.60 engine recommendation?
Old 05-03-2011 | 03:11 AM
DarZeelon's Avatar
Default RE: .60 engine recommendation?
ORIGINAL: Altered1
Good to see you say that about the ASP S.52A DarZeelon... I unpacked mine last night .
Altered1,
I believe in giving credit where it is due.
This ASP is an inexpensive and highly under-appreciated engine.
Its clone with the Magnum nameplate has somewhat more credit, but its American importer sells it with a substantial premium.
I've seen it perform. It might be a bit more difficult to adjust, but at a third of the price I am willing to waste a bit more time on it.
However, for the OP, I still think this is not the right engine, because it is too light in weight.
Old 05-03-2011 | 04:42 AM
I have heard of guys using the 2 needle ASP .52 carb to replace the air bleeds on OS.48s. Been thinking of trying that myself.
Edwin
Old 05-04-2011 | 01:23 AM
The S52A I got, I ordered it with a remote needle.  For me, the price was great, and the remote needle was what the clinched the deal.  I'm not that keen putting my fat fingers so close to a screaming prop I can't see!
my application (airboat) is a lot more forgiving when it comes to power.  My boat will not drop out of the sky if the engine is under powered
With 2 kids under 5, on a single income, my hobby budget is a lot lower than I'd like.  So, The ASP hopefully give me the output I need, for the price I can afford.  There will always be a market for the higher priced kit, just as there will always be a market for a budget option.  I'm glad that the budget kit is improving in performance and quality.
Old 05-06-2011 | 07:53 PM
I started the ASP A52SII for the first time this morning....  before the wife asked me to stop    The engine is quieter than my ENYA .60XF, and straight out of the box, she started with minimal effort - I backed out the needlevalve a half turn from factory to make her rich,  primed her up, hooked up the glow, and gave her a very quick turn with the starter.   I've got her so rich she will not transition without the glow driver attached, but I think this engine will be a breeze to run, and very forgiving on the needle settings.
Now, to look for Darzeelon's break in proceedure...
Old 05-06-2011 | 07:59 PM
DarZeelon's Avatar
ORIGINAL: Altered1
Altered1,
[link=http://www.rcuniverse.com/forum/m_1850473/tm.htm]Here[/link] you go.
Follow it, taking no shortcuts.
Old 05-06-2011 | 09:11 PM
  #31
Thanks Dar, found it
Old 05-06-2011 | 09:47 PM
  #32
DarZeelon's Avatar
Altered1,
I just realized that all one needs to do to access this break-in thread, is to click the 'Rating' link at the top of the column.
This thread is right up there, near the top.
Old 05-07-2011 | 05:50 AM
  #33
My Feedback: (14)
And one last time. THERE IS NO FACTORY SETTING!
One should consider the high speed needle valve position a random happenstance and do not depend upon a factory setting to save your engine's bacon, right out of the box. Close the needle valve completely, but softly, and then open to two and a half to three full turns. Better too rich than too lean. I haven't found the low speed needle worth messing with during the first couple of starting tries. They are usually close enough to run, if not run perfectly, on the low end.
Ed Cregger
Old 05-07-2011 | 10:11 AM
  #34
jstrach's Avatar
Inow begin the break-in process on my ST.61 ABC. Iwill fire it up today for the first time, can't wait.
Old 05-07-2011 | 12:28 PM
  #35
jeffie8696's Avatar
My particular Magnum/ASP XL46A wants to load up in the midrange. Idle and top end are good just the midrange. Any ideas?
Old 05-07-2011 | 02:36 PM
  #36
blw's Avatar
blw
Try leaning the low speed even more and see if you have more room for it.
I check my low speed setting by idling for 25-30 seconds and then give it wot.
What plug are you using?
Old 05-07-2011 | 07:38 PM
  #37
My Feedback: (14)
ORIGINAL: jeffie8696
Drop back to 5% nitro and lean the high and low speed needles. The once rich midrange will miraculously lean out and dry up.
Ed Cregger
Old 05-07-2011 | 09:02 PM
  #38
I have not had the rich mid range problem. Funny thing is I use the low cost, budget glow plugs from Hobby People. If after tweaking the needles and it does not go away, try am Enya #3 plug. That is my favorite plug of all time. They are not cheap. For me, I think they work way better then the O.S. plugs.
Buzz.
Old 05-08-2011 | 04:42 AM
  #39
My Feedback: (14)
ORIGINAL: blvdbuzzard
Buzz.
My apology to you. I was referring to jeffie8696's dilemma with the rich midrange.
Like you, I run cheaper plugs in my two-strokes most of the time, saving the higher cost plugs for where they are needed.
Ed Cregger
Old 05-08-2011 | 04:30 PM
  #40
jeffie8696's Avatar
Yea, Ihave some 5% and should have thought of that, I know better. Doh!!
Old 05-08-2011 | 08:32 PM
  #41
jstrach's Avatar
ORIGINAL: jstrach
Holy cow, that new ST.61 ABC is tough when new.It took almost two hands to turn over trying to get it started the first time. We struggled initially, turns out I didn't have enough juice going to the glow plug. Once we got that problem taken care of, the engine fired right up and we ran three tanks through her. Now we'll work on getting some idle adjustments going tomorrow.
