~~Sig Kadet Brotherhood~~.
#2952
I have been doing the same with their Cub. Built the first one with no mods, other than a non traditional paint scheme, and stuck an FA-100 GK on its nose. Was going to make a second set of wings, clipped version, so bought the wing kit, built a wing, and just for kicks, put it on the bottom of the Cub, Lo and Behold, my next project. So now I have a second Cub, in traditional Cub yellow, but as a Stagger Wing Bipe. I think when its finished it will be an excellent looking flying machine. At the point now on trying to determine which ailerons to lock down, top or bottom.
#2954
Oh heck yeah! gotta be cool!
Now who is gonna be the first to do a stagger wing Kadet?
4 ailerons. Rolls faster than you can count "em. Around mid 90's I modded an 2nd 3rd hand???? biplane I bought originally built in the mid 60's with a cross scavenged .60 for power. I put a ST .90 in the nose and and and cut into the back of the top to add full size ailerons slaved from the bottom pair. Man oh man what a hot dog. Insane roll rate. I could out roll my wingeron slope glider. Wingerons are the whole painless rotate. A solid round carbon fiber rod is is both the wing joiner and the rotation center. You want a lot expo on those channels. My slope buddy went one step farther and also used the wing panels as elevator. Pitcheron's. No external control surface connect whatsoever, and nothing to the tail at all. Man that thing was fast! Pitch was about average, maybe a bit less, but wicked roll.
I have never seen a power plane set up with wingerons or pitcherons. Be pretty cool though. The mechanism would need to be more vibration resistant than what we used for gliders. I did Start a wingeron racer for the race class we had for .25 engines. Moved and never got back to it. MMMM I still got the fuse. Pitcheron controlled Kadet? Still got the control mechanism but no carbon rod. I think it might be 1/2" rod. Uh never mind for now.
Ken
Ken
#2956
http://www.rcuniverse.com/forum/kit-...l#post12095535
For some reason most of the pics in that thread are gone
#2957
Ken
Ken
What I am considering is to cover the bottom ailerons as normal, but after attaching them, seal them to the wing with strips of cloth to immobilize them. This way if I decied I want to use them in the future, all I need to do is open the servo bay, install the servos, and cut away the fabric around the ailerons. This would give me the option of making the bottom ailerons as spoilerons or flaperons as needed. My flying Cub takes very little to stay airborne, when I try to do a 3 point at idle, it climbs. If the Biper has the same tendency, it would be a PITA to land as it wont want to come down until it stalls. If it does that then I will need the lower ones to add some drag, or reduce lift.
#2959
Other than the added weight of the clipped lower wing, its the same as my other cub, without the black and gold engine. I think a 5' runway will be all I need to take off from.
#2961
I have found that the pitch of the prop really affects landing. A fine pitch gives lower speeds, better control and a shorter approach. I like a 14x4 on my OS 70 pulling a Four Star 60. If going to the Saito 100 means using more pitch I'd stick with the 70. CG matters too, of course. A balance point that is best for flying can result in float for some planes. But a low pitch prop should fix that. With all that wing area and no change in the stab area, you might want the CG a little more forward. Of course, you will have to move the balance point forward because of the lower wing position too. The drag of having four wing tips should help landings too.
Jim
Jim
#2962
thats the one part I haven't figured out yet, the CG, most likely the CG will fall somewhere between the single wing CG and the leading edge of the top wing. That falls about where the lower wing spar sits.
#2963
Two things changed:
1. The extra wing increases the total wing area, but the stab area and tail moment arm are the same. That means the stabilizing force has decreased compared with the destabilizing force. That requires a more forward CG.
2. The lower wing is forward from the top wing, so that also moves the CG forward.
#2964
Coming along nicely, hard to believe something so big came out of a box so small...lol I like the way I did the front wing mounts, first time I've done front wing mounts with bolts.
#2965
new year and the Kadet Senior kit is flying, here is the video from this morning maiden
https://www.youtube.com/watch?v=hZHTIyrKigA
Carlo
Carlo
#2967
Carlo
Carlo
What size motor are you using ?
#2968
Hi Tom, the motor is a Turnigy EasyMatch 46 420 kv with a 15x6 APC E and a Turnigy 4S 5000 MAh 20C
Wattmeter says around 20 A so very little wattage.
Further elevator has to be fixed to avoid nose down as now it is flat with the botton of tail
Please consider this is my first electric airplane as I usually fly with electric sailplanes, so any hint (like for the building in this thread) will be more than well accepted
Carlo
Carlo
#2969
Well done Carlo!! Nice looking, great performance. Wonderful way to start the new year.
#2970
Carlo
Carlo
I flew my Kadet Sport ARF on a 32 sized motor, on 4 S. It flew well, but I wanted a little more zip. I put in a 52 size, also on 4 S, and now, I never fly above half throttle.
Your building skills look fine, but if you have questions, the guys in this thread will be happy to help.
#2971
Carlo
Carlo
#2972
my lt-40 build
I would like to throw my hat into this ring now with the competition of my Lt.. done in white red and carbon fibre for the black areas. many upgrades and mods. none of the supplied decals were used.. everything cut from H9 covering on my vinyl cutter
power >>>>>> evolution 10GX2 pumped carb
AUW >>> >>>>8 lbs
Balanced at >> 4 inches as is
AUW >>> >>>>8 lbs
#2974
So far I like the engine .. on the first start the pumped carb had no problem drawing the fuel from the tank located on the CG in the main cabin area. The tank had to be moved back to this spot because the ignition is where the tank should be.. and since the tank is moved back the throttle servo was moved forward. the only problem so far is that I am getting some random servo movement in the throttle servo.. tried to isolate it by installing a BEC.. and then by a second battery.. but still get random movement.. the throttle servo may have to be moved again or maybe just replaced.. as it is mounted right above the ignition module
The tank is mounted in the bottom in dense foam and I use the evolution fibre clunk in the tank.. the vent line goes down out the bottom of the fuse and there is a fill and drain line to the front and the fuel supply line to the engine.. then a layer of foam and a battery, a layer of foam and then a sheet of ply wedged under the installed side rails to hold it all down.. pretty simple and easy to get to if needed..
measured on a scale she had 6 1/2 lbs of pull... 12x6 APC prop
#2975
my lt build
the biggest kick of this whole thing was that I always liked the look of the Lt and even though I fly some stupid over power stuff.. I like the Lt... crazy..
Well as fate would have it.. buddy of mine found this at the local value village store with a price of 9.99 on it... what a laugh... so he got it for me and I of course paid him for it.. and then had a lot of fun building it.. I love to build and restore old models.. and since I had no serious wrecks this year that needed rebuilding this fit into the picture just fine..
