WACO YMF
#6954
RE: WACO YMF
John.
Thank you for posting the picture.
Dan. yes you are right, we have come a long way since those days, today the mail is a very lucrative bussiness for the airlines, so much, that if need be, a passenger may be denied boarding in order to get the mail on board.
I wanted to enlarge the picture but could not even do that, some tning has happened with my computer, I have had to re register with all the web sites I usually visit, I think my wife did it.
Angel
Angel
#6955
RE: WACO YMF
ORIGINAL: mrdhud
stickbuilder,
Bill, did you ever think when you made your first post back in March of 2006 it would be what it is today. My hats off to you, this has to be the fasted growing form on the internet. Thanks to you I’m enjoying many many many days and night building on my Waco.
stickbuilder,
You never hope for anything to be that successful. It was not my doing, or my influence though. This topic came about at the right time and in regard to the right airplane. The enjoyment that you and the rest of us are having with this thread is due to the efforts of all the members of the Brotherhood. I just happened to be the lucky stiff that made the first post. My hat is off to all the Brothers.
Bill, AMA 4720
WACO Brotherhood #1
#6956
My Feedback: (126)
NY
RE: WACO YMF
well lets see if I can get some pics up here not as scale as you more talented builders but it is a sport scale plane for me will do a better one next time here goes flys very nice on the g-26 , 16 x8 prop will go to 18 x6 to try and slow her down on landings , wheel pants & wind screen in the works now that she flys.
#6957
My Feedback: (48)
RE: WACO YMF
Lazyace
Vary good looking Waco you have there. Must be a great feeling after a successful flight.
All
Does any one know if Gary at getstencels is still in businesses? I can’t pull up his web sight for some reason. I would like to get the pinking tape from him I understand he can cut it from solortex
SuperCubMan
I know you used the silver solortex what did you do for your pinking tape?
All
SuperCubMan
#6958
MD
RE: WACO YMF
The owner is Gary Sibert. Call him in the evenings at 540 667 2877
Email [email protected]
Trlamb
Brotherhood# 69
Trlamb
Brotherhood# 69
#6959
RE: WACO YMF
I bought my tape from Gary a couple months ago, it does appear his site is down. He told me he was getting out of the stencil business but was going to continue marketing the tape.
Anthony
Anthony
#6960
ON, CANADA
RE: WACO YMF
I used Gary's pinking tape which he cut out of silver Solartex and I used "Rib Stitching" from Scale Rib Stitch - http://home.cablerocket.com/~scaleribstitch/index.htm I also bought a complete set of stencils from Gary, but I had a h..l of a time using them on the cowl. So I washed the cowl off and I scrapped them and instead I opted to have them cut from vinyl. Although there is a little wrinkling, they look OK from 3 ft.!! The blisters on the FG cowl we use are not round, but have been made oval. Thus it is very difficult to get a good fit except by painting them on, which I don't have the ability to do as good as I wanted!! I also used red 1/16" tape to outline everything except the cowl crabs and the wheel pants which were just too small. I have the Fuse crab and the letters done in two colour vinyl as they would be too difficult to outline at this size. I could have done it but I just know that the tiny bits and pieces would be peeling off from the oil after the first few flights.
Have made arrangements to take the plane up to the local airport here in St. Catharines, where the plane I'm modeling is hangered. The owner Peter Ramm wants photos of the two together!! I'll post them when they're done.
#6962
IN
RE: WACO YMF
Jim,
I cut Clam shells in two sizes then put the smaller over the larger. this gives a stripe all around. same for the blisters. i had to hand cut could not get anyony to cut vinyl for me. used covering and ironed them on,,,
#6963
ON, CANADA
RE: WACO YMF
Thanks Tony. I was aware of that method but didn't think of using covering to do the job! I presume you used film for the job. I see you had the same problem I was presented with in that the front of the blisters were made oval in the model cowl rather than round as in the full scale job. Not a complaint because we wouldn't have had these great cowls without the fine efforts of Jay! As a result however, to simulate the roundness of the real thing we either do as you did, or as I did (see photo), by having the round front of the crab spread over onto the flat part of the cowl. Either way they look good from 3 feet away and few will get any closer! Using vinyl, a double layer would be too thick to form around the blister, so I opted to ignore the red trim in that area.
At a later date, if the model flies really well, I may change my mind and try alternate methods of applying the trim to the cowl and pants to get the full scale effect. But for now it's on to the photos and then the maiden!!
#6964
My Feedback: (48)
RE: WACO YMF
trlamb
Thanks for Gary phone # I will call him this evening and order the tape.
SuperCubman
Where did you get your vinyl cut for your strips & blister decals? I have a place local I get vinyl lettering cut but with out a pattern I don’t know he can cut the other.
Can’t wait to see your Waco finished. Can you tell me how you simulated your front cock pit? It looks really good.
All
I really enjoy looking at every ones finished planes. I have copped and pasted most of them to a folder and go back to them from time to time. The last thing I wont to do is step out of line but I was wondering what you would think of having a web page with every ones finished photos on. It’s just an idea I had.
SuperCubman
All
#6965
ON, CANADA
RE: WACO YMF
Hi Dan. Quite easy really. I used the same thing on my Skybolt (sob, sob!) I simply get the outside shape of the cockpit and trim 1/4" off the outside. I then glue black neoprene tubing all around the outside of the shape, flush with the trimmed edge. I then get some leather or simulated leather in the desired colour and wrap the form carefully leaving the material 1/2" larger. Then I carefully make a 1/4" seam around the outside by folding the material on itself and adhereing it with contact cement making sure the material folds neatly without any corners. I then glue the whole mess in position on the fuse. I stick nicely spaced pins through the outside 1/4" of material into the fuse where I put a drop of CA on the pin inside the fuse and cut it flush with the inside of the fuse.
The effect is that the tubing under the material looks like the combing of the covered cockpit and the pins simulate the fasteners holding the cover in place. If you want to cut a hole under the cover so it sinks in a little in the middle, go ahead. I like keeping the fuse strong in this area unless one builds support into the fuse structure to reinforce another cockpit opening.
If this needs more explanation - let me know and I'll try to draw a pix! The operative word here is try!
#6966
RE: WACO YMF
Perfect timing on the topic,
I am finishing my cowling on my 1/4 scale now, I used frisket paper to make mask for each bump and I am trimming it out with 1/16" 3M automotive pin stripe tape. The tape will make very tight turns without any issues, I would think it would work for 1/5 scale also. Here is a pic of my cowl, you can see the bumps to the left have been trimmed and the ones on the right are ready to be trimmed. The stripes really finish it off nice.
Anthony
Anthony
#6967
RE: WACO YMF
ORIGINAL: WacoNut
Thanks in advance for the advice.
old git - - - - aka John L.
Waco Brotherhood No. 14.
#6968
MD
RE: WACO YMF
Dan
Here is who I have used. Denny has all the stuff for the 33 and I am sure he can make them for the 1/4 and 1/5
He does great work and on time
TR
brotherhood # 69
http://www.cajunrc.com/Cajun_Graphic...cial/index.htm
TR
brotherhood # 69
#6969
RE: WACO YMF
ORIGINAL: old git
That cowl is a superb job. Some time back I had advice from Bill (stickbuilder) on a similar cowl and already have the pinstriping tape. What however is FRISKET PAPER?
Thanks!!!
Frisket paper is used for making mask for air brushing. You can get it at a good art supply store, it's about $10 for a package of 6 sheets.
Anthony
ORIGINAL: WacoNut
Thanks!!!
Anthony
#6970
ON, CANADA
RE: WACO YMF
ORIGINAL: mrdhud
SuperCubman
SuperCubman
I get all my vinyl cut by Doug Field who owns my "local" hobby shop "Field's Hobby Center" in Buffalo http://www.bizingo.com/m/Fields%20Hobby/
He does a great job - very fast - and he charges very little!
#6971
RE: WACO YMF
ORIGINAL: mrdhud
All
All
I don't have a finished WACO to say yes or no on this. But, I too have often thought that would be a neat deal to have a collection of the Brotherhood WACO's all in one place on the web. Would be cool.
#6972
RE: WACO YMF
ORIGINAL: SuperCub Man
If you have posted pic's of your WACO finished I missed them some how. I sure hope you can post a few of it sitting with the full scale as well. Sure is looking good.
#6973
RE: WACO YMF
ORIGINAL: mrdhud
All
All
Bill, AMA 4720
WACO Brotherhood #1
#6975
My Feedback: (35)
ID
RE: WACO YMF
Hey guys:
Wanted you to know I have a 1/5 Scale Waco listed here on RCU. Excellent condition - parts have never been removed from the box.
This is the third try. I hope there not showing up somewhere else!
