What battery for an Evolution 45GX
Old 03-23-2006 | 08:38 PM
Default What battery for an Evolution 45GX
I''m getting ready to put this engine on a GP Yak 54. The manual calls for a 4.8 - 6V battery for the ignition system. Current draw is 500 mAh @ max RPM. My question is, what does a higher (or lower) voltage do for the engine performance, if any?
I am just getting into gassers so take it easy on me.
Old 03-24-2006 | 08:19 AM
Default RE: What battery for an Evolution 45GX
It does nothing for performance. The spark generator will charge up just the same, and timing curves also remain unchanged.
Over-voltage will kill the ignition
under-voltage will operate the low voltage cirquit, and limit rpm to about 3000 by retarding the ignition timing.
That is, if the evolution ignition resembles MVVS ignitions.
Old 03-24-2006 | 09:29 AM
ORIGINAL: preivers
Thanks. The 45 GX does exactly that. I'll probably go with the 4.8V for now just to be on the safe side.
