Welcome to Club SAITO !
Old 09-09-2023, 05:37 PM
  #54251
Jesse Open
Jesse Open's Avatar
Yep, just like I said
If a servo responds directly to my inputs, faithfully responding to position quickly, with fine resolution, it will be just as smooth as I want it.
Old 09-09-2023, 06:34 PM
  #54252
the Wasp
Garry, what you need is a Heli Gyro servo. they really snap to it.
Jim
Old 09-09-2023, 07:19 PM
  #54253
Jesse Open
Jesse Open's Avatar
Hey Jim,
I may just give them a try. Sounds about right.
Old 09-09-2023, 07:49 PM
  #54254
Kenki
So I played around with the engine today, and after taking your advice, the engine is running much better. I backed out the LSN to about flush as the first responder mentioned, then adjusted the HSN, and got to around 9000, backed that out to about 8500 to be safe, the engine is not fully broken in yet, 4 8oz tanks run through following Saito's instructions. The rest of the break in will occur in the the air, and I would like to avoid dead sticks where possible.
After getting the HSN at peak, I went back to the low end, and was able to get a good idle around 2800 RPM, I am hoping this will come down after more break in.
I then had to change the linkage for the proper idle position, and setup the throttle cut on my radio. I am looking forward to doing my maiden flight tomorrow at our field.
Thanks again for all the help.
Old 09-10-2023, 02:34 AM
  #54255
1200SportsterRider
1200SportsterRider's Avatar
Originally Posted by Jesse Open
Hey Jim,
Like this
[Stall Torque] 21.4kgs (6.6V) / 26.4kgs (7.4V) / 30.0kgs (8.4V)kg・cm 297.6oz (6.6V) / 367.0oz (7.4V) / 416.6oz (8.4V)oz・in [Speed] 0.14 (6.6V) / 0.11 (7.4V) / 0.10 (8.4V) Sec/60° [Weight] 60.0 g / 2.12 oz [diemension] 40 x 20 x 39.3 mm [Length of lead harness] 300mm [Operating Voltage] 4.5V - 8.5V
Old 09-10-2023, 02:57 AM
  #54256
Glowgeek
That servo is a dandy, Dave. All that's left now is to find an engine that will spool up that fast with any kind of usable prop.
Old 09-10-2023, 03:21 AM
  #54257
Glowgeek
You're certainly getting there, Kenki.
What happens when you attempt to idle below 2800?
If it just suddenly quits then richen the LSN a touch. If it slowly drops in rpm and quits then lean the LSN. The objective with gassers is to adjust the LSN mixture for the lowest reliable idle with the smallest throttle opening possible. Once broken in and needles properly adjusted your FG will be able to idle indefinitely.
Additionally, gassers will run VERY very rich without quitting but will quit in an instant if allowed to run too lean.
Kenki (09-10-2023)
Old 09-10-2023, 04:59 AM
  #54258
Jesse Open
Jesse Open's Avatar
The methanol engines are very brisk at transition. Higher specific output and broader mixture tolerance range contribute to that quality. Very pleased with that part.
As long as the engine isn't waiting for the throttle I know the lag is very small. I avoid intentionally adding to response time.
Old 09-10-2023, 05:22 AM
  #54259
Glowgeek
Easy enough to check if response time is compromised. I rev the engine while watching the throttle arm and observe which happens first, engine reaching peak rpm or servo reaching full travel. So far I haven't needed a servo faster than .25 sec/60°. Not even on glow engines.
Old 09-10-2023, 05:36 AM
  #54260
Jesse Open
Jesse Open's Avatar
Thanks for yet another "tip". Been there, got the shirt.
I am all set.
Old 09-10-2023, 05:57 AM
  #54261
Glowgeek
Tips are for whoever comes along to read the thread. Many find it valuable information, I know I did just starting out in RC.
Old 09-10-2023, 06:00 AM
  #54262
Glowgeek
Now I need a tip.
I have an exposed rocker 30 with a very slight twist in the con rod. Should I use heat while straightening it, or not? If yes, how much heat?
Old 09-10-2023, 06:09 AM
  #54263
Jesse Open
Jesse Open's Avatar
Originally Posted by Glowgeek
Tips are for however comes along to read the thread. Many find it valuable information, I know I did just starting out in RC.
Exactly,
As with pointing out certain desirable features with gear pullers, tachometers, engine stands, oil , fuel, exhaust thread sealants, etc etc etc
Old 09-10-2023, 09:54 AM
  #54264
Glowgeek
Exactly,
As have I, on all those topics etc etc, but only to get trampled on almost every time I make a suggestion or offer a tip. Sadly, even when the suggestions are personal preference and appropriate, attempts are consistently made to discredit them. Not all of us behave that way, thank goodness.
Old 09-10-2023, 12:55 PM
  #54265
Jesse Open
Jesse Open's Avatar
LOL,
Yes, I know exactly how you feel.
Old 09-11-2023, 02:51 PM
  #54266
kmeyers
kmeyers's Avatar
If you guys are gonna start crying I'm not inviting you to my birthday party! Great cake and ice cream. After that we play with my Saito 100 I oiled and put in a plastic bag 15 years ago.
Tips? Remember this is the internet. What fun would it be without those that trample.
I really do have that 100. What to do with it?
Old 09-11-2023, 03:29 PM
  #54267
Jesse Open
Jesse Open's Avatar
Default Oil for the gasser
Dave,
You are probably getting close to putting the LT-40 aloft.
I see Amazon has the suggested Motul Oil for your new gasser on hand. I have bought the Motul Micro 2T from Amazon, came here the next day.
Let us know how she handles!
Old 09-14-2023, 12:21 PM
  #54268
1200SportsterRider
[QUOTE=Jesse Open;12783080]Dave,
Let us know how she handles![/QUOTE ]I'll be back
Old 09-14-2023, 12:30 PM
  #54269
1200SportsterRider
Gary, I already bought RedLine and Mixed up a gallon of 20 to 1 for the FG 11 and a gallon of 35 to 1 for the Stinger 10cc. Thanks
More Stinger 10CC over at the Gas Engines Forum
Old 09-15-2023, 02:42 AM
  #54270
1200SportsterRider
This little engine is really loud, shown here is a Mac's Tuned, Quiet pipe that I use on Saito from 125 down. I used a suggestion made by Lonnie, I flipped the carb over because the needles were impossible to reach on the PSP in the stock position, that in turn called for flipping the throttle lever. Whew. I have a cardiology appointment this AM and Geri is sick so I take her to a Dr. this PM. The 90 degree pipe is a Mac's tuned pipe header for a Webra 91, I hacked the phlange off of it and made it round at the engine end. I don't think the recommended 1.5 turns out from closed is a good setting for the needles, it will only run about 5 seconds then quits.
Old 09-16-2023, 02:54 AM
  #54271
1200SportsterRider
I am building another FA 30-s(H) from spare parts, I back ordered a crankshaft from MacGregor's for $46.39 USD, at Horizon it is $89.80, the shipping is almost the same at each. Something is really out of kelter.
Saito FA 30-s(H) crankshaft.
Old 09-17-2023, 10:10 AM
  #54272
Jesse Open
Jesse Open's Avatar
Dave,
Is this the oil you are using?
Have you seen it anywhere lately for less than $100 per gallon?
https://www.amazon.com/Red-Line-40605-2-Stroke-Gallon/dp/B000LNEG8S/ref=mp_s_a_1_3?crid=23AALT8ZYB24I&keywords=redline+two+stroke+oil&qid=1694974039&sprefix=redline+two%2Caps%2C186&sr=8-3
Old 09-17-2023, 10:39 AM
  #54273
1200SportsterRider
Yes sir, this size.
Old 09-17-2023, 12:01 PM
  #54274
kmeyers
kmeyers's Avatar
That does not look like a 4 stroke crank.
Old 09-17-2023, 01:07 PM
  #54275
Jesse Open
Jesse Open's Avatar
Hmm, why not?
It appears to have the drive pin for a crank mounted timing pinion.
