WOW!! New DL 111cc and 55cc !
#301
CA
RE: WOW!! New DL 111cc and 55cc !
I cant find that pennzoil air cooled any place today i was looking. Is it going to be better then the lawnboy?
ORIGINAL: flatspinjim
I used Pennzoil air cooled to break mine in. 32 to 1
#302
No comparison. The Pennzoil burns nice and clean. Lawnboy leaves a sticky sludge all over your plane that is a bugger to clean. I order mine by the case here:
http://oilstore.stores.yahoo.net/pe2cyforairc.html
Edit:
This page shows what the new bottles look like. They read Outdoor Multipurpose for Aircooled engines. It is the same as the old oil, but with a new label. The 8 oz bottle are just right for mixing up 2 gallons at 32 to 1. You can click on the picture of the bottle to zoom in on it.
http://oilstore.stores.yahoo.net/penaircool2c.html
Edit:
#305
LIfer, Troybuiltmodels has what they call a quiet beauty muffler for the g62. I haven't tried one so I can't say how quiet it is. I do have a g62 that I started for the first time the other day and it fired right up and idled beautifully. It will eventually be going in a warbird after I fly it on my Big Bee for awhile. I am hoping to get a lightweight 50cc engine pretty soon for a cap 232 I am putting together. DL seems like it is getting most of the votes around here, but I have yet to see one in the flesh. I'm going to a couple of big bird fly ins later this month and hope to see one in action.
#306
My Feedback: (85)
I bought a DLE 111 today from a reputable Chinese dealer that has very good feedback on Ebay....Price I paid was $530 + $44.99 for DHL shipping...Total of $574.99 shipped to my door...I should see the engine in 3 to 5 working days....I would have bought from a USA dealer but after reading about some dealers balking at warranty repairs I figured what's the point and saved myself some bucks...
Kevin
Kevin
#309
My Feedback: (85)
ORIGINAL: SOLO_48
You be sorry,you my save money,who`s going to back you up in time of need
Kevin
#310
Then I have orderen my first DL. The 111.
Began buying DA, then discovered the Mokies are really reliable and cheaper. Then again I tried two MVVS`es, added tunedpipes and even the tiny MVVS 35ccm is pretty close to a DA50 in power! It revs 7400RPM with a 20x10 propeller, still running 1:30 oil and have ran less than 6 litres of gas through it. I am impressed.
So then it is time to try a real cheapie. The DL111 will get two Krumscheid tunedpipes and headers and will serve in one of my TUGs. I am curious to see if the DL works or not Hope the DL111 in my TUG will be able to tow 50 pound gliders without problems... Just a pity DL don`t offer anyother headers andpipes than the lousy loudpitts-mufflers.
#311
CA
Can anyone tell me what the plug gap should be on NGK CM-6 plugs for my new DLE 111. It don"t want to run on both cylinders all the time with those cheap looking china plugs that it came with.
#312
CA
Thanks anyways , I just found it .018-.020
ORIGINAL: g-pace
#314
CA
cm6 plugs had a night and day difference on the way it ran. I flew the plane and the engine ran great atleast for that one flight. I think it will be a good engine.
#316
Hi
i am just installing a 111 in my 1/3 scale clipped cub. can anyone tell me if a 3amp ubec is sufficent to power the ignition ?
I am planing on using a 1800 mah lippo 3 cell, cut down to 2 cells, this has worked really well with my dl 50, but I cannot rememberwere the balance leads should be connected ?
#317
CA
ORIGINAL: Hibrass
Just go mine in the mail today!!!!
Can't wait to get it installed in my CAP and start it for the first time!
#318
My Feedback: (41)
ORIGINAL: cavandish
Hi
I am planing on using a 1800 mah lippo 3 cell, cut down to 2 cells, this has worked really well with my dl 50, but I cannot remember were the balance leads should be connected ?
Hi
#319
WV
Hiya DL111 owners!
Question... How much space does your engine have between the Prop drive flange and the Engine case? Mine is over 1/8 inch....
http://www.rcuniverse.com/gallery/ga...memid%3D168694
I have had a chance to run the engine and all else appears fine just was curiuos..
Ed
Ed
#320
Both of mine are the same. It's normal, my sensor just reaches the far edge of the magnet. Yours might be a hair more than mine but not much if it is.
Here is a link to a drawing of the 111.
http://www.ef3m.pl/files/DLE111-2.jpg
#321
WV
Thanks for the confirmation Super 8.
I noticed that the trigger magnet was drilled and install very close to the edge of the prop drive so I thought it was ok... Just nice to know it is also normal.. :-)
Here is what it is mounted on!
Ed
Ed
