Extreme Flight 87" Yak 54 - Build & Fly
#3276
My Feedback: (24)
RE: Extreme Flight 87" Yak 54 - Build & Fly
dave, actually there was a blue substance on the threads that I was sure was bule loctite. When I asked DA they told me it was some kind of blue loctite sealer, but didn't identify what kind.
I put blue loctite on and tightened it down, Hopefully I will never have to come off. I did this because the insturctions said to loctite everything. Now I just need a longer pulse hose.
JOhn
JOhn
#3279
I live in Bonney Lake and fly at the Ram Field. I usually fly, weather permitting, Sunday, Monday, Tues. morning, Wednesday morning, Thursday after 3:00pm, and Friday mornings. E-mail me with your number and I'll phone and we can set a time that works for both of us. We'll call Charles and have him come out too. Definitely, let's get together and fly. Perhaps IMAC...? Polar Bear is April 10th at Ram Field. I look forward to meeting you.
Mike Raines
ten pillows
Mike Raines
ten pillows
#3280
ORIGINAL: jrjohn
Just recieved my DA50. Cute little thing. It appears my carb is mounted different than others I have seen in the YAK I'm assuming I just have to turn it around? As it is, in the inverted position the throtle world be on the left side. Anything I need to know when flipping this thing?
John
John
you better check with DA before you do anything. They have been doing some mods one of which was to stop some pudling in the carb.. the change in orientation of the carb amy have been the mod. I just sent my DA back for this mod and some others.. all under warranty.
#3282
ORIGINAL: jrjohn
John
John
#3283
My Feedback: (25)
I have the DA with new carb configuration and the choke and throttle arms are on the top right looking from the front of the engine. To operate the choke I use a stiff wire with a hook on one end simply reach through the front of the cowl, insert the hook in the hole in the stock arm, push it back to close and pull it forward to open. Works fine because of all the room in the cowl and no need for additional linkages, etc.
#3284
I just thought i would open the box and check my engine that came with my yak. is this the correct orientation??
#3286
The Yak is designed to have the throttle and choke arm on the right as you look at the motor from the rear. Its a straight shot to the linkages this way.
The carb block mod has the nipple pointing down when the motor is installed on the plane. A two inch (or so) piece of tubing curls up from the left side and to the top of the carb.
You can probably get away with the throttle arm on the left side but I am not sure it will be a straight shot.
Anyone tried it yet?
Seems like people getting their motors now all have the throttle arms on the other side. I dont think thats part of the Mod. DA told me to just insatll the new carb spacer on my motor as is. They didnt say the carb had to be flipped.
#3287
My Feedback: (24)
ORIGINAL: The boys Back
John
#3288
#3291
My Feedback: (25)
I did not rotate my carb and got a straight shot from the servo by making some minor mods. I am using 4/40 ball links and a titanium link hooked to the short arm on the carb. I removed the red aluminum extension piece. I rotated and raised the throttle servo 1/4 in and cut away a small amount of firewall for clean shot.
#3292
My Feedback: (115)
VA
OK, where do I get the KS exhaust heade and pipe that connects to the KS pipe coupler? The one I have is not the correct one?
Please help ASAP, so that I can get it here quick.
Jon
Jon
#3293
My Feedback: (18)
I hate to bring this up, I even tried to search for it with no luck.... Which fuel line do you have to loop? the vent or the main clunk line... and why are we doing this?? I saw this a ways back, made an effort to look for it, got bored going through each page.
Also, Wayne.. could you have Drew post your radio set up and limits on the website?? I'd like to copy them, but good luck finding that post in 100+!!!! We need someone (who is really bored) to index this thread for us!!!!!
Thanks, Mike
Thanks, Mike
#3295
IL
The loop is on the vent line. This is to prevent fuel from coming out the vent on V. down lines.
Wayne - email me the radio setup and I'll post it.
Here are my IMAC modes:
1) Fly around
Aileron - 30%throw and 0% expo
Elevator - 29%throw and 20% expo
Rudder - 45% throw and 40% expo
2) rollers and hammer heads
Rudder - 80% throw and 60% expo
3) snaps
Aileron - 59%throw and 65% expo
Throttle offset - 1%
Rudder to elevator - A = -7%, B = +4%
Rudder to aileron - A = -2%, B = -2%
That's it....
1) Fly around
3) snaps
That's it....
ORIGINAL: DrScoles
Thanks, Mike
Thanks, Mike
#3297
My Feedback: (115)
VA
Does anybody recall how much the header assembly costs from DA? I purchased a used one, and it was being ran on a Comp-ARF 2.3m Extra 330L, but it has like a 15 degree bend at the flange.
I guess I will sell the one I have and get the needed one.
Starting to look good Scott! Just mounted my engine tonight, no I need my header and I should be able to wrap up the engine/muffler install and finish the remainder.
Also included a pic of my lightened Ohio RC Extra 300 with a DA 50!
Thanks for any input guys.
Jon
Jon
#3298
ORIGINAL: Mudsurfer1234
YAY!! It's startin to look like somthin!
I just moved into a new house and have taken priority with the Yak. I still need a back yard, a garage door opener, a work shop, etc. and I DON'T CARE!!! I have set up a card table in the garage and one of the lamps from the house...that will have to do for now
#3299
ORIGINAL: jpa2002
Jon
Jon
Phone: 520.722.0607
OH AND YOU'RE LANDING GEAR ARE ON BACKWARD!!! THEY NEED TO POINT FORWARD!!!
