BME G.90 gas
#276
That's a commendable piece of work there and it's all in the name of progress and enjoyment to experiment and find a working alternative, but at that given price for the fuel required I should think that going gas/ignition would be a more attractive and cost effective way in the long term.
Karol
Karol
#277
My Feedback: (12)
MT
Ed, does this work mainly with 2-strokes? I have mostly 4 strokes in my fleet and would love to convert them to gas but without having to add the weight of ignition. I do have a ST S75 that I think I will try your mixture with. Here's a question, seeing how the ethanol in gas is bad for our little motors. What about using Coleman white fuel? It seems to be a growing trend as it is 100% unleaded fuel. It is a little more expensive than pump gas, yet less than half the price of nitro. [link]http://www.idealtruevalue.com/servlet/the-45832/Detail[/link]
Shane
Shane
#278
My Feedback: (14)
ORIGINAL: karolh
Ed is that for real, a gallon of E85 for $179.9. Must be an error there somewhere.
Karol
Karol
E85 was $1.67 a few weeks ago in a small town named Dalton here in GA a few weeks ago.
I haven't priced the Klotz oil that Greg recommends for use with E85 as yet, but how expensive can it be?
Addressing another poster's comments about ignition system weight, as far as the weight of the ignition system goes, it will be negligible in my Great Planes Ultimate Biplane 1.60. The OS 1.60FX should really turn into a fuel miser with that setup, since it is already really good on fuel consumption as a glow engine. That and being able to use the stock OS carb with the ethanol/gasoline mix makes it sound like a real winner.
Ed Cregger
#279
OH
ORIGINAL: Pit-Viper 1
Shane
Shane
I am working on a video, but don't want to publish it until the spreadsheets of data are all done to show the supporting info to the actual video. The oil mixtures, etc. are based on temperature of 15% nitro Cool Power fuel and used the right amount of oil to match those temperatures and protection. When I'm satified with the numbers being accurate and the video is finished as well I will publish it here in this thread.
Motors I will be using in the test range from: S2000 Super Tigre, 1.8 Moki, 1.00 NX Evolution, S-90K Super Tigre, FP40 O.S. Max, FP25 O.S. MAX, Saito 150 to name a few. I will run them on 18-20% oil mixture depending on the motor. O.S. F glow plug. Will take head and exhaust temperatures with the Cool Power and the E85 and use tach readings with various props. If anyone can think of something else they want to see in this testing by all means ask and if it is worth doing I will include them.
Eric
#280
My Feedback: (14)
It should work equally well with four-strokes in addition to two-strokes. The octane rating of the ethanol/gasoline combo should be high enough not to cause preignition problems.
I favor the spark ignition system because it permits one to tune the mixture much leaner, without worrying about advancing the timing too much, as with a glow plug. The leaner mixture also reduces the amount of oil expelled by the engine.
Power output will be down slightly from methanol and oil only, but you recover a tad bit of that by running a leaner mixture with the ethanol/gasoline combo, minus the boost of nitromethane you might have used in conventional fuel. Those desiring top performance will not be interested in this approach. Those happy with a little less power at a big savings in fuel cost will be shickled titless.
Ed Cregger
Ed Cregger
#281
OH
ORIGINAL: Ed Cregger N2ECW
Ed Cregger
Ed Cregger
#283
My Feedback: (14)
Me too!
Now to get busy again selling off a ton of ARFs I have collected while my legs were healing (took several years). Once I get my shop back, in a few months hopefully, I can get back to modeling real time again. Still have a new mill/lathe combo to unpack and set up. Nothing expensive, but good enough to make the crankcase collar I will need to position the ignition system's Hall Effect transducer. After that it should be a piece of cake.
If this works out in the fashion I think it will, I may begin looking around for a Super Tigre 4500 or the huge OS 35cc glow engine for conversion to E85. I'll try it with the ethanol glow plug as the other poster suggested, just for hoots. I want to be able to document the difference between both glow and ignition system operation. I'll bet that Greg beats all of us to it. If not, Hobbsy probably will.
Ed Cregger
Ed Cregger
#284
My Feedback: (14)
A gallon of super technoplate is $63.60 shipped. That's $12.60 per gallon of fuel mixed at 20%. Add in the cost for E85 and it's over $14.00 a gallon. Will need to use a gas stopper and can't use sullivan flex tanks or silicone fuel tubing.
When I purchase my fuel, I order 8 cases at a time from my LHS and get 5% nitro 20% oil Byron fuel for less, shipped! Good fuel and performance.
#285
My Feedback: (14)
I haven't priced the Klotz oil that Greg recommends for use with E85 as yet, but how expensive can it be? ($63.60 shipped)
(Only 15% of the fuel is gas and that still needs to burn. You will get about 7%less fuel consumption compared glow.)
Ed Cregger
Ed Cregger
#286
OH
ORIGINAL: PlaneKrazee
#288
My Feedback: (14)
ORIGINAL: the mother of invention
I don't know where you are getting your oil, but you got screwed.
That's the price direct from Klotz. I paid $34.00 plus shipping for my gallon five years ago. Use it to increase the oil content for mehanite engines.
Where do you get yours, oh great one?
To me,
The advantage of gas is using less oil. The best synthetic oils compatible with gas are $12.00 a quart but you only need 1/2 pint per gallon for most engines. Pennzoil pricing is less than half that. This way gas is still cheaper than glow even if gas goes up to $6.00 a gallon.
#289
My Feedback: (14)
Ed Cregger
Ed Cregger
When using a spark ignition system, you can lean out the mixture without advancing the timing, unlike when using a glow plug. The result is better fuel consumption if the engine is tuned properly lean.
Unfortunately, we are still going to have to use 15% lube (or more) by volume when burning alcohol/gas mixture in our plain bearing connecting rod and ball bearing equipped engines (OS 1.60FX). That will drive the price of the fuel up quite a bit, but might still be worth it in the long run.
Of course, we're back to making a mess on the model again with the high oil content, as with glow fuel, but what the hey...
Ed Cregger
