WOW!! New DL 111cc and 55cc !
My Feedback: (9)
OR
Just saw that these things we're released now over on TBM and valley view. >>> http://www.valleyviewrc.com/Gas%20Engines.htm Coming from DL....you know they are gonna be good! I also noticed they are "lighter" than the previous 100cc and 55cc.
My Feedback: (67)
IA
RE: WOW!! New DL 111cc and 55cc !
I talk with Tom at Valley View and he will still service the 50's and the 100's, I think I might buy another(last of the mohekens)DL50's for future use.
NEDYOB
NEDYOB
ORIGINAL: Jake Ruddy
I wonder what all the DL 50 and DL 100 people are going to do for parts in the future? Did they just change the jug?
My Feedback: (21)
Time to buy up parts before they are gone. Just read in another thread that the parts are dried up for the old ZDZ 80. Won't be buying a used one of them anytime soon.
Them DL's look nice. Heard they are doing a 222 also. Any new info on that one?
UT
Gents, I see you are sold on the DL Engines.. Please comment pros and cons against the DA engines? I like the fact i can have more Airplanes and engines with Cheaper price But i like performance as well for 50 Gassers on 3D and Warbirds.. I"m in the middle of No where so i don't get much feedback other than these Forums. My buddies back in south Texas use DA religiously and don't like to change..
My Feedback: (22)
OH
I just ordered mine hopefully be here next thursday or friday. Does anyone already have on? Also have a DL 100 tom said the only change was the jugs punched out a little more for the 111 so that means if you have the 100 that needs parts you later on your ok.
ORIGINAL: terribleTom
My Feedback: (13)
I too am waiting to pull the trigger on a 100cc classed engine. The anticipation of some real world testimony on the 111 is killing me!
Post up guys!! LOL
Stan
WV
Post up guys!! LOL
Stan
WV
i wounder will tom have that in a combo i would like to try that dle111 seems to be another winner but wow the price is moving up still way cheap but i will hold my wallet on the 222 and a 150 that will be out soon
WI
Unless people panic and go out and buy up all the parts.
This DA / DL pros and cons thing has been flogged to death.
Seriously though, a search will turn up more info on the 2 engines than you care to read. Pop a HUGE bowl of popcorn and get a few cases of your favorite beverage and have at it!
Mike
Wont be able to fly this weekend on account of the weather(cyclone) here, but will do a few heat cycles and tune the needles.
Looking good dude. I notice that they come with the new hub too.
Where is your floats?, or are you going to hand launch?.
My Feedback: (10)
OH
OK guys I am missing something. I have a DL50. If you look at the specs of the 50 and 55 the only thing that has changed is they raised the compression. I have read people saying they changed the bore or stroke but the specs just dont show it. I am sure it will be another winner but i am just trying to figure out where they are getting the extre displacement.
Rich
Rich
GA
I guess they could change the crankshaft journal size to get a larger displacement, but an increase in compression would suggest a milled head,or a thinner head gasket, maybe a dome piston.
If it's as good as the 50, it will be a winner for sure.[8D]
ORIGINAL: wiz310
They come with some little standoffs as well, but not the ones in the photo.
I have a launch stand, vertical take off and landings.
ORIGINAL: Checklst
The bore is 2mm bigger, stroke is the same. And compression is up from 7.5 to 7.6. Does have a dome head piston, but so does the 50/100
Rest of engine is the same as the 50 & 100
The skirt at the bottom of the cylinder is 2mm larger in diameter, and the crankcases have been bored out a short depth where its meet the head to accomodate the new head/skirt.
Crank, Reeds, Carby, new prop hub etc are all interchangeable with the 50 & 100
The new head is missing the bottom cooling fin, except for a short stub under the exhaust outlet. But the rest of the fins are now square from top to bottom, and no longer taper/reduce in size from top to bottom if you look at side on.
I pulled a new 55 and 111 apart to verify.
Cheers
Scott
DL Engines AU
ORIGINAL: dlenginesaustralia
The new 55 and 111 have different head/piston/crankcase and cylinder gasket
Cheers
Scott
DL Engines AU
ORIGINAL: Checklst
Cheers
Scott
DL Engines AU
More at www.dlenginesaustralia.com/gallery
Cheers
