Reload this Page >
Balsa USA 1/4 Scale Nieuport 28 Build
Old 05-16-2015, 02:02 PM
  #551
SunDevilPilot
SunDevilPilot's Avatar
This project really needs to get done so I can move on. My brain is already two kits ahead!
Today I installed the wood covers over the landing gear. The covers were made from spruce which I machined into a streamline shape. I also cut grooves in the center of each to accept the wire.
Each cover consist of two pieces, an inner and an outer. The wire is sandwiched in the middle.
To make sure the wood pieces never rotate on the wire gear I soldered a small tab on each leg, to lock the wood in place.
Little final sanding and some clear lacquer and the gear will be done.
SunDevilPilot
Name:	Landing Gear Covers 1.jpg
ID:	2096415   Click image for larger version
Name:	Landing Gear Covers 2.jpg
ID:	2096416   Click image for larger version
Name:	Landing Gear Covers 3.jpg
Old 05-16-2015, 02:40 PM
  #552
foodstick
foodstick's Avatar
Your brain is two kits ahead? Brother you must have been in MY head reading my problems with this hobby !
Liking your build, a friend has the N 28 and loves it.
Old 05-17-2015, 08:36 AM
  #553
SunDevilPilot
This morning I got right to the final sanding and putting the lacquer onto the gear. I'm using Deft brand lacquer which comes in a spray can. Super easy to use and really nice finish.
The fresh wood is a little lighter than the spreader bar and struts, which were done months ago, but they should yellow up a bit in time.
Gear is now complete. Next up, mounting the guns.
SunDevilPilot
Name:	Gear Done 1.jpg
ID:	2096557   Click image for larger version
Name:	Gear Done with Cowl 1.jpg
ID:	2096558   Click image for larger version
Name:	Gear Done with Cowl 2.jpg
Old 05-17-2015, 09:52 AM
  #554
HoundDog
My Feedback: (49)
HoundDog's Avatar
gona save the maiden till November ? Gota get Video for U-Tube.
Only 7 degrees cooler than U today but winds are from the south at 26 gusting to 32
Possible T Storms this afternoon. This is what one of our members did yesterday
In the Pits right next to the parking area. Lucky Miss.
OK let's get back to the Project at hand.
ID:	2096555   Click image for larger version
Old 05-17-2015, 09:55 AM
  #555
SunDevilPilot
Glad you made it home safely! Looks like gravity got a piece of that one.
Not really sure when the maiden will be. At least I am closing in on the end of this one. Woodworking is almost complete. Finishing, while complex, should go quickly.
SunDevilPilot
Old 05-17-2015, 10:48 AM
  #556
HoundDog
My Feedback: (49)
HoundDog's Avatar
SunDevilPilot
Be sure to get video of the maiden.
I Got home safely if U consider $1200 front end damage from hitting the javelina pig on the Bush Hwy Safe, Happy it wasn't an an Elk, or the $248 Bearing and hub replacement, in Amarillo TX, on the trailer. I was warned to grease the wheel bearings. OH well it's only Money. Now my only worry is dieing on the table Thursday when they blast a Kidney stone
Any way have a good Maiden and Hope to see ya all in November.
Old 05-18-2015, 01:01 PM
  #557
ALbert.S
aa
Old 06-14-2015, 08:59 AM
  #558
SunDevilPilot
Working on the last bit of construction, gun mounting.
I had two options... Go with the "Sport Scale" mounting vs the scale mounting. I went with the sport scale.
The difference between the two would be mounting the guns to the surface of the fuselage vs cutting into the fuselage and mounting them below the surface (Tighter fit).
I'm struggling with getting this project done so I am going to surface mount them. There is quite a bit of structure under the mounting locations and I really don't feel like modifying that at this point. Additionally, mounting them on the surface will allow them to be added after the model is covered, simplifying that process. The balsa USA Manual has them surface mounted and a few other models I have seen follow this trend.
So far I have the upper mount made. I have the lower mount drawn out and will build it this weekend.
SunDevilPilot
Name:	Upper Gun Mount (1).jpg
ID:	2102533   Click image for larger version
Name:	Upper Gun Mount.jpg
Old 06-14-2015, 09:23 AM
  #559
SunDevilPilot
Just FYI,
I've been doing a bunch of "Modeling" just not on my project!
A friend of mine is in the final stages of an Aviation Concepts PT-19. He asked me to create the inner brakes and outer wheel cover for his plane. He enters scale competitions with his models so I had to work pretty hard on them. The inner portion remains stationary on the axle while the wheel turns. It attaches to the axle with a small set screw. There is about a 1/32 gap between the inner assembly and the wheel itself.
The first photo is of the landing gear of a PT-19 at Pima Air and Space Museum in Tucson. I had taken the photo when I heard my friend would be working on a new build and thought he may want it for reference. My friend did go down to Tucson and was allowed access to the plane where he took a bunch of photos.
They took a couple weekends to complete and I hope they added in a positive way to his model.
They aren't perfect but I had to work within the limitations of the Robart wheels he was using for this project.
SunDevilPilot
Name:	PT-19 Inner Wheel.jpg
ID:	2102538   Click image for larger version
Name:	Wheel Brakes 1.jpg
ID:	2102539   Click image for larger version
Name:	Wheel Brakes 2.jpg
ID:	2102540   Click image for larger version
Old 06-17-2015, 03:56 AM
  #560
20181c
Gas
Old 06-17-2015, 06:29 AM
  #561
HoundDog
My Feedback: (49)
HoundDog's Avatar
Just FYI,
SunDevilPilot
Hope that RICH Guy paid ya well for the lathe work. LOL
Old 06-17-2015, 10:16 AM
  #562
SunDevilPilot
My work is always free!
Old 06-30-2015, 01:13 PM
  #563
SunDevilPilot
Worked in the garage as long as I could, which was not very long due to the heat. Probably about 95 degrees out there. The second mount has been roughly shaped and the mounting inserts for the guns themselves are installed into the mount. Next the upper and side gun mounts will get dowel inserts for the screws that will bolt the mounts to the fuselage. Then the parts will get rounded.
Going well so far.
Name:	Nieuport 28 Guns 1.jpg
ID:	2106615   Click image for larger version
Name:	Nieuport 28 Guns 2.jpg
Old 07-06-2015, 02:55 PM
  #564
SunDevilPilot
I added the dowels into the gun mounts. These dowels capture the 2-56 mounting screws which hold the gun mounts to the fuselage. Now I need to add the 2-56 blind nuts to the inside of the fuse. The rear mounting screw locations are going to be easy, the front two not so much. The holes are already made in the fuse so all the tough stuff is done.
Once the blind nuts are in I'll do the final shaping of the mounts.
Name:	Guns Mounted Part 2 1.jpg
ID:	2107849   Click image for larger version
Name:	Guns Mounted Part 2 2.jpg
ID:	2107850   Click image for larger version
Name:	Guns Mounted Part 2 3.jpg
Old 07-07-2015, 03:18 PM
  #565
SunDevilPilot
This morning I installed the blind nuts for the gun mounts into the fuselage. The rears were a no-brainer as they were in plain view. The upper front was buried under a former and caused a few tense moments (Somewhat rage inducing). The front rear was totally obscured by a former until I made a small access hole.
Once the blind nuts were in a did a little rough shaping of the lower mount. I used the included photo as a reference and believe I got pretty close. I may need to add a little more angle to the rear edge to closer match the photo but so far so good.
I think the next item is the windshield, then double check everything and commit to covering.
SunDevilPilot
Name:	Full Scale.jpg
ID:	2107972   Click image for larger version
Name:	Lower Mount Done 1.jpg
ID:	2107973   Click image for larger version
Name:	Lower Mount Done 2.jpg
Old 07-08-2015, 07:40 PM
  #566
SunDevilPilot
Just thought I'd share this. Heck, it's my thread!
My friend finished up the wheels for his PT-19. He really does some great work (Why I had to try really hard to make my contribution nice).
SunDevilPilot
ID:	2108147   Click image for larger version
Old 07-11-2015, 08:09 PM
  #567
SunDevilPilot
Today I did a little more shaping on the gun mount and think I have gotten the shape where I want it. About 2 minutes of rounding on the upper mount and they are done.
I started looking at what to do with the windshield and think I have a plan. There are several variants of the windshield and I think I will choose one with three distinct panels, all of which are slightly rounded. To my eye it just looks the most proper for the plane. A couple templates will be made from card stock to get the shape correct then the final piece will be thin ply.
I re-mounted the pilot figure to check the height of the windshield.
SunDevilPilot
Name:	Gun Mounts Complete 1.jpg
ID:	2108611   Click image for larger version
Name:	Gun Mounts Complete 2.jpg
ID:	2108612   Click image for larger version
Name:	Gun Mounts Complete 3.jpg
ID:	2108613   Click image for larger version
Name:	Gun Mounts Complete 4.jpg
Old 07-19-2015, 05:28 PM
  #568
SunDevilPilot
Started on the windshield.
I was lucky enough to receive a template for the windshield from someone in RC Scale Builder. I have referenced several build threads on RC Scale Builder for a long time and many of the guys over there create some really magical planes. I believe the original creator of the template was a guy who, on RCSB, goes by Geezer. He had provided the templates to a gentleman named Whit. Whit provided them to me.
If you want a true reference of a great pair of 1/3 scale Nieuport 28's look for Geezer and Whit's threads. They are both in the Balsa USA section on RCSB.
First I plan on mounting the base onto the fuse with some tiny screws. Then the frames will be fitted and glued to the base. This method will allow the windshield to come off the model for finishing and simply bolt back on.
I still need to cut out the glass section but at least I have a start.
Thanks Geezer and Whit!
SunDevilPilot
Name:	Nieuport Windshield.jpg
Old 09-15-2015, 12:31 PM
  #569
SunDevilPilot
Today I tackled the windshield. I have never done a windshield using this method but I believe it is superior to gluing one on after the model is finished. All the fiddling is done and for the most part the windshield is complete. I will likely add some fillets to the lower edge once the initial glue sets up. I will also add some type of filler material to the backside, along the joints between the front and sides. I don't want these parts to come apart down the road so maybe something like fiberglass cloth.
The process went really smooth. I first mounted the base, centering it on the fuselage. Then I added the center portion, using a small piece of wood with a tiny notch in it to set the proper angle. Once the center was glued in place I added the sides. The sides have a slight bend to them. I pre-bent the parts with a little water, allowing the bend to set while the parts were strapped to a can.
I think the only item left to address is the locating and mounting of the motor ESC. Been a lot of work but this one is pretty much assembled and can move onto covering / painting.
SunDevilPilot
Name:	Nieuport Windshield Part 1 1.jpg
ID:	2120078   Click image for larger version
Name:	Nieuport Windshield Part 1 2.jpg
ID:	2120079   Click image for larger version
Name:	Nieuport Windshield Part 1 3.jpg
Old 09-15-2015, 03:13 PM
  #570
jpflyer
My Feedback: (13)
That looks great. I will probably copy it, when I get that far. Thanks for posting it.
Old 10-27-2015, 06:27 PM
  #571
SunDevilPilot
First bit of covering goes on. Started with the rudder to get the feel back. SolarTex just makes the job too easy.
SunDevilPilot
ID:	2128005   Click image for larger version
Old 10-31-2015, 12:25 PM
  #572
Ray99
sorry if I am crashing this thread. I'm new to kit building and quite ignorant of what it takes. I just have one question, just how flat does a building board have to be. I have mine down to .007" on a board that is 48" X 24". Is that good enough? once again sorry to interupt
Ray
Old 10-31-2015, 01:01 PM
  #573
jeffo
My Feedback: (68)
heavens yes,your building a plane,not a clock.
Old 10-31-2015, 04:02 PM
  #574
takEon
Old 10-31-2015, 07:50 PM
  #575
SunDevilPilot
I agree. That is one flat table!
