RCGF Engines
#3476
RE: RCGF Engines
2 of my 3 3000MAh NiMH battery packs from hangtimes.com charged above capacity when formation slow charged.
one shows 6.8 volts and the other 2 show 6.7volts.
i was surprised that they charged above capacity. never had a NiMH charge above capacity before.
i would recommend hangtimes.com to anyone.
#3477
RE: RCGF Engines
3 NoBS NiMH 5 cell 6.0v packs
3000ma Type Sanyo HR-SCU
cell impedence 6 mOhms
first pack
charged 5-16-2009
slow charged 300ma
cutoff V 7.23 Volts
capacity 2784
second pack
charged 5-17-2009
slow charged 300ma
cutoff V 7.22 Volts
capacity 3877
third pack
charged 5-18-2009
slow charged 300ma
cutoff V 7.28 Volts
capacity 3736
first pack
charged 5-16-2009
slow charged 300ma
cutoff V 7.23 Volts
capacity 2784
second pack
charged 5-17-2009
slow charged 300ma
cutoff V 7.22 Volts
capacity 3877
third pack
charged 5-18-2009
slow charged 300ma
cutoff V 7.28 Volts
capacity 3736
#3480
RE: RCGF Engines
Problem solved. My engine has been cutting out during inverted flight..Since I have some down time with my plane,decided to pull the fuel tank out for inspection...My hobby shop supplied me with glow fuel line,instead of gasoline fuel line as I requested...Fuel line had swollen,and my clunk had come off... This time I will zip tie all my fuel line connection...
#3483
My Feedback: (15)
AL
RE: RCGF Engines
I should have paid more attention to the posts on page 135 about the Sullivan gas stopper having degradation problems. Mine also came apart today. Fortunately I found the problem on the ground before engine start.
Here’s part of my post that I sent out to our club members:
If you are using the Sullivan S478 product on your fuel tanks for gas operation I would suggest that you replace the fuel stopper ASAP! My fuel stopper disintegrated after less than 8 tanks of fuel and lead to a fuel soaked fuselage bottom in my Christen Eagle. This seems to be a common problem; and I base that on my personal experience and from the RCU posts that I have seem in the last two weeks. I suspect that the Ethanol additive in the gas is the culprit. The Dubro #400 brown gas stopper appears to not be degraded by Ethanol.
I ordered aluminum stopper caps from PSP. They look similar to the Sullivan but are 1/3 the price, mainly because Sullivan’s conversion comes with extra items that you generally don’t need. I can reuse the Sullivan aluminum cap with a Dubro brown gas stopper, but after that I’ll be using the PSP/Dubro units.
http://www.pspmfg.com/FuelTankCap.html - The neon purple is the only one currently in stock for 5/32” tubing. That is the one I ordered.
Mike
#3484
RE: RCGF Engines
With some history in using aluminum caps, excersise a little vigilance and periodically check the clamping pressure of the center screw. They loosen up from time to time and generate an air and/or fuel leak. I have several that I will no longer use for that reason.
#3485
My Feedback: (15)
AL
RE: RCGF Engines
I agree with your comments T.O.M.
This fuel tank was my first use of an aluminum cap. I was concerned about the stopper screw coming loose since it was going into a threaded retainer. In these type of blind applications I have used one small drop of red Loctite under the head of the screw with 100% success to date. If the screweverneeded to be removedat a later time it has popped looseafter a small applicationof heat from a soldering iron. I admit that I would only do this with a socket head screw, not a phillips head screw which is easily stripped.
I'm really disappointed that this Sullivangas stopperdisintegrated so quickly. If this is going to be the norm then I hope Sullivan pulls this product from the market. I will sendSullivan a polite letter explaining the problem and hope they will accept some constructive criticism about this product and its potential negative consequences.
Mike
Mike
#3487
RE: RCGF Engines
I just ran across this thread and started reading it from the beginning, but just don't have the time to go through the whole thing. I had never hear of this manufacturer before, but from the little I've read, I'm really interested in their products. I don't have any gas engines yet, and this would be my first. Ihave a Seagull Ultimate 90-120 size and I was planning on putting an Evolution 1.20 glow engine on it. Then I remembered about the SPE 26cc gas engines and started thinking about getting into gas. However, now that I have found RCGF engines, I think I'll try them instead.
Will the RCGF 26cc be a good choice for the Seagull Ultimate? What props would you recommend in 2 and 3 blades?
#3488
My Feedback: (12)
MT
RE: RCGF Engines
The 26cc should a great choice for that bird. I think most guys are using 16-17" props for theirs. I'm sure someone will chime in shortly. These are great little motors and run terrific.
Shane
Shane
#3489
RE: RCGF Engines
I'd take a 16x8 and 16x10 to the field, see which one you like. A lot of it will depend on flying style - are you looking for 3D or Sport performance? I have my RCGF 26 in a 1/7 scale P-47D, the 16x10 is by far the better prop for me.
#3491
RE: RCGF Engines
Went to maiden the Sea Gull Yak today. The 20 fired right up but had to shut it off cause the ruder servo was twitching around center.[&o]
Got it home, changed the servo, problem solved.
Maybe Friday. That is when the weather forecast is going to cooperate.[sm=shades_smile.gif]
#3492
My Feedback: (9)
WA
RE: RCGF Engines
More flights with the 25% Aeroworks Edge and the RCGF 26cc engine. Ran great, good power, big loops, 12 minute flight and I had about 3/4 of a 12 oz tank left over! I could probably go down to an 8 oz tank!
Sam
Sam
#3493
MO
RE: RCGF Engines
Looking for a plane for my 20cc had it in my P-47 and it seemed to want to tip stall if it got too slow?
Plus I miss the 4 stroke sound in that plane was thinking about a 140 cessna 182 any suggestions for a scale or sport plane?
Thanks, Larry
#3496
My Feedback: (12)
MT
RE: RCGF Engines
ORIGINAL: r/cfun
Thanks, Larry
Thanks, Larry
Shane
#3497
My Feedback: (8)
RE: RCGF Engines
Hi everyone, I am the Sales Technician from KMP. The Aerovate line has taken us by surprise and the demand is higher than the supply. I wanted to address the bolt for a spinner. The answer is yes the end of the prop main bolt is drilled and tapped for a 4mm bolt. If for some reason you don't have this on your engine, contact BJ's engine service. They are the factory authorized service center for both the Aerovate and the RCGF engines. Another accessory website you may find some good accessories for this engine is www.magnumrc.com. There is inverted Pitts mufflers and standoffs for this engine. Another jewel to be found is a scale prop hub designed for the 26cc that fits right over the drive plate for this engine. FYI
#3498
AZ
RE: RCGF Engines
To all,
I know that the ignition has a futaba connector on it but, I only have JR/Hitec stuff. I was wondering if my superswitch I plan on using has to be a Futaba or are the charge jacks that different. I thought the positive is always the middle lead. thanks in advance.
#3499
My Feedback: (12)
MT
RE: RCGF Engines
JR and Futuba are the same as far as the wires go, just be sure you line up the BLK/FUT to the BRWN/JR wires. I use JR digitals for my ailerons. Plug them in like so, I always plug in the male JR end into the female futuba end otherwise you have to trim the tab on the futuba. Just be sure to safety wire or clip them together as the JR end is a little odd shaped.
Shane
Shane
#3500
RE: RCGF Engines
Got the maiden in on the Sea Gull Yak with the 20. Got 8,840 rpm with a Xore 16-6 on the ground. This engine has about 1/2 a gallon through it 32:1 Pennzoil. It amazes everyone that sees it run.
The plane has unlimited vertical and seems to be a great match for the engine. Did run into a problem I have not encountered before. The elevator trim couldn't be adjusted for level flight.It was either climbing or with one click down it would drop with hands of on elevator. It flew level inverted without input. 45 degree inverted climb stayed at 45 degrees..The C/G was right on with the Venessa Rig. That is as much info as I can give right now. Any help would be apreciated.
