Go Back  RCU Forums > Glow Engines, Gas Engines, Fuel & Mfg Support Forums > Glow Engines
 UMS Evolution Radial Care and Operation >
Old 06-27-2017 | 10:05 AM
  #2226
ID:	2221831Hi Tom , Here's a couple of pics of my Giant Stick with the 7 -77 in it. Flys it nicely . Should have shortened the nose up by an inch or two and it wouldn't have required as much tail weight.
Old 06-27-2017 | 05:00 PM
  #2227
My Feedback: (62)
Wow! best sounding stick.....in the WORLD!
Old 06-28-2017 | 09:08 AM
  #2228
Tom, I will be using 22/12 prop for ground clearance. ..what should I expect?
Old 06-29-2017 | 04:44 AM
  #2229
My Feedback: (62)
Default 22x12
The 7-77 is quite powerful. I am using a 25x12 with great results. How about a 22x12 three blade?
Old 06-29-2017 | 09:06 AM
  #2230
22x12 3 blade prop IF that's the only option....maxim, what would happen with 22x12 2 blade prop? Engine overrev?
3 blade on bi plane not exactly look i was going for...
Old 06-30-2017 | 05:24 AM
  #2231
EQ1
Yes, it will most probably overrev. Why not increase the pitch? This will give you more max. speed, but you could always thottle down. I am using a 24x12 on my Wedell-Williams and the engine is really not impressed of that prop.
Old 07-03-2017 | 03:46 AM
  #2232
Default H9 beaver with the 355cc evolution radial
Hello today I filmed two short flights, I am running a 18x8 fiala propeller @ 7000 rpm, this plane weighs 17.5lbs and the engine powers it just fine.
ID:	2222724   Click image for larger version
Old 07-04-2017 | 04:10 AM
  #2233
My Feedback: (62)
Default Great video!
Nice job Fulcrum. Interesting area where you fly. -Tom
Old 07-04-2017 | 05:05 AM
  #2234
Thanks it is a semi desertic place. This engine sips fuel, I had almost full tank after this flight.
Old 07-06-2017 | 06:36 AM
  #2235
Default Landing and taxi in to pits
Tried putting up a link to a couple of videos but the site wont enable them .
Sorry , will try a different way.
Old 07-11-2017 | 04:46 PM
  #2236
Originally Posted by barzini
Hello,
I'm interested in putting my Evolution 7-77 radial in a Flair Stearman.Does anyone have any thoughts on this combo? The Flair Stearman has an 89" top wing and should weigh around 20 lbs.Any help is appreciated.
Thanks,Tony
My Flair Stearman Evo 7-77 32 lbs.
My Ziroli Corsair Evo 9-99 36 lbs.
Old 07-13-2017 | 05:24 PM
  #2237
My Feedback: (62)
What great video's. I hope these video's are inspiring others to get their radials in the air. I flew one of my 7-77's just the other day. -Tom
Old 07-13-2017 | 06:29 PM
  #2238
Default Love these engines
Yes, just flew both planes at a war bird meet last week went well, kinda considering sending them in for gas conversation, but, don't want to add anymore weight!! On the other hand they run perfectly well as is😁😁
Old 07-13-2017 | 08:41 PM
  #2239
cymaz's Avatar
My 7-77
Old 07-14-2017 | 03:54 AM
  #2240
My Feedback: (62)
I remember that plane! A beautiful picture.
Old 07-15-2017 | 03:52 AM
  #2241
Default 7-77
Originally Posted by cymaz
My 7-77
nice photo shot Cymaz!!
Old 07-15-2017 | 04:11 AM
  #2242
Hi SLSKN,
I'm just starting my Flair Stearman build and will be putting the Evo 7-77 in it.
what size prop are you using?, what works best?
Shaun.
Old 07-15-2017 | 05:04 AM
  #2243
Originally Posted by Raven S
Hi SLSKN,<br />I'm just starting my Flair Stearman build and will be putting the Evo 7-77 in it.<br />what size prop are you using?, what works best?<br />Thanks,<br />Shaun.
<br />Yes a nice kit! I am using a scale Falcon 24x12 prop, engine seems happy with it.
Old 07-15-2017 | 03:41 PM
  #2244
Thanks for that.
The engine should arrive in the next few days, just got a few other questions if that's ok,this will be my first radial.
what fuel are you running, after break in,
is there enough power in reserve for the stearman, I have read a few posts and was a bit worried that there might not be enough power,
last one, is your engine mounted directly to the ply former on the ply tube as standard in the kit build.
thanks for your time,
I'll probably have a few more questions later, would it better to pm you rather than go off thread?
cheers,
shaun.
Old 07-15-2017 | 03:43 PM
  #2245
Sorry forgot to say, your Stearman looks great.
cheers,
shaun.
Old 07-16-2017 | 12:20 PM
  #2246
has anyone shortened exhaust pipe??? If so,how did it change sound? Just louder?
Old 07-16-2017 | 12:21 PM
  #2247
Talking 7-77 radial with exhaust ring above...
Old 07-16-2017 | 12:29 PM
  #2248
Talking 7-77 radial with exhaust ring above...sorry about bold text in above post...
Old 07-18-2017 | 03:34 AM
  #2249
Hello Shaun, Yes I did not build my Stearman, traded it for a T-28 I had, but the guy I got it from had a G-62 in it, I put the 7-77 in it, but had to make a plywood plate for the engine mount, added to the original firewall, the power your asking about is ok, I would say perfect for scale flying, but the airplane is covered with fabric, and is painted with Imeron paint, plus the guy that built it used a lot of plywood, so is heavier than normal, but still fly's very nice, any other help I can give let me know thanks! Oh and the fuel I use is 8% oil and 5% nitro, was making my own, but know using Riches Brew, out of Texas, good fuel especially made for these engines.
Old 07-18-2017 | 04:12 PM
  #2250
Hi slskn,
Thanks for that info,
I have another one for you, how big is the fuel tank and what sort of flight time do you get out of it.
Cheers,
Shaun.
