DLE30!
#1351
VA
Count me in on the "how to" request. My engine was OK (mostly) untill this cold weather hit. Can't even think about flying now cause it's 26* and snowing and over a foot of snow on the deck and and and. And I need to modify my engine. Thx. Bob
#1352
There's a Devcon epoxy product that will work like that real nice aluminum job. It contains a whole bunch of titanium and machines extremely well. Won't fall out or break loose inside the plenum. Expensive!!
A little secret for cold wx running. Insulate your engines to keep the heat in, instead of cooling them. Reduce the amount of incoming cooling area. Pre-heat your engines before trying to start them. A heat gun works real good
#1355
Some sites have outlets at the field, some don't. Leaving the plane in the car with the heater turned up high is another option. Planes using a 30 are generally rather small. Or just find that person that always has that electric personality and plug into the appropriate orifice...
#1357
NH
There is enough hot air on forums to take of it. What we use in the race car dry sump tank is a heater like this:
http://www.hrpworld.com/index.cfm?tp...action=product
It is easy enough to use an inverter running off the car battery to power it up.
<br type="_moz" />
<br type="_moz" />
#1358
MD
You stuff the intake with clay mark your carb port , carve out the clay around it back to reed area smooth it let clay dry or heat it dry
Get some alumaweld rod from weld shop it melts at 700 plus degrees with propane torch
Stand it up heat maniflod, touch rod on insides till full
File the face with good flat file
If for some reason you want it out just heat to above 700 degrees will run right out
This is real aluminum acually stronger and welds to the manifold
It takes a little time and skill but will last
I tested epoxy and jb weld and body putty after leaving them a few days in jar of 2 cycle gas you could crumble them in your fingers
I know the intake is not flooded all the time with fuel I just dont think it would last,also it may bounce around and possibly get into reeds or cylinder if falls apart
Dont take offense to my opinion about epoxy type fixes it just isnt for me, I figured I would postmine if anyone would like to use it</p>
#1360
alle, that sure looked like a good way to do the intake runner. What kind of clay did you use? Did you need to add any sealant on the base gasket on re-assembly? Thanks Capt,n
#1361
A little secret for cold wx running. Insulate your engines to keep the heat in, instead of cooling them. Reduce the amount of incoming cooling area. Pre-heat your engines before trying to start them. A heat gun works real good [img]{akamaiimageforum}/image/s49.gif[/img]
Most snowmobiles are 2 strokes and have very little trouble starting at - 25 C, if there is trouble some either quick start from your automotive supply will get them running quick. a quick shot into the carb and away you go.
#1362
Not much oil in that either. Quite a few people will use far too much of it. I use the stuff for starting engines on the "bench" but it's never more than a quick shot at the right time.
The titanium filled Devcon product has been used to rework cylinder ports in morotcycles. If you do a good job of cleaning and scuffing before hand it does not loosen or fall out.
#1364
Started the DLE 30 in my TLT yak today. Took alot to get it wet, but then started right up. Running a 18-8 APC on 32:1 gsa oil(laenboy) mix. Factory settings. Didnt sound rich, but after two tanks of heatup/cooldown running I was able to only get 16.5 lbs thrust on fish scale. How much more can I expect with time and proper gas/oil ratio, and carb tuning. I didnt tach the top end but I got it to idle reliably at 2100 rpm. The tilt test slowed the idle some but engine didnt die. I think it would have if idle were any lower...antiquefer
#1365
ORIGINAL: antiquefer
Maybe you might want to get rid of the Lawnboy oil though. There are much better alternatives like Pennzoil and others.
The idle will get lower and the high end higher as your engine wears in !
They are great little engines
#1368
My Feedback: (19)
ORIGINAL: ghoffman
I have a 10 year old set of Chevrolet race car heads that have epoxy in the intakes. It is very thin however.
#1369
T.O.M and apalsson, The engine and plane are in fact not mine. I installed it for a friend. I said it was mine caus it was easier. I wish it were. Anyway, Upon seing what you wrote about Lawnboy, I was concerned and called the owner. He said the gas oil mix he gave me to run in the engine was in fact penziol @ 32:1. Dont know why I thought it was Lawnboy. I am glad that what ever is wrong with Lawnboy, I didnt use it. Thanks for the help.......................antiquefer.
#1370
ORIGINAL: Truckracer
In the race class I competed in for several years, our small block Chevy engines were very restricted on carbs and intake manifold configurtions. But there were no rules governing modifications to manifolds. Some guys spent thousands of $$$$ to have their intake manifolds modified for optimal airflow. They cut the intake manifolds in half lengthwise to get access to the ports then the ports were reconfigured using a combination of tig welding and filled epoxies. After grinding the ports to shape, the manifolds were rewelded back together. Have seen the same thing done in cylinder head intake ports. The point here being that the filled epoxies held up extremely well. I wouldn't hesitate to use them on one of our gas engines.
ORIGINAL: ghoffman
#1371
My Feedback: (19)
I've been away from that for awhile now but remember they just applied the filler to a very well cleaned, freshly ground surface. Some guys used the Devcon product Tired Old Man talks about ..... some just used JB Weld. I no longer have a contact who I could confirm this with though.
#1372
I don't have the precise name of the Devcon filled product. You can Google "Devcon" and work your way through a couple of Devcon pages to get to the right one. It's a titanium filled epoxy and the only one they have. It's better than the J.B. Weld by an order of magnitutde. Not a glue as much as a filler that accepts high tolerance machining and will handle the heat of the transfer and boost port sections of cylinders. It does not come cheap and is available in 1/2 and 1 pound quantities.
#1373
My Feedback: (19)
ORIGINAL: Tired Old Man
I don't have the precise name of the Devcon filled product. You can Google ''Devcon'' and work your way through a couple of Devcon pages to get to the right one. It's a titanium filled epoxy and the only one they have. It's better than the J.B. Weld by an order of magnitutde. Not a glue as much as a filler that accepts high tolerance machining and will handle the heat of the transfer and boost port sections of cylinders. It does not come cheap and is available in 1/2 and 1 pound quantities.
#1374
My Feedback: (52)
I believe this should be made public so it won't go into a PM.
The comment about the tried and true 3w 28 or a Zenoah product is quite relevant. People know that higher quality costs more but they don't want, or can't afford, to pay for that level of quality. However, they can or will afford to buy at lower price points. When they elect to do so they fail to remember they are not paying for the best quality, but for lessor quality. Then they expect to have the same level of performance and quality available at a much higher price with the better product. If you aren't capable of paying for the best quality, you should not expect the best possible quality...or performance. You've paid for fair to good quality and performence, not the best. If you expect the best possible quality, or try to force a manufacturer to increase the quality and performance of their products, anticipate that soon you'll be paying a much higher price for it. Until then the issue isn't with the quality of the budget manufacturers product, the problem is with the consumers that expect to receive more than they paid for. The consumer has the responsibility to determine what they want, what they need, and what they can afford. If they cannot afford the best, they should not expect the best, and accept the compromise that came of their decision.
I have found out for myself that I learn as I go, and most times learn something new everyday. And also to respect those that know more than I do.
So here is my question, You have posted many times about people buying lower quality parts, engines and so on. And expecting to get high quality products.
I took the time to go and check out the sales adds of the sellers of the DLE 30 engines, below is a direct copy and paste from one of the adds,
I have sold many of these to my buddies at our local field and have had no issues whatsoever! They have performed flawlessly!
Now after reading this, and MANY of the other adds that the sellers put out there, it is easy to see why the buyer would think that he or she is getting a good working product.
If you could shed some light on why sellers state these engines are so great, and then the engines turn out to have problems, could you,
Please tell us all why you believe the buyer is so wrong for expecting to receive what they pay for??? Or in the very least what the SELLERS are advertising???
I live my life every day thinking that I should get what I pay for. And it should be as it is advertised.
I wish you and everyone else the best life has to offer. And I mean NO ONE any disrespect.
