axe cp thread
#1577
All the posts I've read sum up that the Axe's tail won't track straight into a loop with the stock 3-1 board. Most people are using the Axe as learning tool. My take is that you'll probably "graduate" to a different, maybe more capable heli when it comes to time to learn inverted flight, 3D etc.
I'm in the process of upgrading to brushless. I wish I could give more feedback to you about going brushless. Keep up the good work without training gear. Are you flying in all perspectives: tail out, 90 degree, 45 degree angles and pirouettes?
#1578
I have but a query...? Can we use the eflite charger for the suggested lipo from great planes (electrfly 910mah)....? I would like to use the eflite 800mah 11.1 v but apparently you only get 8 mins run time. So if I understand correctly you would get about 9 mins with the 910mah right,...? Ive never asked this question before.
Or what about 10.8v @ 1000mah...about 10 mins run time...?
#1579
douglas4-
The eflite charger should work just fine for your electrifly 3S910mAh battery pack. The eflite 3S800mAh is just a little on the "light side" for operating the Axe. Do you happen to know if the eflite battery is a 10C or a 15C pack? Your estimates are probably close on the hover time. The 10.8V - 1000mAh is a NimH pack? If so, it will be substancially heavier than a comparable Li-Poly and probably won't work as well as you would probably like.
#1580
douglas4-
You may have to check the connector on the eflite charger. The Electrifly 910mAh packs use Dean's Ultra Plugs. I like the Ultra Plugs. It would be an easy swap on the charger.
#1581
Been out of the loop for a bit..House remodel. Anyway, anyone have any pics of different canopies. The stock one is not so cool. I'm thinking huey style etc. If anyone has any links or photos to get me on the right track, it would be great
AZ
If any of you are good at setting up swash plates heres a question.
I was checking the old throws on my axe cp that the original stock radio set up would produce in full cyclic (any direction) so that i could emulate them with my 9C and I came up with 13 degrees measured with a pitch gauge on the main, flybar level and looking at the swash itself? Oh and this was in idle up mode with the throttle/pitch stick at center (if it even matters). I thought the general rule of thought for swash tilt was like 6 to 8 degrees. Is this because it has only a hiller head, and at the lower setting would no be as responsive? Seems a bit extreem to me.
#1583
#1584
TO: Missle
Heres the link to the company who makes custom r/c packs. They are actually lighter than the stock batterys. Its the 1000 mah 10.8v block packs Im gonna buy. Im sending them one of my stock packs that is a dunger to use for making my custom packs. http://www.onlybatterypacks.com/items.asp?db=31
#1585
TO: Missle
I checked out the link you provided. Be cautious of the cells making up these packs. They have a discharge rate of 3 amps (3C in this case). The stock Axe set up (brushed motors) will draw approximately 7 to 8 amps - well over twice the amperage these batteries are designed for. I don't recommend you experimenting with http://www.onlybatterypacks.com/items.asp?db=31, could be a bad scenario... Sorry for the bad news. [&o]
#1586
ME
I have what I think is a pretty basic question, but is still unknown by this relative newbie. In allthe different R/C helis out there of different shapes and sizes, I've noticed something that seems to not be unique to any particular type - the location of the flybar. Why are some above and some below the main rotors? Is it similar to the difference between a wing-over plane and a wing under one?
Thanks.
Thanks.
#1587
#1588
ORIGINAL: dfalcon
Get some lipo's. Thunder Power 1320's weigh a little less than the stock battery and are lasting a little more than twice as long. I also have a 1100mAh PolyQuest battery that I use in the Axe, and by the time I'm done with all three batteries, my nerves are shot and it's time for a break anyway.
For field charging, I keep a small, lead-acid lawn tractor/atv/motorcycle battery. It'll charge about 20 batteries before it needs recharging itself.
I makes no sense for me to drive 10 miles only to fly for 5 minutes.
What is "a little more than twice as long?" These stock ones are good for about 5 minutes tops.
#1589
ORIGINAL: HelisRule
Thanks.
Thanks.
Read This link below , May help a tad as how the real ones work. I never liked details and more like a laymans term type guy. Basically it stabilizes the entire rotor system whenever you make any type of input into the sytem. (Keeps it as level as possible) Since cyclic and collective is a constant application-there you have it.
http://www.aircav.com/huey/stabiliz.html
#1591
Heres my little beast. Only 3 days old!
You may or may not notice the main rotor gear exposed more. Seems to have been rubbing on the fuselage, so I got the dremel out and rounded off some area to keep it from happening again. This is actually the purple one. The flash made it look blue
#1593
NC
just got my new axe cp i really like it never flown a heli really before except for a blade cx2 which is not real hard to fly this is a whole new ballgame just wondering if there is anything to do to make it not so responsive for now already need new blade grips just a few more questions - flat or sym. blades? - has anyone had to adj. the settings on the board before flight?(don't know exactly if i am trimming it out properly) - and one more thing what exactly does making it run in seperations do? thanks for any insight anyone might be able to share i think that it will be great fun once i learn a little more
PS - one more is a heading hold gyro worth it?
#1596
landonsmith
Get flat bottom plastic blades. Add wheel collars to the flybar out by the paddles.
I agree with mmatheny's suggestions. Also consider moving the servo/swashplate rods into the center holes on all three servo arms. Try one change at a time. Don't do all changes at once. Judge what combination works best for you.
Don't worry about going separates yet. Going separates will help you control your heli better; however, they won't make it easier to learn. Practice, practice, pratice. [8D]
#1598
landonsmith-
Higher head speed does increase stability. Flat-bottom airfoils create more lift. I don't have any experience with them. I think you should give 'em a try if you are up to the task! See the quote below:
ORIGINAL: Thomasp168
You can use BLADE CP blades in the AXE. they're a little bit shorter, so your headspeed is up. I'm lifting off at below half throttle with a full charge (1320 LIPO). I use the flat bottoms, about 7 bucks a pair less than the AXE blades. the fit is a little snug, but they work great.
#1599
FL
Word of Warning!!!!!! [X(]
ON AXE CP ...major desing weakness...Be carefull with screw that holds the Tail Shaft(HMXE9560). If you use a screw that is even the slights bit longer than the one that comes there or tighten too much, you may short the wires to the tail motor thereby frying the e-board!
This happened to me[:@][&:] ...i feel like such a careless fool...I have never fried anything in all of my years with RC. ...well at least the smoke was cool....
Gotta love the smell of fried electronics in the morning.
Its still a great little heli. Now I have to find a replacement e-board (anyone have an extra one cheap?) or do something else...
Word of Warning!!!!!! [X(]ON AXE CP ...major desing weakness...Be carefull with screw that holds the Tail Shaft(HMXE9560). If you use a screw that is even the slights bit longer than the one that comes there or tighten too much, you may short the wires to the tail motor thereby frying the e-board!
.This happened to me[:@][&:] ...i feel like such a careless fool...I have never fried anything in all of my years with RC. ...well at least the smoke was cool....
#1600
ORIGINAL: delvallejr
If you think this looks squirly, wait til you fly it-in the wind.
