Go Back  RCU Forums > RC Airplanes > IMAC
 2005 sequences >
2005 sequences
IMAC Discuss IMAC style aerobatics in here
2005 sequences
Old 11-20-2004 | 12:41 PM
quist's Avatar
My Feedback: (198)
Default 2005 sequences
the proposed 2005 sequences are now available for IMAC memebers in the members only area. these sequences look very busy and no free passes. So they should fly faster.
Old 11-20-2004 | 01:08 PM
Silent-AV8R's Avatar
Default RE: 2005 sequences
But I'll bet that people will figure out how to stretch them from horizon to horizon.
BTW - what class are you flying in '05??
Old 11-20-2004 | 02:44 PM
quist's Avatar
My Feedback: (198)
Advanced, I think
Old 11-20-2004 | 03:45 PM
My Feedback: (8)
there are no free pass's in imac. your maneuver ends and the next one starts immediately.
Old 11-20-2004 | 03:47 PM
Flyfalcons's Avatar
If you aren't an IMAC member you can see the proposed sequences at the Northwest IMAC site.
http://www.imacnw.com/
Old 11-20-2004 | 04:07 PM
ORIGINAL: tony/amps
True enough, but Tony was using it as a generic term to indicate a long level pass (scored of course) with no actual figure on the line. This is a waste of time just driving from one end of the box to the other.
Pilots need to learn to fly tight. I was totally blown away at the Tucson Shootout to see a full scale Sukhoi flying a 360 roller smaller and tighter than 99% of the IMAC rollers I see flown.
Old 11-20-2004 | 04:29 PM
Say, could one of you clever fellows check out the proposed Intermediate sequence?
Have a look at Figure 8 on Proposal 2. It looks like a 2 point roll, half loop, then positive snap. Shouldn't that be a negative snap from inverted to inverted???
Old 11-20-2004 | 04:36 PM
Flyfalcons's Avatar
I think you mean figure 9 on proposal 2... are you asking if it is an illegal maneuver? According to the maneuvers catalog that is an allowed maneuver.
Old 11-20-2004 | 06:04 PM
Looking at the IMAC sequence criteria I currently have I am assuming things have changed for the intermediate class in 2005. According to what I have only 1 full positive snap from level or 45 degrees is allowed and 1 full negative snap from inverted to inverted. Anyone care to comment?
Old 11-20-2004 | 06:29 PM
I'm confused by the questions.
First A320's comments. There are no written guidelines for Known Construction. Don't confuse the Unknown Guidance Catalog with the Knowns. Having said that, there are general guidelines the BoD uses for each class. For 2005 it was decided to allow negative snap rolls on both level inverted lines and on inverted 45 downlines.
Now to the questions about the figures. Figure #8 on Intermediate Proposal B is a vertical upline with a 2 of 4-point roll up, exit negative.
On Proposal A, figure #8 is a 1 and 1/2 continuous rolls from inverted to positive. That is followed by a positive snap, 1/2 inside loop, full roll, exit negative.
The last two figures are the same in both. Pull to a negative 45 downline, full negative sap roll, exit negative. Then a 90 degree 1 roll roller to the inside. Enter/exit negative.
Old 11-20-2004 | 06:31 PM
Flyfalcons's Avatar
If you look at the snap criteria for intermediate, it does allow a full positive snap from inverted at the top of a loop or half loop.
Old 11-20-2004 | 06:34 PM
Again, there are no published criteria for Knowns. Only Unknowns, and they are different. The only real true published criteria is the FAI catalog, and I can assure you that all these proposals are fully legal by that standard.
Old 11-20-2004 | 07:04 PM
My Feedback: (18)
What happened to crossbox?
Unlimited B has only one crossbox maneuver (a humpty where the loop over the top is crossbox), and Unlimited A has two maneuvers, but one is just the entry to a roller. Personally I think the most interesting parts of the more complex advanced/unlimited sequences are the crossbox elements that require planning and skill to position properly. In some sequences it seems like back to back crossbox maneuvers make it go even faster because it makes it impossible to draw a long line between maneuvers. Is this an intentional effort to control sequence size?
Anyone know the story?
-Adam
Old 11-20-2004 | 08:26 PM
Sorry to argue with you, but I do have a sequence criteria that was published by IMAC for what the limits were in each family of maneuvers for each class. Known or unknowns. So far in all my IMAC flying over the past several years I have never seen anything that deviated from that published criteria. Don't get me wrong, I'm glad to see more than a single snap in intermediate, but I would like to have an updated list or you guys could be flying some very interesting unknowns if you come to Phoenix in February next year to fly in the return of "The Cactus Classic".
Old 11-20-2004 | 08:45 PM
My Feedback: (16)
So are we voting or critiquing?
Old 11-20-2004 | 09:21 PM
ORIGINAL: A320driver
The official Unknown catalog is being re-worked right now. It needs a fair bit of work. As far as the Knowns, sorry, since I worked on the 2005 submittals I think I can tell you that there was NOT a document that was used. We had discussions with the BoD as to what was desired, what was acceptable and so on. But the only really official document is the Unknown one. And believe it or not, but there are things that are legal for a Known that are not OK for a Known. Any Unknowns that I write in 2005 will comply fully with the new catalog of Unknown figures, once it is finalized.
Hope that helps.
Old 11-20-2004 | 09:25 PM
ORIGINAL: Geistware
The way I understand it, the BoD is looking for comments only. The final decision will be by the BoD alone. THe IMAC website has a place for member comment on each sequence.
Old 11-20-2004 | 11:22 PM
My Feedback: (16)
I commented on the Sportsman and Intermediate routines posted.
ORIGINAL: aresti2004
ORIGINAL: Geistware
Old 11-21-2004 | 12:03 AM
Hi All,
Had a beautiful day here in Nor-Cal ..Burnt 3 gallons trying the new advanced proposals..B is a real winner..Goes fast and is easy to keep tight!! Hats off to whoever wrote it!!!A wasn't as much fun...
My buddy flew sportsman...A is a time waster while B is efficient... We haven't checked out intermediate or Unlimited yet.(But we will tomorrow)!!!
Can't wait for Phoenix"05
Dave Stoik
Old 11-21-2004 | 12:10 AM
Bill,
I thought I recognized some of your Handywork in the proposals!!!! (GRIN)
Dave
Old 11-21-2004 | 12:14 AM
The sequences at the Northwest site are not the same as the ones on the IMAC members site. At least the Sportsman routines aren't anyways. Unless I missed something they're not the same. Later Jon
Old 11-21-2004 | 01:00 AM
ORIGINAL: hekter-RCU
Bill,
Dave
Watch you talkin' about Willis???? [&:]
Old 11-21-2004 | 01:14 AM
For any Non-IMAC members out tehre who are interested you can see the 2005 proposals here:
http://www.scaleaerobatics.org/IMAC2005Proposals.html
Old 11-21-2004 | 07:42 AM
My Feedback: (12)
I agree with Hecter that proposal A for Sportsman is a waste of time. There are 3, count them 3, 2 of 4 rolls on 45° uplines. What gives?
Another comment regarding the "speed" at which a sequence is flown. Since the Shootout, I realize that a few of you (I'm assuming most are involved with SCAT) are concerned with the time it take to fly a sequence. "Fly tight" I'm not sure I agree. It is my opinion that a sequence should take about the same amount of time wether it is a SCAT or IMAC event. If someone chooses to fly the routine at an accelerated pace then have at it. I believe time is saved by staging pilots 2-3 deep and having them in the air before the next guy takes off. I love to have as many flights as possible but not at the expence of feeling rushed when I fly. Here in the SC region, there is too much lack time between rounds. Every contest I atttended could have easily completed another round exept for one due to weather.
By the way, it was great fun competing against all of you guys at the Shootout. I had a blast.
Ryan
Old 11-21-2004 | 09:18 AM
I'm going to go fly some of these today with a buddy.
(Interm and Unlim)
