Problem with evolution 26 gt2 !!!
Old 12-19-2007 | 11:11 AM
Default RE: Problem with evolution 26 gt2 !!!
I did that in 1985. Thanks for being concerned. I went on to be a warranty director for a large Motorsport manufacturer in the US for the last 10 years of my career. I always love it when people react the way you have when they have no idea of someone’s background. I have sat through product liability cases. I have sat through class action suits, I am not a lawyer but I have been through the procedure a few times. Since this has no productive end I will let you believe what you want to believe. Have a nice day.....
Respectfully
103/17
Old 12-19-2007 | 12:34 PM
ORIGINAL: 103/17
Well Sir, I guess we all have opinions. You have just stated yours. Nothing that I posted is bad information. Everything that I posted is factual. Everything that I posted is common knowledge for any 1st year engineering student. Its not very complex............ I am sorry that you dont agree.
103/17
Seems a rather classic case of "A little knowledge is a dangerous thing."
Old 12-19-2007 | 12:43 PM
The other reason for problem free running is that you rev your engines well in their design range, know how to adjust them and how to cool them.
Old 12-19-2007 | 09:28 PM
blw's Avatar
blw
Let's keep it friendly.
Old 12-20-2007 | 10:45 AM
Jezmo's Avatar
ORIGINAL: dick Hanson
I love "qualified" answers--which exclude actual use of the product. They miss the key point -
Experience with the product.
As for lawyers -
That should help----
if the lawyer has a background (actual experience) in applications of oils -with THIS particular engine .
FWIW I have had a few of the MVVS/ Evolutions -which came with the recommended oils and that is what I used -and even with the thrashing I gave em - they continue to run well - no additional bearing clearnce (how do I know?) -easy you record and compare prop movement at TDC hot n cold and th pistons are smoothly polished in viewing occasionally when changing to another model.
The factory advice has proven to me , to be spot on.
I wasn't refering to the lawyers knowledge in oils or anything related to engines or airplanes etc. I was refering to warranty issues and whether or not they had to be honored if requirements from the manufacturer were not adhered to and how that applies to US law. I am not real fond of them folks but they DO know more about it than my feeble little mind. If I misunderstood your reply please forgive me Dick. Also, I agree with everything you said after - "FWIW I have....."
Old 12-20-2007 | 12:54 PM
  #31
rmh's Avatar
rmh
Lawyers -like Doctors or Ditchdiggers - will take the job and charge you--IF they can actually do the job- is another matter .
Some can- some can't.
Also , some know more about the issue than you do - some don't.
Spend yer money and take yer chance---
I am not a cynic-just have had a lot of experience with good ones and --not so good ones .
Old 12-20-2007 | 01:32 PM
  #32
I found out the problem It was I had a two line system . one going to the carb and one plugged with a plug. What was happening was the engine would build pressure in the tank and quit and run rich !! When I would take the plug out or the fule line off the carb fuel would spit all over . So I un plugged the line and have run 3 tanks fully out with no problems and the plug was perfect!!
Thanks for your help !! I guess I was just thinking nitro being this was my first gas and didn't think about the pressure !! This engine runs great would recommend to any one !!I thought I was kinda werd it had pressure in the tank !!
Thanks,Josh
Old 12-20-2007 | 01:34 PM
  #33
Jezmo's Avatar
Yeh, me too. I'd just as soon not have to deal with them. Have a good one Dick.
Old 12-20-2007 | 02:12 PM
  #34
RTK's Avatar
RTK
ORIGINAL: josh*********
I'm confused, you always have to have the tank vented to the atmosphere. With a two line system one is vented the other to the carb. If you plug the vent you will create a vacuum and stop fuel flow.
Old 12-20-2007 | 03:35 PM
  #35
Banned
Okay, Let's all settle down with the legal matters and take note of what is important here. If you are running a two-line fuel system on a gas engine you want the vent line to make 1-2 loops on top of the fuel tank and then exit out the bottom of the fuse. The line with the clunk on it goes to the carb. It has a tee in it and a line running off of the 90 degree tube that is used to fill the tank. It goes to the fuel button. See below.
ID:	830087   Click image for larger version
ID:	830088   Click image for larger version
Old 12-20-2007 | 03:51 PM
  #36
RTK's Avatar
RTK
Oops, I should have read the whole post. I didn't realize he had set it up as a glow system.
Al--I set up all my planes just as you have. It is very simple and works.
Old 12-20-2007 | 04:07 PM
  #37
Banned
Works for me!! Got all of mine this way.
Old 12-21-2007 | 12:47 PM
  #38
Ya This is my first gas and I rely didn't do no research on how to set up the tank!!
Thanks for the post on how to set the tank up!!
Josh
