RCGF Engines
Old 08-16-2014, 07:26 PM
  #6276
iflyjr
My Feedback: (19)
Engine ran great. Started 4 flips brand new. After that first flip. Very happy so far. RCGF 60 single
Old 08-17-2014, 06:04 PM
  #6277
rt3232
Six Guns
Been using pitts style mufflers for about 20 years (G-38 first) a vibrator to say the least, any way I have found that if you add a third attach point on the far side of the can, can to engine you will no longer have it coming loose. ( it can't be to the firewall) you may have to find a welder to add a small plate or spot to drill and tap the muffler can for the support leg
If you need a pic of what I am trying to say can do.
Cheers Bob T
PS captmicom I have to say THANKS for your support
Old 08-17-2014, 08:11 PM
  #6278
Captmicom
You are welcome!!!
Old 08-17-2014, 08:21 PM
  #6279
SIX GUNS
SIX GUNS's Avatar
Bob if you have a pic that would help
Jim
Old 08-18-2014, 02:00 PM
  #6280
rt3232
Six Guns
Can't seam to get the pics to up load.
If any one knows how to do this sure would like some help
Cheers Bob T
Old 08-18-2014, 02:09 PM
  #6281
rt3232
This is the leg on my RCGF-62 it is the piece from the head bolt back to the muffler maybe I got it figured out
Cheers
Name:	RCGF-62 muffler.JPG
Old 08-19-2014, 06:22 PM
  #6282
rt3232
Hear is another pic of a third attach point, this is on a RCGF-26. and this muffler was made from a wood mock up by bison in Canada, The volume of the can is approximately 2 X the std pitts can and the DB avg on this one is right at 87
Hope this helps
Cheers Bob T
AMA13377
Old 08-20-2014, 06:00 AM
  #6283
SIX GUNS
SIX GUNS's Avatar
Thanks Bob I am going to look at how
I can do something like that it looks like it mite
work out well
Jim
Old 08-28-2014, 03:13 PM
  #6284
rt3232
Now I have a question of you RCGF users, I and my flying buddy both have new engines, mine is a 62 and his is a 45.
The question is why would they both viberiate at low RPM's 1850 to 2k we both balance our props and spinners, both have only about 15 to 20 min run time, they are easy to start great throttle response and hi end. we normally pre-tune on the test stand and then put them in a plane and fly them for brake in, for about a gal std 87 oct gasl none ethenol at 35;1.
cheers Bob T
Old 08-28-2014, 03:36 PM
  #6285
ahicks
Pretty typical for a single in my experience. Just off the idle they'll get the tail surfaces jumping around pretty good, justifying the time/trouble you spent installing flying wires easily....
Old 08-28-2014, 06:09 PM
  #6286
rt3232
Maybe I should have added we are comparing them to older engines of the same brand except the 62 and that we are comparing to my 2 G-62's similar birds size and weight. all are bi-planes pitts, c/eagle and a weeks
It's not a big deal, was just looking for some other thoughts.
ahicks we are using functional flying wires on all of the birds, and maybe they will smooth out with a little more time on them, and thanks for your comment.
Cheers Bob T
AMA13377
Old 08-29-2014, 04:28 AM
  #6287
ahicks
G-62 vs. RCGF does put a different spin on that thought. How do the engine weights compare? If G-62 is heavier, maybe some of that weight is in heavier crank counterweights?
Old 08-29-2014, 01:01 PM
  #6288
rt3232
Hi ahicks
At this point I don't have a clue on the that, as my G-62's have custom style pitts mufflers, and the RCGF-62 has a home made pitts style muffler and I have never put them on a scale.
But you sure could be right, from the looks I would guess the heads came out of the same casting mold, but that is ware the similarity ends. I have never had the G-62's apart, they have side carb's and the RCGF-62 is a rear carb.
Top end's are vary close in RPM's with the same props, So like I said it's not a big deal, as we both like our engines.
cheers bob T
Old 09-01-2014, 08:04 PM
  #6289
SIX GUNS
SIX GUNS's Avatar
Bob do you still have the P-47 and the F4U . Don't you have a G62 in the
P-47 ??
Old 09-02-2014, 04:49 AM
  #6290
rt3232
P-47 ??
Yes I do, but do to health and weather I have not flown the Corsair I a year, and the 47 is ready to go after clipping the corn last fall.
Had the Corsair out but d#$@m air pump bat went south so just able to run it around on the ground a bit.
Becouse these 62's are shakers I recommend soft mounting them, also I have found that making the mount plate out of steel may eliminate the need for nose weight to balance.
Cheers bob T
Old 09-29-2014, 12:07 PM
  #6291
hutch814
Im looking for a rcgf 50cc single cylinder head where can i buy one the threads are striped for my spark plug. hard time trying to find one
Old 09-29-2014, 12:32 PM
  #6292
iflyjr
My Feedback: (19)
What about a heli coil.
Old 09-29-2014, 12:53 PM
  #6293
captinjohn
A new cyl head should be cheap brand new...if it just a removable head.
Old 09-29-2014, 05:31 PM
  #6294
Captmicom
You can buy one from me... I have one or two left in my parts bends.
Capt Micom
Old 09-29-2014, 05:37 PM
  #6295
ahicks
Capt, any word on the 10 yet?
Old 09-29-2014, 08:25 PM
  #6296
Captmicom
Not a peep!! I did some draft testing work on a new type carb for the 10cc and sent it out, but I have not heard how it worked yet...
Old 12-22-2014, 06:46 PM
  #6297
Ted Harrold
Hello I have "heard" some of the smaller gas engines ,from other manufactuers still need to have a starter to help them to get started. Is there an issue with the 15-- 20 size rcgf motors?
Old 12-22-2014, 08:22 PM
  #6298
Captmicom
Hi Ted,
I can't speak to all small gas engines. But as for RCGF, there is nothing wrong with the RCGF 15cc and 20cc engines. The issue is our brand new engines have not had a gas in the carbs before. You sometimes need to use a starter on a new engine to get the carb wet with fuel. After that they will hand start. The other issue that comes to mind for using a starter, is to use a prop with a sharp trailing edge.. (Not Smart to try to hand flip one of those)
Old 12-22-2014, 09:03 PM
  #6299
Captmicom
To All of My RCGF Engine Friends
We are Proud to Announce
The Grand Opening of The RCGF USA Warehouse!!
As most of you know we opened the US Service Center a few years ago in order to provide warranty service right here in the good old USA. We have now brought RCGF direct to you via the RCGF USA Warehouse. We are adding a bunch of new resellers every day! It is real easy for your local hobby shops to become a reseller. Just have them give me a call to get signed up. If you want to buy direct you can go to www.rcgfusa.com and place your orders from there also. RCGF has also reduced the prices of all of our engines making them even more affordable!!
Old 12-22-2014, 09:20 PM
  #6300
Captmicom
The long awaited day is finally here.
I have just this last weekend received the first RCGF 10cc beta gas engines. We are putting it through its paces and so far it is proving to be a little powerhouse!! Running it wide open for 15 minutes on a 60 size Ugly Stik, it only used about 2 oz. of fuel. I will keep you all posted and also let you know when it will be available. The cost should be $179.99 + tax.
