Go Back  RCU Forums > RC Airplanes > Golden Age, Vintage & Antique RC
Reload this Page >
Bud Nosen Mr. mulligan
Golden Age, Vintage & Antique RC Want to discuss some of those from the golden age, vintage rc planes or even an old classic antique vintage rc planes, radios, engines, etc? This is the place for you. Enjoy!
Old 09-26-2014, 03:54 PM
  #326
flyingagin
flyingagin's Avatar
Now I remember about the aluminum 90's. Yep I am with ya on this on Steve and will be interested in seeing it
I am hoping to try to get some CL flying in next week, Just a 2 or 3 flights. Charging batteries right now. I am having to punt on the TX battery It puffed since when do LIFE batteries puff?
Yeah I said TX and CL. I use 2.4 for throttle. If I get the dizzies I can land. Ringmaster Flython next weekend. I want to test my body a bit.
Ken
Old 09-27-2014, 02:42 AM
  #327
TomCrump
TomCrump's Avatar
Your wing looks great, Steve. I wish that mine were that far along.
The wingtip design looks good, too. It should hold up well.
Old 09-27-2014, 02:45 AM
  #328
stevegauth30
stevegauth30's Avatar
Thank you Tom. Means a lot coming from you. For some reason, for a simple wing it was a lot of work. Hopefully the other side will be a bit easier now that I've done it once.
Old 09-27-2014, 02:56 AM
  #329
TomCrump
TomCrump's Avatar
I have both of mine at similar points, but not nearly as far along as yours. I need to mount them to the center section, so that I can install the wig tube sockets. After that, I can sheet the bottom of the wing panels.
Your second panel should frame up quickly.
Old 09-27-2014, 02:59 AM
  #330
stevegauth30
Oh. I thought your wings were done sheeted. I need to check and see when I ordered my tube and socket. Hopefully they come some time this coming week. Right now I'm working on getting the speedster back in the air.
Old 09-27-2014, 03:03 AM
  #331
TomCrump
TomCrump's Avatar
My wings are a monoque design. Without sheeting, the are pretty flimsy. The spars are 1/8X1/4" balsa. Without some sheeting, I couldn't remove the wings from the building board. LOL
Old 09-27-2014, 03:07 AM
  #332
stevegauth30
Gotcha. Kind of like building a house. A light breeze can blow it over till the plywood go's on. Then it's rock solid.
Old 09-27-2014, 03:15 AM
  #333
stevegauth30
Not sure if I told you about my last flight with the Rearwin. Was getting toward the end of the flight. I pulled the stick back to settle into a nice approach, and the engine wouldn't throttle down. I had throttle control from about half to full, but nothing below half. I did a few patterns at half throttle trying to get it to come down, but at half throttle, she wants to climb. No luck. So I went around for a real wide approach, and made sure I was set up as good as possible, and killed the ignition. Brought it in for a perfect three point dead stick. When I looked, I saw the broken mount on the opposite side of the throttle so when I pulled the stick back, it actually would pull the whole engine. Whew, close call.
Old 09-27-2014, 03:22 AM
  #334
TomCrump
TomCrump's Avatar
I think that you did mention the landing, but not the cause of the problem.
I'm glad that you had a successful result. Flying out a tank of gas isn't much fun.
Old 09-27-2014, 03:27 AM
  #335
stevegauth30
This thing is a hog, so not much different than any other flight. But I used to cram the biggest tank I could until I had to fly around for 40 minutes one time. Learned two lessons on that one. Not such a big tank, and make sure to have a kill switch or throttle cut of some type. Although, you loose the throttle servo and the throttle cut switch is useless.
Old 09-27-2014, 04:37 AM
  #336
flyingagin
flyingagin's Avatar
You both are making good progress. I enjoy watching other builds, more relaxing than my own maybe.
Ken
Old 09-27-2014, 05:45 AM
  #337
stevegauth30
Thanks Ken. I sprung for the good wheels with the aluminum hubs. These feel pretty stiff too, so maybe not too much bounce. Well see.
Old 09-29-2014, 11:33 AM
  #338
FlyerInOKC
FlyerInOKC's Avatar
Off topic I was speaking with the owner of my local hobby shop and he got some spar glow plugs in for that new 15cc OS engine that runs on gasoline but runs on a glow plug without an ignition setup. He took one of them and stuck it in on old Weber .61 and she ran great even the idle perfect. The only difference he noticed was a little lower RPM at full throttle, he loss about 200 RPM. He plans on trying it with a 4 cycle engine tomorrow. I may just try converting a few engines myself. He used a 40-1 ratio on the fuel but his feeling is he would want to increase to 20-1 for engines without bearings.
Mike
Old 09-29-2014, 11:51 AM
  #339
FlyerInOKC
FlyerInOKC's Avatar
CORRECTION My CRS kicked in again! He tested the gasoline glow plug with a K&B and not a Weber!
Old 09-29-2014, 01:10 PM
  #340
stevegauth30
But he ran gasolene through it? Pretty interesting.
Old 09-29-2014, 02:05 PM
  #341
flyingagin
flyingagin's Avatar
Norvel has a .40 that runs gas/oil (14% castor). Uses a p5 plug and ceramic cyl,and very high compression. It is lighter than most .40s and even though gas not glow is as strong or stronger.
Thread http://www.rcuniverse.com/forum/glow...ow-engine.html
Ken
Old 09-30-2014, 05:43 AM
  #342
FlyerInOKC
FlyerInOKC's Avatar
Originally Posted by stevegauth30
But he ran gasoline through it? Pretty interesting.
Yes, and the only modification for an existing glow engine is to use this new glow plug and replace the tank plug & fuel lines to gasoline compatible. As I understand it OS has come up with an alloy for the coil that remains glowing in the presence of gasoline like Platinum does in the presence of alcohol fuel.
Old 10-01-2014, 01:38 AM
  #343
TomCrump
TomCrump's Avatar
A friend sent me this link. It may be of interest. http://www.ebay.com/itm/IKON-NWSTS-M...item3f3ded2d49
Old 10-01-2014, 01:49 AM
  #344
stevegauth30
I saw this last night. I'm thinking I've got my hands full with the Mulligan I already have. Although, I do want to build an IKON kit. Hopefully getting back to work on the other wing panel today. Hope my wing tube shows up soon as well. How's the Vega coming?
Old 10-01-2014, 02:44 AM
  #345
TomCrump
TomCrump's Avatar
The Vega is on a temporary hold.
I'd like to get my 20+ year old IKON Stinson running/flying this year. I got it's Saito twin to fire, but it wouldn't stay running. I also seem to be having binding problems with my radio.
I should get a handle on it this week, then get back to the Vega,
Old 10-01-2014, 02:46 AM
  #346
stevegauth30
Nice. Has said Stinson ever flown? You built it 20+ years ago? Pics?
Old 10-01-2014, 02:53 AM
  #347
stevegauth30
Yeah, I also took a break to get the speedster back in the air. She's just about done, and then I wound up assembling another flippy floppy arf. I know, I never learn. Flip flippers are for guys who can actually fly them. Work should commence on Mr. M again today as I'm finishing up the arf as we speak.
Old 10-01-2014, 03:02 AM
  #348
TomCrump
TomCrump's Avatar
She hasn't flown in years, but she has flown.
ID:	2036494   Click image for larger version
ID:	2036495   Click image for larger version
Old 10-01-2014, 03:05 AM
  #349
stevegauth30
Well, good luck with it. I hope she treats you well. I'd love to see a pic once it's flight ready.
Old 10-01-2014, 03:15 AM
  #350
stevegauth30
Oops. Never mind. Didn't notice you already posted pics.looks great.
