Reload this Page >
~~Sig Kadet Brotherhood~~.
Old 07-31-2021, 02:59 PM
  #3776
neons
neons's Avatar
Dino
That is a well color coordinated scheme. It just caught my eyes. Very pretty. Good choice.
I fly my inherited Kadet Senior regularly over the years. Love the plane. I recovered mine the same with original Circus Pink as my best friend had it before he passed away 2007.
Old 07-31-2021, 07:31 PM
  #3777
FlyerInOKC
FlyerInOKC's Avatar
I like Circus Pink too!
The following 3 users liked this post by FlyerInOKC:
D_I_N_O (08-01-2021), Mud Duck (01-25-2022), skylark-flier (01-25-2022)
Old 08-01-2021, 01:43 AM
  #3778
D_I_N_O
D_I_N_O's Avatar
Pink engine
What paint is used. I have one .40 Saito and it is running pretty hot even with proper mixture and cooling. I would expect paint to be burned off.
Few words about my color choices. To be fair I have to admit I did not select the colors. I gave some examples to my daughters to choose from. My preferred combination would have been lighter pink with dark graphite grey. Luckily I followed advice from offspring. Color pattern is copied from kit box with some variations. Not too much imagination used with finishing.
Old 08-01-2021, 06:10 AM
  #3779
FlyerInOKC
FlyerInOKC's Avatar
Rustoleum/Krylon and it has stayed on when running the .56 Saito. It does wear some in handling but once you mount it permanently that problem is solved.
Old 08-23-2021, 05:09 PM
  #3780
biam
biam's Avatar
A giant pic of my Sr. I realized I hadn’t put one up after finishing a few years back.
The following 3 users liked this post by biam:
capt1597 (09-27-2021), Mud Duck (01-25-2022), skylark-flier (08-24-2021)
Old 08-23-2021, 07:37 PM
  #3781
FlyerInOKC
FlyerInOKC's Avatar
Nice! Is that your Cherokee in the background?
Old 08-24-2021, 12:23 PM
  #3782
biam
biam's Avatar
Yes it is. The Cherokee is equipped with flaps, was experimenting with them and getting used to using them again. Both have magnum four strokes. The Cherokee has a .52 and the Sr. Has a .70. Will try to post smaller pics next time when I figure it out. Tried to put up two pics yesterday but the site experienced difficulty’s😒
Old 09-21-2021, 01:43 PM
  #3783
vlcordero
Default Sig kobra ep conversion
I was wondering if any of you chaps have converted a sig kobra to Electric? My hangar Queen has sat under the table saw for too long and the motor is shot. Tank is gross. Battery pack kaput. A .25 electric motor should be more than sufficient no?? 9" max on the prop length. Thanks in advance!
Old 09-22-2021, 06:43 AM
  #3784
Flight Risk
Flight Risk's Avatar
I'm not too familiar with the Kobra, but have converted a couple other glow planes to electric. One concern I would have is that you will need to stuff a 3000 mAh or larger battery near the nose to get any flight time, and my guess is you may need to relocate servos farther back. Would the battery be inserted through the canopy or will the wing need to come off? I'm sure it can be done, but will take some reconfiguring.
Old 09-22-2021, 09:53 AM
  #3785
vlcordero
Thanks for responding! I wasn't sure i would even get a response! I have 8-1/2 inches from the front engine bulkhead to the 3rd, and luckily only the throttle servo was there which will also be eliminated. 2nd bulkhead has a 2-1/4 square hole cutout so I am optimistic I can get a decent pack in there. Unfortunately to utilize all that space, I will have to opt for the wing off battery installation. It had a .32 in it so I was looking for a .32 motor, but I cannot swing an 11" prop due to ground clearance. I was ready to move on some parts and realized I may need to downsize the motor but hope to have equal performance as the .32. Of course I would NEVER overthink such a rather simple conversion before execution. 😆 🤣 i will look into my battery options to see what is available! Thanks for the suggestion! So.. about that motor size... 😂
Old 09-22-2021, 10:26 AM
  #3786
acdii
Look into the Eflite Power 25 1250KV. It works with the prop size you need. If the plane weighs more than 5.5 pounds though, you may need to go to a larger motor. Prop size for that motor is 8x8E to 10x10E (3S). I have a pair of them flying my Twin Otter, but for that plane it needs 8800 MAH 3S packs for it to fly more than a couple minutes after take off due to it's size. Don't forget that batteries work on their sides too.
https://www.horizonhobby.com/product...EFLM4025B.html
Old 09-22-2021, 01:51 PM
  #3787
Hydro Junkie
Hydro Junkie's Avatar
You do know that you can down size the blade length by adding a blade? I was just looking at the OS 35 AX and it runs a 10X6 for break in. If you can clear a 9" prop, a 3 blade 9X6 would probably work. If the engine you had was an OS 32, the 35 is a drop in replacement. IF you have your heart set on the electric conversion, ignore my post.
Old 10-02-2021, 07:38 PM
  #3788
flyingagin
flyingagin's Avatar
There is a 200% Kadet Senior build be done on the other site. Some great work.
Ken
The following 2 users liked this post by flyingagin:
biam (10-06-2021), skylark-flier (10-03-2021)
Old 01-25-2022, 03:15 AM
  #3789
skyrat71
skyrat71's Avatar
I'm back again. Been a busy few months with no flying. The frozen Arctic is living up to it's reputation this winter. But, my wife who loves me and puts up with my foolishness and poor decision making skills decided i needed an other kit to build. So now i have a Kadet LT25 awaiting its turn on the building board. I am torn between building it exactly per the plans and saving it to teach my son with in a few years(he just turned 15 months, so it will be awhile), or bashing the hell out of it and making another super STOL mudplane. Show me your LTs guys and help me decide.
Old 01-25-2022, 04:19 AM
  #3790
Mud Duck
My Feedback: (94)
Mud Duck's Avatar
Default Glad you’re back!
I would recommend building it now. When he’s old enough there will be other kits and planes to build. My LT-25 is approaching 25 years old. My dad built it for me with an O.S. FS-26 four-stroke to start with. He modified it to have a servo on each aileron so that it could have the benefits of flaperons and it’s awesome! The covering became hard and brittle over the years so I refurbished it and converted it to electric and a bolt-on wing. I love how it flies with electric power, especially the landings with the flaperons. It is like a dead stick landing each time and it will slow to a stop. Initially I was using A123 cells, but now it uses Li-Po’s.
Dad with the LT-25 1997’ish.
LT-25 converted to electric and bolt-on wing.
Old 01-25-2022, 05:24 AM
  #3791
rich6170
rich6170's Avatar
Default Lt25
I just got this one done last month and looking forward to warm weather. Converted to tricycle landing gear. Bolt on wings and powered by OS 40fp. It also has dual aileron servos with flapperons.
The following 3 users liked this post by rich6170:
biam (01-26-2022), Mud Duck (01-25-2022), skylark-flier (01-25-2022)
Old 01-25-2022, 06:41 AM
  #3792
Flight Risk
Ken
I just checked out that thread. He finally had the maiden a couple weeks ago. Fun to watch video. Big DLE 170 twin.
Old 01-25-2022, 06:48 AM
  #3793
FlyerInOKC
FlyerInOKC's Avatar
Rich, you have a very classy looking airplane!
Old 02-27-2022, 11:44 PM
  #3794
D_I_N_O
D_I_N_O's Avatar
Against all odds I managed to complete float installation within one winter build season. This is mainly because floats are only modified version of ARF set for Great Planes Avistar 30cc
Floats fit nicely although they are bit too wide. Avistar is bigger plane but I think these floats look too small for it. All plywood construction with film covering. I changed top covering from blue to Oracover Bordeaux red which is perfect match for my selected paint. This is just lucky coincidence. Float set included nice white aluminium strut set for installation which I could not use. I did bend some piano wire instead.
Here is video of short test flight with frozen fingers. I don't usually do any winter flying. Temperature was -10 C, half flap take off and full flap landing.
The following 3 users liked this post by D_I_N_O:
capt1597 (02-28-2022), Mud Duck (02-28-2022), RICKSTUBBZ (02-28-2022)
Old 02-28-2022, 04:52 AM
  #3795
FlyerInOKC
FlyerInOKC's Avatar
Nice job!
Old 02-28-2022, 07:30 AM
  #3796
flyingagin
flyingagin's Avatar
Looks good on floats.
When I built my Kadet Sr. I installed hard points for floats, but I never ended up building any floats for her. But the last Kadet Jr. I did build floats for it although I then had to add the hard point for them. The floats were a bit small as there were no hobby shops around and I just used the material I had on hand. And then I moved again and did not have access to be able to float fly. Closest it got to water was the apartments pool for pics.
Well with my soon move to the Mo. Ozarks I should have plenty of water. I have ribs for a new wing for my Sr. made. Barn door ailerons and slotted flaps. I will have to make a set of floats for it, and a new set for the Jr. I had to get rid of a bunch of stuff on my last move.
Ken
Old 02-28-2022, 08:45 AM
  #3797
tedsander
I'm finally getting the rebuild of a crashed LT-40 ARF started.
Rather than pay for a fuse kit from Sig, I'll just cut my own balsa and make my own. Too bad shipping for LT-40 plans from Sig costs more than the plans! So I'll have to figure it out from the jig-saw pieces the crash left behind.
The critical question:
How much down and side thrust is built in? Would rather do it when installing the firewall, than afterwards by shimming the engine.
Otherwise, should be a relatively quick rebuild.
Old 03-01-2022, 08:13 AM
  #3798
flyingagin
flyingagin's Avatar
If the angels are the same as a Kadet SR, JR, or any other Kadet size just go that way. I don't know, but would be somewhat surprised if the angels are not the same. Plans for the the Kadet can be found online for down loading, free. I don't remember the angels myself.
Some one else on here might be able to chime in with the info want also.
Ken
Old 03-02-2022, 01:12 AM
  #3799
Hydro Junkie
Okay guys, direct from the Sig website:
SIG LT-40 TRAINER KIT - Sig Manufacturing (sigmfg.com)
Incidence is 0 degrees for the horizontal stabilizer, 1.5 degrees positive on the wing
Engine should be set at 6 degrees right and down
Mud Duck (03-02-2022)
Old 03-02-2022, 05:14 AM
  #3800
tedsander
Thanks Hydro! I didn't scroll far down enough!
Wow, 6 and 6...I never would have guessed that much!
