Welcome to Club SAITO !
Old 11-24-2005, 07:49 AM
  #901
N1EDM
Default RE: Welcome to Club SAITO !
Dave, thanks for the note. Sent pm. Haven't changed the email address.
Happy Thanksgiving everyone.
Now back to discussing Saito's! Sadly, one area to check when planning to fit an engine into a project is the length of the engine. I had a 100GK ready to go into a Scale project. Unfortunately, it was about 5mm too long to fit under the cowl... Keep the length of the engines in mind when you plan an enclosed engine installation. I'll have to see if a 91 is shorter, but I don't think it will fit either.
Bob
Old 11-24-2005, 08:49 AM
  #902
jlkonn
jlkonn's Avatar
Bill and everyone,
The rear bearing recently failed on my Saito 1.00.
While I'm waiting to hear from Horizon I've been thinking...
Am I doing the wrong thing the way I store the plane it's on?
I take the wing off and hang the fuselage by the tail on the garage wall.
This hangs it nose down with the engine draining itself in to the crank bearings.
Is this bad?
Thanks!
JLK
Old 11-24-2005, 09:12 AM
  #903
gjeffers
gjeffers's Avatar
what fuel are yu using JK, has it castor in it?
Old 11-24-2005, 10:18 AM
  #904
jlkonn
jlkonn's Avatar
Gary,
I am using Sig 25% Nitro, 50%castro/50%synthetic
JLK
Old 11-24-2005, 11:19 AM
  #905
gjeffers
gjeffers's Avatar
does sig have at least 18% oil John, other than that all i do is make sure i run the engine dry at the end of each session and put in a good amount of air tool oil through the crank vent and spin the prop a bunch to distribute and store with the plane sitting on my workbench upright(engine inverted),i also spin the prop each time i walk by
hope this helps
good luck!!
Old 11-24-2005, 11:44 AM
  #906
jlkonn
jlkonn's Avatar
Gary,
Yes, the jug says oil content 20%.
I wonder if I shouldn't remove the engine when I think I won't be flying for a couple weeks.
It's hard to tell since we just moved here and I'd hate to miss the occaional nice day this winter.
The previous 3 years we lived in Lincoln, Nebraska.
I remember last Christmas Day it was the warmest place in the country.
60 something degrees!
Of course I hadn't started back flying then.
I have started going thru my 2 strokes from 20 something years ago.
Bill has put me on to some great sources for rings and bearings.
I just finished one and after I tested it I ran it on several shots of WD40 then loaded it up with Marvel Mystery Oil.
The Saito would be a lot more trouble to get the cowl off each time and get MMO into the intake, breather and rockers. It may come to that though.
JLK
Old 11-24-2005, 12:28 PM
  #907
Kmot
My Feedback: (24)
Kmot's Avatar
ORIGINAL: William Robison
Tom:
As all the late valves I've bought are already installed in engines, and I didn't want to strip one to measure the groove, I hope you will forgive me for measuring the collet (from a spare set of springs) instead. Haw. The collet is 1.5 mm thick where it goes into the groove.
Thanks Bill, now can you measure the ID of the two collets? Haw!
You have a $300 engine, why fuss about the cost of a set of valves?
Oh, I don't fuss about the cost. I just like the challenge!
with the upgrade on the retainers the clips are no longer supplied.
You're kidding! You mean to tell me standard metric c-clips won't fit?
I suspect also that at least part of the "Gumming" of your valve stems was the hammered ridge. Now that everything is cleaned up
Whoa! Wait till I get around to cleaning it, lol...
Old 11-24-2005, 12:49 PM
  #908
MAAC
Hi Guys
No offense but I am getting too many emails from this site.
I only want to get replies to my posted questions. Not an email every time someone posts something. How do I change this. Can not seem to figure it out. And while I'm at it why can one not start a completely new thread? All other forum I belong to allow this?
Cheers
Old 11-24-2005, 12:53 PM
  #909
canadagoose
canadagoose's Avatar
Easy, up top underneath the yellow menu and where it says you're logged in, click on 'Remove Subscription'
Old 11-24-2005, 01:05 PM
  #910
iflynething
How long did it take for this thread to reach 36 pages?? I'm thinking not too long!!
So much information. Seems like everytime I come back to check up on it, there are 1-2 more pages I have to read, and enjoy doing!!
~Michael~
Old 11-24-2005, 01:11 PM
  #911
w8ye
My Feedback: (16)
w8ye's Avatar
About 12 1/3 pages per month average. It went a lot faster in the beginning.
Old 11-24-2005, 01:22 PM
  #912
iflynething
WOW.....that's intersting.
I have a question, what is better for 4-stroke engines. I guess I should say what is better for SAITO engines. Castor, Synthetic, or a mixture of both. I run Coolpower 15% 18% lube. Used to run Byron 10-15%. What's better, and why. Why isn't the other one good?
~Michael~
Old 11-24-2005, 01:27 PM
  #913
canadagoose
Hi Guys
or click on settings in the yellow menu and under subscription preferences, click 'Notify me once per thread until I visit the thread again' or 'Notify me once per thread until I visit the thread again or until I visit the board the next time' i don't think you can get notified to just you're questions or replies.
Old 11-24-2005, 02:06 PM
  #914
slim56
Just bought my first Saito (100) going on an Ultra Stick. What do I do with the breather nipple in the back plate? I thought that this was a simple pressurized system. I would like to fly this tomorrow if anybody could help me on this Thanksgiving Day I would be grateful.
Happy Thanksgiving,
Anaconda
Old 11-24-2005, 04:35 PM
  #915
Ernie Misner
Ernie Misner's Avatar
Interesting about the 50 Hobbsy. What year did they make those? Same size as the more popular 56?
Ernie
Old 11-24-2005, 04:52 PM
  #916
William Robison
anaconda:
Just put a length of fuel hose on the back plate nipple and run it down and out. The excess engine oil will blow out of it.
Next time I open the listing I'll add your name.
Bill.
Old 11-24-2005, 06:31 PM
  #917
blkmesa
My Feedback: (21)
I love Saito engines. I have 16 engines but much to my dismay only 4 of them are Saito's. I will be thinning out my inventory and investing in more of them.
Old 11-24-2005, 07:13 PM
  #918
blkmesa
My Feedback: (21)
I think that I just joind club Saito. I'm on page 36 but how do I find out what number I'am ?
Old 11-24-2005, 07:20 PM
  #919
William Robison
blkmesa:
You and anaconda are in, but not yet on the list. Later this evening I'll add you two. In the meantime you can see the list [link=http://www.rcuniverse.com/forum/m_3306814/mpage_27/key_/tm.htm]here[/link].
When I addd your names they will show there. Post 657 is numeric order, #658 is alohabetic.
Bill.
Old 11-24-2005, 07:41 PM
  #920
William Robison
Last entries:
128 anaconda
129 blkmesa
Bill.
Old 11-24-2005, 08:25 PM
  #921
w8ye
My Feedback: (16)
w8ye's Avatar
The Saito 50 is basically the same exterior size as the 56. Saito still makes them but Horizon quit selling them last year. I think they came out around 96 or 97? The 50 has the same stroke as the 56 but the 56 has the same bore as the 65.
Old 11-24-2005, 08:51 PM
  #922
SigMan
My Feedback: (21)
SigMan's Avatar
WOW! i cant believe my thread is still going and has gotten this much attention, but im happy it has....guess there are lotsa saito lovers besides me...lol![sm=sunsmiley.gif]
Old 11-24-2005, 10:56 PM
  #923
fredscz
My Feedback: (47)
I would like to apply for membership in "Club Saito". I'm currently flying 6 with 7 more in reserve. If I qualify I would like to join under the name Fred B. I have an '82 that pulls a 14x6apc about the same as my '91 but I think the 91 is my all around favorite.
FEB
Old 11-25-2005, 10:04 AM
  #924
blkmesa
My Feedback: (21)
Thank you Bill. Everybody need's a number now day's.
Old 11-25-2005, 01:41 PM
  #925
Genesis_twin
ORIGINAL: Kmot
Genesis, that is totally awesome!
How did you attach the CPU fan to it? I might need to do the same with the FA40 I want to put into a boat.
-Tom
Thanks Tom,
Sorry for the late reply. I simply JB-welded the fan and a spacer made from the "nose cone" of another fan to the back of the flywheel. Make sure to roughen the surfaces.
