DA50 is Here!
MO
Update
DA sent the prop and their muffler overnight express. Was certainly no need for that but I do appreciate it. Ran about 1/2 gallon through it swapping mufflers and props, see results below.
I am pleased at how this engine has turned into a one flip starter. It runs very well everywhere. The BCM is a bit quieter but the DA sounds more "manly".
Todays results.
Pro-Zinger 22X10
BCM 5900 rpm
DA 6700 rpm
NX 21X10
BCM 6100 rpm
DA 6900 rpm
Mejzlik 22X10
BCM 6300 rpm
DA 7100 rpm
Time to quit playing around with this and mount the engine to the plane. Quite a difference huh? Choose your muffler/prop wisely. This engine will be mounted in a H9 80" cap that should weigh around 15 1/2 lbs.
Dave
Todays results.
Pro-Zinger 22X10
BCM 5900 rpm
DA 6700 rpm
NX 21X10
BCM 6100 rpm
DA 6900 rpm
Mejzlik 22X10
BCM 6300 rpm
DA 7100 rpm
Dave
IN
Thanks Dave for the data. It appears that your engine picked up some rpm from the break-in. It also shows that the DA is equal to a healthy Brison 3.2 when it is not held back by the Bisson muffler.
daveham,
Thanks, it seems they have delivered . . .as advertised!
NOT A PAID ADVERTISMENT! and he's not my brother-in-law!
Thanks again for being our "Test bed" can't wait until you get that "One Flip-Fifty" in the air.
We are all living out our DA 50-R Dream through you . . .
BigRagu
BigRagu
hey guys
what about the zdz 50rv? its 5.7hp 7000 rpm rotary valve and 5 ounces more in weight than the da 50. which engine is better? the zdz is also $75 cheaper.
#31
My Feedback: (20)
NC
Engine stand offs
Here you go>http://www.aerografixs.com/
Guys name is Roger.Good luck with that DA 50, looks good!
Doug
Doug
#33
My Feedback: (132)
DAVHAM,
Thank you for sharing your test data with us. It is quite interesting to see the major differance in RPM just switching from one can exhaust to another. Looks like Bison really missed the boat. Since the Bison pitts style mufflers are on back order I called and talked to DA about possibly switching to their exhaust so as not to loose all the RPM. They said they were switching to Slimline pitts exhausts and those on back order will be filled with a Slimline. Although they haven't tried one yet Slimline is saying the RPM numbers will be equivelent to DA's. I'm keeping my fingers crossed for a pitts that will let this engine turn 7000 + with a 22 X 10 after break in.
#35
IN
Say Windbuster:
Doing the math on the manufacturer's websites shows that the ZDZ-50 and DA-50 should weigh within an ounce of each other. It would be interesting to see some open exhaust numbers using the same prop on both engines, and also using mufflers of comparable design and outlet diameter. RCS quotes 7,000 rpm with a 22x10 Menz-S for the ZDZ, but they don't list the muffler used. They only list the Bisson Pitts and Side Mount mufflers for sale, so it's probably (?) one of those.
#37
IN
Windbuster:
The first DA-50 was shipped last week, ZDZ-50 maybe 2 months ago. These things are too new to have any long term data on reliability or problems. You'll be lucky to get bench performance test results. Maybe the guys in Canada can install these engines in their snowblower and report back?
#38
davham or anybody:
Have you considered the fact that the ends of the exhaust pipes on the Bisson mufflers have rolled ends causing a restriction of sorts. One of our club members is an engineer, and calculated the amount of restriction before and after cutting off the rolled ends. In terms of square inches of area, cutting off the ends almost doubled the area. I couldn't believe the difference he calculated. The Pitts type muffler was for a 3W-35 engine. He had a substantial increase in rpms. Did davham cut off the ends of the exhaust pipes on his Bisson muffler?
#39
The Slimline Pitts muffler on my G26 cuts 500 rpm from the same engine with no muffler at all...A standard Abell muffler loses only 200 rpm, but is louder..There's a fine line between size and power..Maybe Slimline will design a new muffler that would be tuned, making the engine even better..Still waiting for my very own DA50..Maybe next week....
#41
My Feedback: (18)
MO
When I ordered my DA50 (and yes I have had it for about 2 weeks), Dave @ DA said that with the BCM, you would loose a few hundred rpm. But he said if you cut about 1/4 of an inch off the exhaust stacks you would gain that rpm back, and as davham put it, makes it sound more "manley". I still have yet to receive my muffler. I guess BCM was/is having a problem supplying the demand....
#43
Where did you get your DA from without an ignition? I just bought my World Model Extra today and will be ordering a DA 50 this week. Does anybody know how long the wait is to get one..
#44
IN
Where'd he buy it???
Two hints.. it wasn't Aircraft International or Cactus Aviation.
If you call up DA, I'm sure they'll sell you as much of or as little of a DA-50 as you like. Ya just has to pay yer money.
#47
MO
After reading a few of the above post I went out and looked at the Bisson, and sure enough it's rolled in. I will cut 1/4" off each end and test it again with the Mejzlik prop.
I would rather use the Bisson for cosmetic reasons only. The DA will require a large portion of the cowl side to be removed.
Dave
Dave
#48
To davham:
If you have a micrometer, measure the outlet hole on the muffler pipes before and after the cutting. We calculate the area before and after produces an increase of almost 50%. Although it doesn't look like it at first glance, the rolled ends really restrict.
Cajuncharley
Cajuncharley
#49
Any input from Desert Aircraft regarding this issue?
I have one DA-50, not boken in yet and would like to know the end of this history.
I had talk several times by phone with Dave Johnson at Desert Aircraft, and it seems to me he is not the kidn of person that sales pineapples as apples.
So is recomended to get this to an end instead of live it floating...
Miguel
Miguel
Couldn't make anything lighter anyway...
