressure on the carb. Nice that they fitted it instead of having to solder it on yourself.
Old 01-05-2006 | 08:23 AM
  #42
Angus Balfour's Avatar
Just ordered a MVVS 58 PROsport with a BCM wrap-around muffler. Anyone tried this set-up? What props/rpms did you get?
regards,
Angus
Old 01-05-2006 | 10:40 AM
  #43
Guys, does anyone know if this engine has the same muffler bolt pattern of the ZDZ50NG? so I can use the same supersonic muffler on it.
Like you greyhound, I´m looking for a little more power, my YAK came out too heavy!!! this engine looks like a good option.
Old 01-05-2006 | 11:14 AM
  #44
DarZeelon's Avatar
Juanes,
The most effective silencer from a power output standpoint, is the MVVS #3204, with the #3202/B or P header.
There is, I believe a similar one from EVO.
Old 01-05-2006 | 06:25 PM
  #45
Juanes,
the bolts are about 1 3/8 apart on the zdz and about 1 5/8 on the EVO so unless you are a good machinest you'll need a new muffler.
with the EVO the yak came out 18 lb 11 oz RTF I have only had the chance to fly it once with this setup but I can already tell a night and day difference between the two...tons more power with the evo
Old 01-05-2006 | 07:39 PM
  #46
Panzlflyer's Avatar
My Feedback: (15)
I think it was 6400 with a BME 24/10 on mine but I will re check this weekend. BCM muffler. Moving the prop CCW more resolved the running backwards.
Old 01-05-2006 | 11:50 PM
  #47
DarZeelon's Avatar
Juanes,
The bolt spacing for the MVVS exhaust port is 46 mm, center-to-center.
Old 01-06-2006 | 05:14 AM
  #48
marzo91's Avatar
My Feedback: (57)
Where did you order the Pro sport version of this engine. I thought all the new MVVS 58's were updated to the better bearings. I also thought the hp was the same. Can you tell me more about this? Thanks
Old 01-06-2006 | 05:50 AM
  #49
I quote the featured from my web page:
Additional features:
-heavy duty bearings throughout,
-a titanium central prop drive bolt.
-redesigned crankshaft
-heavy duty connecting rod
-redesigned cylinder porting
-piston adapted to porting changes
-Added intake horn on carburettor
Old 01-06-2006 | 09:40 AM
  #50
marzo91's Avatar
My Feedback: (57)
Pe, I also e-mailed you about price, shipping, taxes, and duties. Is there a noticable power increase with the Prosport over the standard 58? Thanks
