DLE30!
#1303
ORIGINAL: gen3v8
Can ypu please not use the word STUFFER with Jody`s name affixed as this was my contribution
Ido know someone in the injection molding biz, and I have investigatedthe process,there are several prohibitions in makingthe stufferfor the 30. The biggest is the cost of the tooling required for the mold, it's many thousands of dollars. There are not enough 30s out there to pay for it, not to mention I have a bit of a problem with profiting from the sale of it when it should be given to anyone that purchased a DLE30 and needsit. And contrary to popular belief, the factory has beenworking to solvethe problemsthat people have related to them, I correspond with them about itregularly. My luck would be that right after I paidthousands of dollars to manufacture a stuffer the factory would release one of their own or something that provides equivalent relief,then gives it away as they should.
The 30s that Ihave flyingdo not have any kind of stuffer in them, with the exception of the very firstone Iran and mounted allare just as they came out of the box and mounted with the plug at 6:00, none die in the air,when landing, or when turning rightbut all will die on the ground after idling for several secondsthen tilted carb up.
I won't make the stuffers for customers even if they want to pay for them, I just don't have the time to hand make them for everyone that may want them, that's why I posted the pictures. Iand others have been working on other things to help this engine that may be easier to produce or convince the factoryto change the design but all of it takes time.
#1305
ORIGINAL: jedijody
The 30s that I have flying do not have any kind of stuffer in them, with the exception of the very first one I ran and mounted all are just as they came out of the box and mounted with the plug at 6:00, none die in the air, when landing, or when turning right but all will die on the ground after idling for several seconds then tilted carb up.
#1306
WY
Geee... I built my first crankcase stuffer for a Mac 91 gokart in the late 60's. An thats just what we called it a crankcase stuffer.
ORIGINAL: gen3v8
#1307
ORIGINAL: gen3v8
#1308
ORIGINAL: tkg
ORIGINAL: gen3v8
Can you please not use the word STUFFER with Jody`s name affixed as this was my contribution
#1309
For the life of me, I cannot understand why DLE chose to side mount the carb and duct the fuel/air mixture around the case. Of the the 26cc engines that I have the biggest nit I have is that the carb usually has to stick out the side of the plane.
Any theories as to why the didn't put the carb on the back of the engine like the 50 and 55? No pooling problems with a shorter and more direct path. Not to mention the throttle linkages are more direct and easier to route. Most of these engines are mounted on 2 1/2" standoffs anyway.
#1310
3d I wondered that also and believe it could be because of the length that most planes have to use for the engine in a 30cc class. I know that you can cut the firewall so that the carb would work but not all planes are capable of having that done. I hate to cut a beautiful cowl also.
#1311
I guess DLE did make a DLE30cc protoype engine with rear induction. I understand it ran well. But the DLE people thought it would be too "long" of a engine with rear induction. I guess it may help to let them know our thoughts. So now is the time to post if you think the engine would be to "long". Also email the DLE company. They do respond. Best Regards Capt,n
#1312
CO
Jody has done WAY more testing on these engines than anyone else on this thread that actually KNOWS what he's doing and people have the nerve to say that he's just wanting credit for it. That simply amazes me!!
#1313
ORIGINAL: flatspinjim
#1314
I don't understand what these negative remarks towards Jody are all about. He has done more for people on thee forums than any of these people could hope to do. Jody never claimed to take credit for anything that I seen. He has just been helping out. I had a quick look back and I can't see any posts where Jody claims anything to be just "his" idea.
edit: (sp)
edit: (sp)
#1315
My Feedback: (24)
TN
ORIGINAL: captinjohn
Well I will go even further...Jody likes to take the credit for all he can. I was the first to post that mounting the DLE at a 20 degree angle would help this pooling problem a lot. Jody for a long time said people just did not know how to tune the engine and ..OH...the pooling problem when tilting engine has to be a pretty isolated thing! I even had video about a test...but could not upload it untill weeks later. Capt,n
ORIGINAL: gen3v8
Dang, Somebody that lives near this guy go give him a pat on the back he has solved it all! HA HA HA
Some of you guys just make me sit back a laugh. My 7 year old acts more mature than you guys!!
#1316
[quote]ORIGINAL: sodbuster 1
ORIGINAL: craigteffe
Same issue on two different engines, mounted on the plane and tryed everything. see below. I have had 3 different carbs on this engine also. gaskets are in good shape.
[/quote
what's the serial numbers on the engines?
ORIGINAL: CAT POwer
What about the Carb gasket if it is sticking up1....2 mm creating a pool area............
Well here is an update to the issue of the engine dying when you hold the plane in the air with the carb verticle the engine goes rich, if i lean the low end setting it cleans up but will not transition and runs lean when the plane is upright. I tryed another battery straight to the ignition and tryed another ignition still no good. I remoed the carb and adjusted the lever hight on the main needle when i raised the lever height that helped the transition but the egine still dies at anything less than 2800 RPM When you hold it at different attitudes. I pulled the engine apart and found that one of the reeds is raised off the base ever so slightly, not sur if this is the issue or not! Put the engine back together and ran it some more still the same. I also rigged a new tank and strapped it to the side of the plane I have tryed everything except run time and a new set of reeds and reed stop. I will also recheck the timing but I'm pretty sure this is not the issue.
I posted this over on his site but wanted to post it here so people could give some feedback.
I bought 2 DL 30's about a week or two ago, My friend has one and I have the other. We are having some trouble with them and would like some help. Here is what is happening, Engine is mounted inverted without cowl and when started and warmed up we tuned for max RPM on high end and adjusted the low end for good transition. When you pick the plane up and turn it slightly where the carb is angled up and then level the plane back out the engine dies, you can also shake the plane slightly and it dies, (Throttle setting at idle or 2 clicks above idle). We have replumed the tank and replaced the fuel line, removed the felt clunk and installed a regular clunk, installed a nipple on the diaphram cover and run a line to the inside of the plane, rotated the carb, hooked the battery directly to the iginition, tryed another ignition module, tryed another carb, tryed a carb off of a G26, tryed a velocity stack, mounted another Dl 30 engine on his plane and it does the same thing. We tryed one thing at a time before trying something else. We orignally found this problem when lifting the plane off of our flight stands to place on taxie way. The engines only do this at 2 clicks above idle or below they run great above that throttle setting.
Anybody else with these engines could you please try your planes at idle or 2 clicks above rotate the plane around and see if this happens to you and post back here.
Thanks for any and all help!!!
Ask Ralph C.
I bought 2 of these engines from Ralph Cunningham One for me and the other for a friend, He has his mounted and when you go to pick the plane up the RPM changes or the engine dies. Anybody run into this issue before? We have the high end set for peak RPM and the low end for good transition We can seem to tune it out but then the engine stubles real bad when you advance the throttle. We have it mounted on a Sig Mayham with no cowl. He is going to mount my engine and she how it works. He has replumbed everything, I told him to try a regular style clunk because a few have said the filter clunks have solved thier issue.
#1317
<div>Can we drop the banter about this pooling problem?</div><div>
</div><div>Or at least everyone get over it til someone comes along with a cheap fix or the factory does?</div><div>
</div><div>Start a DLE 30 Pooling Problem thread and complain and whinge about it there if you feel you were ripped off.</div><div>Seems you either fix the intake plenum problem yourselves, mount the engine any way but vertical, or sell the engine and get over it.</div><div>
</div><div>Piping up in here and b*tching how the factory is doing nothing isnt helping anyone. Nor is the arguments about who came up with the fix or what its called. </div><div>
</div><div>I want to see more pictures of peoples installs with the DLE-30 and prop data etc.
</div><div>
</div><div>
</div>
</div><div></div><div>
</div>
#1318
ORIGINAL: VeeAte
</div><div>
</div><div>
</div>
</div>
#1319
ORIGINAL: VeeAte
</div><div>
</div><div>
</div>
</div>
I just found out santa is going to be leaving this engine under my tree! I came to this thread to do exacly what you said, learn about oils, octane, and props. This thread would be much more useful without the childish arguments.
So, I have run maxima 927 in my dirtbikes and atvs for a good while. It is one of the best (in my opinion) oils, however will it perform just as well in this engine? I also run cam 2 fuel, would there be a noticable power increase with useing that over pump gas?
#1320
My Feedback: (8)
There are a lot of good oils to choose from and different ways posted to break in. I have went to pennsoil for aircooled engines at 32-1 on breakin and because its good and easy to pickup. Then use echo 50-1 sys oil. I have not made the change to syn yet as I have only ran the engine on test stand. Xoar 18-8 was turning 8100+ . Idle was 1900 . This was after about three hrs of running at 3000 on the test stand. Now all I have to do is build the Yak 54 and go fly.
OH I for got I use 91 pump gas.
#1321
All this moaning and groaning about the DLE 30 but nobody seems willing to step up and spend more than double the cost of a DLE 30 for a tried and true 3w-28i, which I know can run for over 600 hours and never give a moments trouble. Then you have the Zenoah G-26. Do people want a strong and reliable engine or a reason to complain? BTW, all three of the engines named in this post have their purpose, and none of them are bad engines.
#1322
Jody,
In the photos you posted, what type of material did you use to make it out of? I work with Marty as a mold maker. We were trying to figure out
what type of urethane to use that would cast into a silicone mold. I think most urethanes won't do well with gas & heat.
Mark
Mark
#1324
ORIGINAL: Tired Old Man
<br type="_moz" />
