DLE30!
#3626
RE: NEW DLE30!
ORIGINAL: strgazr27
Now that right there is funny
ORIGINAL: Tired Old Man
I'm not here to make anyone happy. If the kid is ugly, telling Mom it's cute doesn't change the appearance of the kid. Information I'll give but no Dr. Feelgood stuff.
#3628
RE: NEW DLE30!
I got to get off too...need a tap to tap threads in a adapter part I made. The size is a question too. Need bolts that will fit a Pitts style muffler that was to a Moki 1.35. Lost the bolts...but a american size may work too....as long as I can get a bolt the right size and tap with SAE threads. Oh the fun of it all! Capt,n
#3629
SD
RE: NEW DLE30!
ORIGINAL: w8ye
Gaskets under the cylinder would change the timing?
#3630
RE: NEW DLE30!
ORIGINAL: jerrysu29
On my new V2 rear carb 30cc DLE there was no steel alignment pin in the whole. I did not drill the block, I just installed a piece of plastic tube in the elignment hole, epoxied it in and installed the linkage rod, maybe your V2 had a steel pin but mine didn't.
On spare parts crankcases for v2 DLE30 engine received, ALL of them comes with the steel pin installed. I think the factory install the pin before machine the cylinder base to leave it flat, with both sides bolted and aligned by the steel pin.
Regards
#3632
RE: NEW DLE30!
I converted my DLE30cc engine from side intake to rear intake. If I ever decide to split the case...I will drill all the way through and install a pin. That way if I take it apart & go to putit back together, that pin will help locate thefront & rear casetogether. It is a pin for alignment. Capt,n
#3633
SD
RE: NEW DLE30!
ORIGINAL: mpascual
On all kits for conversion to rear intake i've installed (more than 50) , the alignement hole is not drilled on the rear side of crankcase.
Regards
ORIGINAL: jerrysu29
Regards
#3636
DC
RE: NEW DLE30!
This is how NON issues become issues...You don't need an alignment pin, just bolt the cylinder on loosely, tighten the case bolts, tighten the cylinder...What pin ???
The only thing the rear case does is seal the carnkcase and provide a mount for the carb..NO stress anywhere, a few thousnandths misalignment would make no difference anywhere, the cylinder base gasket would seal just fine.
#3638
RE: NEW DLE30!
ORIGINAL: Antique
The only thing the rear case does is seal the crankcase and provide a mount for the carb..NO stress anywhere, a few thousandths misalignment would make no difference anywhere, the cylinder base gasket would seal just fine.
Newbies I am sorry for leading you astray! Capt,n
#3639
My Feedback: (22)
FL
RE: NEW DLE30!
sometimes you guys split hairs giving us newbies the impression that the dle30 has all kinds of issues when in fact theres almost nothing really wrong to begin with.and I am not including the pseudo side carb .that sinle change alone has vastly made the engine a good solid investment.
#3640
My Feedback: (9)
WA
RE: NEW DLE30!
On a different note, I've been running my DLE 30 with a 18-8 Xoar prop. Last week I tried the Xoar laminated 19x8. What a difference in noise! It sounds much mellower that before. I did not get to fly much due to some new-plane-maiden flight issues that had to wait until I returned home to fix, but I'll get some time on it this week. I would not have believed that a prop change could make so much difference!
Sam
Sam
#3641
ON, CANADA
RE: NEW DLE30!
ORIGINAL: DaddySam
Sam
Sam
#3642
IL
RE: NEW DLE30!
Has anyone used the single bolt conversion assembly for the 30 from Valley View I'm wanting to use my Dynathrust 20x6 and it has the molding pockets in the back side of the prop ordered a new MA classic it also has the holes oin the back side!Would be kinda hard to drill the holes for the four prop bolts and get them lined up correctly. Just wondering if the single bolt adapter might spin on the prop or if it would hold it tight enough!
#3645
LA
RE: NEW DLE30!
Hey guys ive been away from the forums for a while... didnt realize that DLE is selling the 30 with the carb mounted on the rear. I just placed a order from Horizon this morning for the Taylorcraft, im planning on buying one of the new dle-30's with the carb on the rear. Im thinking thats gonna be a good combo. So guys yall fill me in, hows the new 30 doing with a rear mount carb? Did it solve all the issues they were having?
#3646
RE: NEW DLE30!
Hi everyone:
The ignition on my DLE 30 is damaged.. I tried the ignition form the RCG 26cc engine i bought from hobbyking a while ago and works flawlessly with the DLE.
Question is there anyone that sell the an iginiton for the DLE that is not tower hobbes cause $90 for an ignition i find it too much..
Hobby king has the ignition for the 26cc which i'm using for $25 but its out of stock currently.
Does anyone know where i can find a similar ignition at a reasonable price??
#3647
RE: NEW DLE30!
ORIGINAL: Night Scream
Hi everyone:
Hi everyone:
#3649
IL
RE: NEW DLE30!
I got my second DLE 30 V-2 today it didn't have the new throttle lever ext. must have gottin an older one then the one I got earler Oh well can still make it work but I liked the new replacement better!
#3650
RE: NEW DLE30!
What about those CDI's that hobbyking sells? I saw one that says works from 26cc to 50cc?
Do these gas engines from that range use the same ignition? I though the ignitions where individuals to each engine size..
