Welcome to Club SAITO !
Old 08-07-2020, 06:22 PM
  #47176
Glowgeek
Originally Posted by the Wasp View Post
as I remember the Saito 100iT was $1100+
Jim
Love to have one of those for a warbird.
Old 08-08-2020, 12:53 AM
  #47177
Monty Python
Monty Python's Avatar
Originally Posted by Captcrunch44 View Post
he is Australian I’ll have to keep him away for my Saito 125
You'd be mad if you didn't
Dave do you think mas made a mistake moving away from white painted tips? lot of people i know bought them for that reason, they look pretty in flight and nearly indistructable.
Lonnie i've seen a 60 size h9 mustang flown with a 200 ti it sounded awesome. There's someone here struggling to get off the water with high pitch props, do you agree that most 6 pitch props fly most ga planes at scale speed at half throttle to 3/4 ?
Captcrunch44 (08-08-2020)
Old 08-08-2020, 01:51 AM
  #47178
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
I am seriously considering painting them white, I'll certainly share if I do.
Old 08-08-2020, 01:59 AM
  #47179
Glowgeek
Originally Posted by Monty Python View Post
.........................Lonnie i've seen a 60 size h9 mustang flown with a 200 ti it sounded awesome. There's someone here struggling to get off the water with high pitch props, do you agree that most 6 pitch props fly most ga planes at scale speed at half throttle to 3/4 ?
Yeah, love to have a 200ti in a Spit like that vid Jim has posted here a couple of times. Woohoo, hold on to your hat!
Yes, I'd say most scale models of civilian aircraft will fly at scale speed with a 6 pitch prop, as long as the diameter of the prop is large enough to overcome airframe drag and the engine has the nuggets to spin it fast enough.
Old 08-08-2020, 02:33 AM
  #47180
Glowgeek
Whoops, had to reboot the internet.
With WWll warbirds it can be tough to achieve scale speeds, especially when talking about Reno racing speeds. Installing larger than recommended 4 stroke engines and using 8 to 10 pitch props is the norm. Same with drag queens like the P-47, lots of power required.
Dave, once I get my fa180/ 60 size P-47 propped correctly I'm going to dye the apc prop black and add white tips. Are you thinking of using laquer paint for the prop tips?
Old 08-08-2020, 02:49 AM
  #47181
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
Here you go, it will be here Monday.
Old 08-08-2020, 03:02 AM
  #47182
Glowgeek
Ok thanks. Looks like that product is Acrylic Laquer, should be resistant to nitro.
Old 08-08-2020, 03:08 AM
  #47183
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
Product
Automotive Metallic Paint - Acrylic Enamel - Universal Touch Up
You're correct and I didn't know that little detail.
Old 08-08-2020, 11:33 AM
  #47184
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
Interesting Fokker, interesting flight box in a violin case. The Fokker is nearly silent in flight and quite p
owerful.
Old 08-08-2020, 11:37 AM
  #47185
Glowgeek
Looks like you made it to Fredericksburg! Gobs of power with scale looks!
Have fun out there Dave!
Old 08-08-2020, 11:55 AM
  #47186
the Wasp
Lonnie, you like, you shall hear
the Saito 100,,,,,cc
Old 08-08-2020, 12:50 PM
  #47187
FlyerInOKC
FlyerInOKC's Avatar
Since it was hotter than a firecracker today I decide to stay inside. I decided I had enough filling and sanding so I started covering the bottom of wing of Capt. P's new ride and Pinky Saito's new home.
Old 08-08-2020, 01:35 PM
  #47188
Glowgeek
Nice to see Pinky progress.
Old 08-08-2020, 06:14 PM
  #47189
FlyerInOKC
FlyerInOKC's Avatar
So there I was sitting in my beanbag chair eating Cheetos nak....er... wrong story! Get your mind out of the gutter!
I got the top of the wing covered now. I still have a few wrinkles to shrink out but I like to do that later before I apply the decals.. I hope to start covering on the fuselage tomorrow if I can get the throttle finished and the tank plumbed. Manual says you need 2 rolls of covering but I can tell you that it is going to be tight.
Man that pink is bright!.
Old 08-08-2020, 06:43 PM
  #47190
FlyerInOKC
FlyerInOKC's Avatar
OK I had a thought, Gary when you painted this Saito did you clear the nipple on the backplate or do I need to pull it so the excess oil will leak out? Also what kind of paint did you use in case I need to touch it up? Thanks!
Mike
Old 08-09-2020, 03:38 AM
  #47191
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
The next time I see that gent I want to find out what's in the violin case that requires two cooling fans. He flies with that beautiful prop.
Old 08-09-2020, 05:14 AM
  #47192
Captcrunch44
Mike
well mike captcrunch painted the engine yes he plunged the vent.
and he used Krylon.
Old 08-09-2020, 05:43 AM
  #47193
FlyerInOKC
FlyerInOKC's Avatar
Thank you Cap! I will pull the nipple and clear the opening. I have a couple of honey dos before I can get back to work.
Old 08-09-2020, 05:49 AM
  #47194
Captcrunch44
I should say I covered the vent. It should be clear that’s how I oil the engine’s for storage is through that hole.
Old 08-09-2020, 06:44 AM
  #47195
acdii
Nothing better than lubing through a nipple.
Old 08-09-2020, 07:24 AM
  #47196
FlyerInOKC
FlyerInOKC's Avatar
Cool! Ithad so much paint covering the end I thought for sure it was probably closed.
Old 08-09-2020, 10:50 AM
  #47197
Glowgeek
No washout on a hog wing Mike?
Old 08-09-2020, 11:13 AM
  #47198
FlyerInOKC
FlyerInOKC's Avatar
Thank you but that is a Pete N Poke wing not an Astro Hog wing. I received the airplane partially built without the plans but from what I have been able to download in the manual/plans area there is no washout called for. I have been debating one thing so please feel free to chime in. The static struts are non load bearing and just kind of float in slots at both ends. I think the airplane looks better with them so I will keep them. My quandary is should I paint them pink to match the main struts or cover them in red Monokote to match the border going on the tail feathers and some of the decals? What do you think?
Old 08-09-2020, 12:55 PM
  #47199
Glowgeek
Aaaw heck, I'm no good at artsy fartsy stuff. This one looks pretty cool.
Great Planes Pete 'n Poke Build: 2012
Old 08-09-2020, 01:14 PM
  #47200
FlyerInOKC
FlyerInOKC's Avatar
Nice looking airplane but it would look even better with a Saito in it! I'm thinking about making the elevator red/white checkerboard if I have enough it will help the pink go farther.
