MT 35 Looks Like a Winner
Old 06-29-2010, 07:00 PM
  #326
PlaneKrazee
My Feedback: (14)
PlaneKrazee's Avatar
Default RE: MT 35 Looks Like a Winner
How is the vibration of your 35 vs the Syssa? The Syssa a clubmember owns was much smoother than my 35.
Old 06-29-2010, 08:19 PM
  #327
tele1974
I would have to agree with the Syssa being a smooth runner. Its a different motor and it really isn't fair to compare it. Its smaller obviously at 30cc and it likes the high rpms on the pipe. My Syssa was spinning in the mid 9's on a Xoar 18x6 prop too. Actually the same prop. I think the MT is probably going to have more low end grunt to it. But, I don't have the numbers to back that statement up. I am slowly learing all this number comparison really doesn't mean anything anyway. Ithink is is all about matching the motor with the airframe. The Syssa was not happy spinning those rpms and draging my extra through the air and thats why Todd has it. And, then again I really have no clue what I am talking about.
Old 06-29-2010, 09:25 PM
  #328
Rocketman_
Rocketman_'s Avatar
ORIGINAL: tele1974
I didn't get a chance to get a reading at wide open throttle. It blew my pipe off at 8000. I did get a reading today. It spun the 18x6 Xoar Beachwood at 9690.
Now you're talking! We learn now that you never reached full throttle during your previous test. Its best not to publish incomplete results. The MT-35 shines a whole lot brighter now.
Old 06-30-2010, 08:34 PM
  #329
tele1974
Can anyone recommend a side mount drop header.  I will need to go down 2 inches.
Old 06-30-2010, 08:41 PM
  #330
PlaneKrazee
My Feedback: (14)
The exhaust pattern is the same as a G26, if that helps.
Old 07-01-2010, 09:23 AM
  #331
Rocketman_
Rocketman_'s Avatar
ORIGINAL: tele1974
If you can't find an of-the-shelf header you can order a custom made header to fit your installation. I believe Just Engines Custom Manifolds http://www.justengines.unseen.org/ac..._Examples.html is just sitting there waiting for you to send an e-mail with sketch and measurements. They made a "Down Under" header (manifold) for my MVVS pipe. They even account for engine offset if you so specify.
Unfortunately and sadly the well known custom header craftsman, Karl Mueller, is very ill and is no longer making headers.
ORIGINAL: PlaneKrazee
Almost the same. It is very close. I had to open the bolt holes slightly in a Bisson muffler with a drill in order to get both bolts into the MT-35.
ID:	1461392   Click image for larger version
Old 07-11-2010, 10:11 PM
  #332
ultra6a
My Feedback: (27)
ultra6a's Avatar
ORIGINAL: Rocketman_
Another MT-35 runs.
Those new Xoar 19 X ''3DA'' props arrived from Valley View RC in a dented, bent and busted mailing tube but the props were undamaged. The props were obviously strong enough to prevent the U.S. Mail from breaking the tube completely apart.
Initially the engine was difficult to start because it would not draw fuel but it popped and spun the prop loose after I squirted gas in the carb. After squirting gas in it a couple of times it fired up and continued running. Before I was chased indoors by mosquitoes, thunder and rain I managed to get the max speed up to a ''blazing'' 4300 rpm and idle speed down to 2400 rpm after many needle valve adjustments and a tank of gas.
The following day I started all over by resetting both needle valves to 1 1/2 turns open and choked the engine. This time the gas came up in the line and flowed to the engine. Also, the compression was much better than the day before when it seemed to have a leaky piston ring. It surprised me by roaring to life on one flip of the prop.
With just a few needle adjustments, max speed went to 7000 rpm and idle was 2000 rpm (it idled at 1700 rpm but not reliably). It shakes a good deal more than the MVVS 26cc that it replaced. I'm using regular gas at 32:1 with Mobil Racing 2T synthetic oil.
I would have taken it to the field to break it in while flying it but the winds were too high, just as they have been for weeks.
Did you ever get yours to idle reliably below 2000 rpm? I can't get mine to do it. Cuts off everytime.
Old 07-12-2010, 08:06 AM
  #333
Rocketman_
Rocketman_'s Avatar
Yes, I did get it to idle below 2000 rpm. It will idle at 1800 rpm but is unstable at 1700 rpm.
Old 07-12-2010, 11:12 AM
  #334
Rocketman_
Rocketman_'s Avatar
ORIGINAL: jedijody
The carbs I put on the MT35 have a detent choke, they don't come that way but I modify them with the correct Walbro parts. I can also sell the parts for those that want to convert their high idle choke system to the detent type. ...
Do you also sell the complete WT805 carb and the fiberglass reeds separately for the MT-35?
Old 07-15-2010, 10:02 AM
  #335
mtenginesusa
The V2 version are complete now. upgrade parts including bigbore 805 carb. arm. manual chock, fiberglass reed. 4 bolts hub .
ID:	1468173   Click image for larger version
ID:	1468174   Click image for larger version
ID:	1468175   Click image for larger version
Old 07-15-2010, 10:41 PM
  #336
tele1974
Lookin' good!!! Just what the doctor ordered. MT... put it on a EScomposite pipe now and post some numbers. I think you will get some attention. Ididn't have mine on long enough to get some acurate publishable numbers to hold up to the scrutiny. Thou its not practical and probably not a good idea, I would bet a dollar it will spin a 18x6 Xoar close to 10g.
Old 07-15-2010, 10:54 PM
  #337
w8ye
My Feedback: (16)
w8ye's Avatar
ORIGINAL: mtenginesusa
The pictures are small and do not enlarge?
Old 07-15-2010, 11:00 PM
  #338
tele1974
Taylortown? Hello neighbor! 29 thousand posts. Wow!
Old 07-15-2010, 11:36 PM
  #339
w8ye
My Feedback: (16)
w8ye's Avatar
Rural Mansfield
Old 07-16-2010, 10:55 AM
  #340
Whistling Death
Whistling Death's Avatar
That is a nice looking engine. Have all the initial problems been worked out on it now?
Old 07-16-2010, 11:24 AM
  #341
jedijody
jedijody's Avatar
First one came yesterday for testing, I'll let you all know.
Old 07-16-2010, 04:25 PM
  #342
Rocketman_
Rocketman_'s Avatar
Its shaft has been modified and it lost its nuts.
Old 07-16-2010, 05:28 PM
  #343
Super08
Super08's Avatar
That must have hurt.....
Old 07-17-2010, 11:33 AM
  #344
Rocketman_
Rocketman_'s Avatar
Er, what were you thinking? Circumcision and castration?
Its too bad that the threaded prop shaft and nuts were not kept as an option to the 4-bolt hub arrangement.
Old 07-17-2010, 12:10 PM
  #345
w8ye
My Feedback: (16)
w8ye's Avatar
It will be a great honest day when Valley View gets into full swing support of the MT engines.
Old 07-17-2010, 12:15 PM
  #346
jedijody
jedijody's Avatar
We are in full swing, where do you think these changes are coming from? I've also been fixing all the previous ones that were sold by places other than VVRC. The first test engine is here, and the updated test 70 is on it's way, they are looking very good.
Old 07-17-2010, 12:42 PM
  #347
w8ye
My Feedback: (16)
w8ye's Avatar
This has been needed for a long time
Old 07-18-2010, 12:17 AM
  #348
aussiesteve
aussiesteve's Avatar
I got to lay my hands on a newly delivered MT 35 last week. A friend of mine received one (fresh from the factory I think) and I helped him get it running and tuned. I think it must have many of the ""Valleyview improvements" on it (not totally sure about that but it sure is a heck of an improvement on the last one I saw).
We got it running for him straight up (no hassles) and it seems like a very sweet engine indeed. I think this engine will definitley be rivalling all of the other Chinese made 26, 28, 30, and 32cc engines.
No - I am not dealing with them and am not involved with them in any way, nor am I going to be doing so - I was simply helping a friend out and can see where this engine is going to be a real winner for sure. (Kudos where they belong).
Old 07-18-2010, 09:15 AM
  #349
PlaneKrazee
My Feedback: (14)
Jody,
Glad to hear you are able to get things straightend out.
Old 07-19-2010, 02:08 PM
  #350
Switch_639
a question guys... which props do you use? a friend of mine purchased this engine and the prop hole is too big for the shaft... why is this shaft not same diameter as others? now he needs to make a spacer or something...
