Reload this Page >
~~Sig Kadet Brotherhood~~.
Old 10-16-2014, 04:01 PM
  #1801
flyingagin
flyingagin's Avatar
Awsome. Threads are easy here as no the other big sites. I do build threads on some other site where the pic size bytes is much smaller. I have to edit the p[ics to 18% to fit them. Those are a pain in the behind. Some are easy to link to photo bucket. And one you have to know html to do so. Needles to say it is a royal pain, But it is my favorite CL site, so put up with the limits.
Ken
Old 10-18-2014, 01:33 PM
  #1802
Zor
Banned
Default Playing around
Hello folks,
I have been doing some figurations on the idea of snap in wing struts.
Atached pics are from the monitor and consequently not too sharp.
My scanner is on another computer.
I will respond to any questions.
Zor
Name:	R 100_7450.jpg
ID:	2040868   Click image for larger version
Name:	R 100_7451.jpg
ID:	2040869   Click image for larger version
Name:	R 100_7452.jpg
Old 10-18-2014, 02:16 PM
  #1803
TomCrump
TomCrump's Avatar
My Kadet kit showed up yesterday, but I haven't checked it out.
I was delayed because I've been making progress on my Lockheed Vega. I mounted the wings, and set the incidence .
ID:	2040872   Click image for larger version
ID:	2040873   Click image for larger version
Old 10-18-2014, 04:16 PM
  #1804
Zor
Banned
Default What are they ?
Hi TomCrump,
I am curious what are the values for incidences; Wings and stabilizer.
Also . . . is there any thrust angle settings and what are they ?
Zor
Old 10-18-2014, 05:42 PM
  #1805
TomCrump
TomCrump's Avatar
Originally Posted by Zor
Hi TomCrump,
Zor
I haven't looked, but the info should be on the plans. I believe that you said that you purchased the kit, so you should be able to locate that info.
My Kadet Sport required down thrust, but no right thrust.
Old 10-18-2014, 07:53 PM
  #1806
Zor
Banned
TomCrump,
I was referring to your Lockheed Vega.
You said you mounted the wings and set the incidence.
Zor
Old 10-19-2014, 03:27 AM
  #1807
TomCrump
TomCrump's Avatar
TomCrump,
Zor
Sorry for the confusion. Since this is a Kadet thread, I'll refer you to my Vega build, where your questions are answered. http://www.rcgroups.com/forums/showthread.php?t=2237248
Old 10-19-2014, 08:19 AM
  #1808
Zor
Banned
Thanks TomC.
Stab +1 and wings 0. I will browse the linked thread later.
Thanks also for that link.
Zor
Old 10-19-2014, 11:51 AM
  #1809
Flight Risk
Flight Risk's Avatar
About a month ago, I lost my Kadet Senior Sport. The 91 four stroke allowed huge loops to be performed. I was enjoying them so much, that I neglected to reduce throttle on the down slope.
The inevtable happened. The wing broke just outside of the wing tube.
Several years ago, I lost my SR ARF with an FS 91 in a similar manner, pulling out of a high sped dive. Not fun. Which is one reason I stuck with an FS 61 in my new Sport. It's too easy to get carried away with pushing your plane to the limits. Struts are a good idea. I wish some manufacturer like Dubro would come out with some good clip on struts. I don't like the type with the fiddly little bolts, and I tryed clip on cleavises on one and they kept failing. Maybe locking linch pins of some sort.
Old 10-19-2014, 12:43 PM
  #1810
Zor
Banned
Default More preparation for the build
Following preparation of the wing ribs ( post 1770 ) I am now preparing for the assignment of the wood pieces.
Having a concept of the stresses in the model we should select the wood for the stronger pieces to be used where more stress resistance is needed.
I think that the material strength is related to hardness and weight. Also the hardness can vary along the length of a stringer for example.
My next move is to weigh the 36 inch long pieces and mark them while also checking their CG and mark that also.
Stresses and impact forces are lots more at the wings attachment and landng gear than at the stabilizer-elevator where the cross pieces are basically just providing thickness and spacing.
More on this later.
Zor
Old 10-19-2014, 02:38 PM
  #1811
TomCrump
TomCrump's Avatar
I had read about those failures. It's too bad that Sig hasn't remedied the problem.
The only "mod" that I've noticed, is a statement that basically says that we are on our own, if we use larger than recommended engines.
I have two smaller 4 strokes (.52 Surpass and an FS .61) that would work well in the Senior Sport. I was having too much fun with that .91 four stroke up front, though.
That's one of the reasons that I decided to build my next Kadet. I want to make sure that the wing will handle the expected stress loads. I don't think that I would be satisfied with a smaller four stroke.
I don't plan to go crazy, flying the Kadet, but it will recieve more stress than it would get if it were to be used as a trainer.
Old 10-19-2014, 05:44 PM
  #1812
acdii
My friend keeps commenting that he is surprised the wing hasnt come off my LT-40 yet with how I fly it. I beefed it up pretty good when I built it, along with the front pin block and rear hold downs. I used 1/4" aircraft ply for both, and the spar is rigidly assembled along with ply added front and rear to accommodate the bolt down configuration.
Old 10-19-2014, 06:51 PM
  #1813
Zor
Banned
Default Reference post # 1810
Greetings,
I have now classified all the 36 inches long wood strips.
The pictures show the results for the 1/4" x 1/4" strips.
I have also done the other cross-section sizes.
It is interesting to find that some are twice the weight of the lighter one.
The CG variation can be estimated by the fact that the pieces are 1/4" square.
Note that a 9.4 gram piece shows as 9 grams and a 9.5 piece shows as 10 grams.
I should be able to start building as I said in early December.
I will start with the wings and am designing the wings and fuselage bottom modifications to accept snap-in struts.
I am anxious to follow TomCrump planned build log but I am not planning to post in that thread.
Zor
Name:	R 100_7462.jpg
ID:	2041253   Click image for larger version
Name:	R 100_7463.jpg
ID:	2041254   Click image for larger version
Name:	R 100_7464.jpg
ID:	2041255   Click image for larger version
Name:	R 100_7465.jpg
Last edited by Zor; 10-19-2014 at 08:35 PM. Reason: Corrected intereting to interesting
Old 10-20-2014, 05:21 PM
  #1814
ckimmey
Is registration for the Kadet Brotherhood still open? I am new to RCU (been bouncing around RCG for a while). My Kadet hasn't flown for a year or so... powered by Super Tiger .45 (just enough power). I have been flying low wing intermediates and my Big Stik this season.
I have been considering mounting a .61 or larger in the nose and helping out with the candy drops next year at our club. Maybe even offer it as a tow plane for the glider guys...
Old 10-20-2014, 08:17 PM
  #1815
skylark-flier
skylark-flier's Avatar
Of course the Brotherhood is still open - Kadet fans always welcome new brothers. We've got you logged, #171 is all yours, welcome to RCU & the SIG Kadet Brotherhood!!!!! Ahhhh, you must have a Kadet Sr., can't imagine any other version that would need larger than a .45 (2-cycle), although there are a fair number of guys around here that have powered Kadets with everything up to nearly tractor engine sizes (just kidding). Seriously, Kadets can do nearly anything, and there are some very VERY interesting Kadets in this group.
Here's our SIG Kadet Brotherhood, as I've got it today:[TABLE="width: 508"]
[TR]
[TD]1[/TD]
[TD]-[/TD]
[TD]Gary Harris[/TD]
[TD]61[/TD]
[TD]-[/TD]
[TD]jstyle13[/TD]
[TD]121[/TD]
[TD]-[/TD]
[TD]bparker3[/TD]
[/TR]
[TR]
[TD]2[/TD]
[TD]-[/TD]
[TD]soarrich[/TD]
[TD]62[/TD]
[TD]-[/TD]
[TD]WYDAH[/TD]
[TD]122[/TD]
[TD]-[/TD]
[TD]DBD1[/TD]
[/TR]
[TR]
[TD]3[/TD]
[TD]-[/TD]
[TD]N1EDM[/TD]
[TD]63[/TD]
[TD]-[/TD]
[TD]stupidscreenname[/TD]
[TD]123[/TD]
[TD]-[/TD]
[TD]Chappy110[/TD]
[/TR]
[TR]
[TD]4[/TD]
[TD]-[/TD]
[TD]Live Wire[/TD]
[TD]64[/TD]
[TD]-[/TD]
[TD]coxco[/TD]
[TD]124[/TD]
[TD]-[/TD]
[TD]ercobud[/TD]
[/TR]
[TR]
[TD]5[/TD]
[TD]-[/TD]
[TD]5skyhawk172[/TD]
[TD]65[/TD]
[TD]-[/TD]
[TD]TunnelBill[/TD]
[TD]125[/TD]
[TD]-[/TD]
[TD]rickpell[/TD]
[/TR]
[TR]
[TD]6[/TD]
[TD]-[/TD]
[TD]zippome[/TD]
[TD]66[/TD]
[TD]-[/TD]
[TD]mike109[/TD]
[TD]126[/TD]
[TD]-[/TD]
[TD]ThunderBoat[/TD]
[/TR]
[TR]
[TD]7[/TD]
[TD]-[/TD]
[TD]shepard62[/TD]
[TD]67[/TD]
[TD]-[/TD]
[TD]beevo[/TD]
[TD]127[/TD]
[TD]-[/TD]
[TD]tazzzz[/TD]
[/TR]
[TR]
[TD]8[/TD]
[TD]-[/TD]
[TD]DeferredDefect[/TD]
[TD]68[/TD]
[TD]-[/TD]
[TD]Lowvoltage[/TD]
[TD]128[/TD]
[TD]-[/TD]
[TD]ThunderChicken[/TD]
[/TR]
[TR]
[TD]9[/TD]
[TD]-[/TD]
[TD]archie05[/TD]
[TD]69[/TD]
[TD]-[/TD]
[TD]skylark-flier[/TD]
[TD]129[/TD]
[TD]-[/TD]
[TD]deanz406[/TD]
[/TR]
[TR]
[TD]10[/TD]
[TD]-[/TD]
[TD]tomgreen[/TD]
[TD]70[/TD]
[TD]-[/TD]
[TD]hugh durden[/TD]
[TD]130[/TD]
[TD]-[/TD]
[TD]biam[/TD]
[/TR]
[TR]
[TD]11[/TD]
[TD]-[/TD]
[TD]n2ryd[/TD]
[TD]71[/TD]
[TD]-[/TD]
[TD]Cloud Cruiser[/TD]
[TD]131[/TD]
[TD]-[/TD]
[TD]UPF-7[/TD]
[/TR]
[TR]
[TD]12[/TD]
[TD]-[/TD]
[TD]race61[/TD]
[TD]72[/TD]
[TD]-[/TD]
[TD]SIGPlanes[/TD]
[TD]132[/TD]
[TD]-[/TD]
[TD]neons[/TD]
[/TR]
[TR]
[TD]13[/TD]
[TD]-[/TD]
[TD]Slavko[/TD]
[TD]73[/TD]
[TD]-[/TD]
[TD]rexperk[/TD]
[TD]133[/TD]
[TD]-[/TD]
[TD]Flyboy14901[/TD]
[/TR]
[TR]
[TD]14[/TD]
[TD]-[/TD]
[TD]lkruse[/TD]
[TD]74[/TD]
[TD]-[/TD]
[TD]M. Boesen[/TD]
[TD]134[/TD]
[TD]-[/TD]
[TD]proszak59[/TD]
[/TR]
[TR]
[TD]15[/TD]
[TD]-[/TD]
[TD]flyingagin[/TD]
[TD]75[/TD]
[TD]-[/TD]
[TD]whatwheel[/TD]
[TD]135[/TD]
[TD]-[/TD]
[TD]wildbills21[/TD]
[/TR]
[TR]
[TD]16[/TD]
[TD]-[/TD]
[TD]JPNYGAARD[/TD]
[TD]76[/TD]
[TD]-[/TD]
[TD]Wagon1[/TD]
[TD]136[/TD]
[TD]-[/TD]
[TD]hairy46[/TD]
[/TR]
[TR]
[TD]17[/TD]
[TD]-[/TD]
[TD]foodstick[/TD]
[TD]77[/TD]
[TD]-[/TD]
[TD]paulhold[/TD]
[TD]137[/TD]
[TD]-[/TD]
[TD]p-Yock[/TD]
[/TR]
[TR]
[TD]18[/TD]
[TD]-[/TD]
[TD]ovationdave[/TD]
[TD]78[/TD]
[TD]-[/TD]
[TD]groundstrike[/TD]
[TD]138[/TD]
[TD]-[/TD]
[TD]rrengineer[/TD]
[/TR]
[TR]
[TD]19[/TD]
[TD]-[/TD]
[TD]joebahl[/TD]
[TD]79[/TD]
[TD]-[/TD]
[TD]adreliable661[/TD]
[TD]139[/TD]
[TD]-[/TD]
[TD]hogflyer[/TD]
[/TR]
[TR]
[TD]20[/TD]
[TD]-[/TD]
[TD]WI53072[/TD]
[TD]80[/TD]
[TD]-[/TD]
[TD]earlwb[/TD]
[TD]140[/TD]
[TD]-[/TD]
[TD]Firewalkerd1[/TD]
[/TR]
[TR]
[TD]21[/TD]
[TD]-[/TD]
[TD]huck1199[/TD]
[TD]81[/TD]
[TD]-[/TD]
[TD]Unclebuck21228[/TD]
[TD]141[/TD]
[TD]-[/TD]
[TD]Flight Risk[/TD]
[/TR]
[TR]
[TD]22[/TD]
[TD]-[/TD]
[TD]Top_Gunn[/TD]
[TD]82[/TD]
[TD]-[/TD]
[TD]malitape[/TD]
[TD]142[/TD]
[TD]-[/TD]
[TD]ratshooter[/TD]
[/TR]
[TR]
[TD]23[/TD]
[TD]-[/TD]
[TD]Nergall[/TD]
[TD]83[/TD]
[TD]-[/TD]
[TD]Dave Holmes[/TD]
[TD]143[/TD]
[TD]-[/TD]
[TD]Steve Westphal[/TD]
[/TR]
[TR]
[TD]24[/TD]
[TD]-[/TD]
[TD]acdii[/TD]
[TD]84[/TD]
[TD]-[/TD]
[TD]Carlos G[/TD]
[TD]144[/TD]
[TD]-[/TD]
[TD]cforcht[/TD]
[/TR]
[TR]
[TD]25[/TD]
[TD]-[/TD]
[TD]hutchis[/TD]
[TD]85[/TD]
[TD]-[/TD]
[TD]kingranch[/TD]
[TD]145[/TD]
[TD]-[/TD]
[TD]kb8ife[/TD]
[/TR]
[TR]
[TD]26[/TD]
[TD]-[/TD]
[TD]ddewey[/TD]
[TD]86[/TD]
[TD]-[/TD]
[TD]Red Kadet[/TD]
[TD]146[/TD]
[TD]-[/TD]
[TD]rburke39[/TD]
[/TR]
[TR]
[TD]27[/TD]
[TD]-[/TD]
[TD]dhal22[/TD]
[TD]87[/TD]
[TD]-[/TD]
[TD]dirtrod[/TD]
[TD]147[/TD]
[TD]-[/TD]
[TD]rc56[/TD]
[/TR]
[TR]
[TD]28[/TD]
[TD]-[/TD]
[TD]Thomas Pham[/TD]
[TD]88[/TD]
[TD]-[/TD]
[TD]t4[/TD]
[TD]148[/TD]
[TD]-[/TD]
[TD]redjack[/TD]
[/TR]
[TR]
[TD]29[/TD]
[TD]-[/TD]
[TD]cubkadet[/TD]
[TD]89[/TD]
[TD]-[/TD]
[TD]FlyerInOKC[/TD]
[TD]149[/TD]
[TD]-[/TD]
[TD]rdgettler[/TD]
[/TR]
[TR]
[TD]30[/TD]
[TD]-[/TD]
[TD]Greg Davis[/TD]
[TD]90[/TD]
[TD]-[/TD]
[TD]DELTAFLY[/TD]
[TD]150[/TD]
[TD]-[/TD]
[TD]daddyvinny[/TD]
[/TR]
[TR]
[TD]31[/TD]
[TD]-[/TD]
[TD]CanDo[/TD]
[TD]91[/TD]
[TD]-[/TD]
[TD]sharpe917[/TD]
[TD]151[/TD]
[TD]-[/TD]
[TD]MartyPetriSr[/TD]
[/TR]
[TR]
[TD]32[/TD]
[TD]-[/TD]
[TD]gva1956[/TD]
[TD]92[/TD]
[TD]-[/TD]
[TD]jollyroger[/TD]
[TD]152[/TD]
[TD]-[/TD]
[TD]tomclark[/TD]
[/TR]
[TR]
[TD]33[/TD]
[TD]-[/TD]
[TD]metaldriver_2[/TD]
[TD]93[/TD]
[TD]-[/TD]
[TD]Cliffc[/TD]
[TD]153[/TD]
[TD]-[/TD]
[TD]c-crunch[/TD]
[/TR]
[TR]
[TD]34[/TD]
[TD]-[/TD]
[TD]Bladejunkie[/TD]
[TD]94[/TD]
[TD]-[/TD]
[TD]1320fastback[/TD]
[TD]154[/TD]
[TD]-[/TD]
[TD]BigTeeEldorado[/TD]
[/TR]
[TR]
[TD]35[/TD]
[TD]-[/TD]
[TD]New222[/TD]
[TD]95[/TD]
[TD]-[/TD]
[TD]Captinjohn[/TD]
[TD]155[/TD]
[TD]-[/TD]
[TD]TomCrump[/TD]
[/TR]
[TR]
[TD]36[/TD]
[TD]-[/TD]
[TD]cubflyman[/TD]
[TD]96[/TD]
[TD]-[/TD]
[TD]spaceworm[/TD]
[TD]156[/TD]
[TD]-[/TD]
[TD]hiflyer15[/TD]
[/TR]
[TR]
[TD]37[/TD]
[TD]-[/TD]
[TD]dasquirrelisme[/TD]
[TD]97[/TD]
[TD]-[/TD]
[TD]EvanB[/TD]
[TD]157[/TD]
[TD]-[/TD]
[TD]Fly North[/TD]
[/TR]
[TR]
[TD]38[/TD]
[TD]-[/TD]
[TD]Planejaw[/TD]
[TD]98[/TD]
[TD]-[/TD]
[TD]Major Tomski[/TD]
[TD]158[/TD]
[TD]-[/TD]
[TD]dwaynenancy[/TD]
[/TR]
[TR]
[TD]39[/TD]
[TD]-[/TD]
[TD]usc1990[/TD]
[TD]99[/TD]
[TD]-[/TD]
[TD]Jim Branaum[/TD]
[TD]159[/TD]
[TD]-[/TD]
[TD]oinoyou[/TD]
[/TR]
[TR]
[TD]40[/TD]
[TD]-[/TD]
[TD]cjet[/TD]
[TD]100[/TD]
[TD]-[/TD]
[TD]WLM189[/TD]
[TD]160[/TD]
[TD]-[/TD]
[TD]Jersy Hank[/TD]
[/TR]
[TR]
[TD]41[/TD]
[TD]-[/TD]
[TD]Murphey[/TD]
[TD]101[/TD]
[TD]-[/TD]
[TD]skyraider71[/TD]
[TD]161[/TD]
[TD]-[/TD]
[TD]flashpilot[/TD]
[/TR]
[TR]
[TD]42[/TD]
[TD]-[/TD]
[TD]Sandyt[/TD]
[TD]102[/TD]
[TD]-[/TD]
[TD]rc lifer[/TD]
[TD]162[/TD]
[TD]-[/TD]
[TD]Old_RC_Guy[/TD]
[/TR]
[TR]
[TD]43[/TD]
[TD]-[/TD]
[TD]planedriver_2[/TD]
[TD]103[/TD]
[TD]-[/TD]
[TD]NM2K[/TD]
[TD]163[/TD]
[TD]-[/TD]
[TD]TheComputerGeek[/TD]
[/TR]
[TR]
[TD]44[/TD]
[TD]-[/TD]
[TD]PT19[/TD]
[TD]104[/TD]
[TD]-[/TD]
[TD]terrysigcolt[/TD]
[TD]164[/TD]
[TD]-[/TD]
[TD]FloridaBeachFlyr[/TD]
[/TR]
[TR]
[TD]45[/TD]
[TD]-[/TD]
[TD]TimHendrix[/TD]
[TD]105[/TD]
[TD]-[/TD]
[TD]plane-o-joe[/TD]
[TD]165[/TD]
[TD]-[/TD]
[TD]aggieman[/TD]
[/TR]
[TR]
[TD]46[/TD]
[TD]-[/TD]
[TD]jessiej[/TD]
[TD]106[/TD]
[TD]-[/TD]
[TD]BobFE[/TD]
[TD]166[/TD]
[TD]-[/TD]
[TD]Renegade[/TD]
[/TR]
[TR]
[TD]47[/TD]
[TD]-[/TD]
[TD]Mr-Punk[/TD]
[TD]107[/TD]
[TD]-[/TD]
[TD]FLAPSDOWN[/TD]
[TD]167[/TD]
[TD]-[/TD]
[TD]T-47[/TD]
[/TR]
[TR]
[TD]48[/TD]
[TD]-[/TD]
[TD]rccrasher65[/TD]
[TD]108[/TD]
[TD]-[/TD]
[TD]scttsprg[/TD]
[TD]168[/TD]
[TD]-[/TD]
[TD]SigSenior[/TD]
[/TR]
[TR]
[TD]49[/TD]
[TD]-[/TD]
[TD]FMAY[/TD]
[TD]109[/TD]
[TD]-[/TD]
[TD]sbrillha[/TD]
[TD]169[/TD]
[TD]-[/TD]
[TD]Zor[/TD]
[/TR]
[TR]
[TD]50[/TD]
[TD]-[/TD]
[TD]Hrannar[/TD]
[TD]110[/TD]
[TD]-[/TD]
[TD]Mike Gretz[/TD]
[TD]170[/TD]
[TD]-[/TD]
[TD]WMB[/TD]
[/TR]
[TR]
[TD]51[/TD]
[TD]-[/TD]
[TD]Razor44[/TD]
[TD]111[/TD]
[TD]-[/TD]
[TD]skyrat71[/TD]
[TD]171[/TD]
[TD]-[/TD]
[TD]skimmey[/TD]
[/TR]
[TR]
[TD]52[/TD]
[TD]-[/TD]
[TD]Ken Kehlet[/TD]
[TD]112[/TD]
[TD]-[/TD]
[TD]lumppi[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]53[/TD]
[TD]-[/TD]
[TD]oldfartpilot[/TD]
[TD]113[/TD]
[TD]-[/TD]
[TD]bchapman[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]54[/TD]
[TD]-[/TD]
[TD]Soaring Steve[/TD]
[TD]114[/TD]
[TD]-[/TD]
[TD]scoooper[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]55[/TD]
[TD]-[/TD]
[TD]freefall2907[/TD]
[TD]115[/TD]
[TD]-[/TD]
[TD]Jolly Popper[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]56[/TD]
[TD]-[/TD]
[TD]fix-n-fly[/TD]
[TD]116[/TD]
[TD]-[/TD]
[TD]CNY_Dave[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]57[/TD]
[TD]-[/TD]
[TD]SigMan[/TD]
[TD]117[/TD]
[TD]-[/TD]
[TD]rtn9105[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]58[/TD]
[TD]-[/TD]
[TD]eroc144[/TD]
[TD]118[/TD]
[TD]-[/TD]
[TD]mbnt[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]59[/TD]
[TD]-[/TD]
[TD]nextofkin[/TD]
[TD]119[/TD]
[TD]-[/TD]
[TD]crawler tech[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]60[/TD]
[TD]-[/TD]
[TD]ALT[/TD]
[TD]120[/TD]
[TD]-[/TD]
[TD]308jockey[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[/TABLE]
Old 10-21-2014, 06:10 AM
  #1816
BigTeeEldorado
BigTeeEldorado's Avatar
Of course you are talking about my LT25 STOL
Old 10-21-2014, 06:13 AM
  #1817
FlyerInOKC
FlyerInOKC's Avatar
You're right they don't need a lot of power. I built my LT-40 with the Super Tigre .40 and she flys great!
Old 10-21-2014, 09:59 AM
  #1818
skylark-flier
Of course, you're absolutely right - that was #1 on my mind. Way earlier there was mention of a whole series of Kadets too, some twin engine, some twin tail, some just plane DIFFERENT!! I remember a sailplane carrier too - not a tow'r, a carrier.
Old 10-21-2014, 10:49 AM
  #1819
BigTeeEldorado
Wait Wait.....I've got a Twin...and I'm starting on a twin tail this week!!
Old 10-21-2014, 12:12 PM
  #1820
TomCrump
TomCrump's Avatar
If anyone is interested, I've started a build thread on how I will modify the Kadet Senior kit into a Kadet Senior Sport. http://www.rcuniverse.com/forum/kit-...l#post11903446
If interested, I encourage you to participate, as I'm sure that you have some good ideas that can be incorporated into my build.
Old 10-21-2014, 12:50 PM
  #1821
FlyerInOKC
FlyerInOKC's Avatar
I am interested and have subscribed!
Old 10-21-2014, 01:35 PM
  #1822
SigSenior
SigSenior's Avatar
BigTee,
Really like that landing gear you are sporting on your LT25 STOL. Did you fabricate that?
SS
Old 10-21-2014, 06:16 PM
  #1823
skylark-flier
For sure Tom, I'm following the thread too.
Old 10-21-2014, 07:03 PM
  #1824
flyingagin
flyingagin's Avatar
I'm in also Tom
Ken
Old 10-21-2014, 07:21 PM
  #1825
BigTeeEldorado
Originally Posted by SigSenior
BigTee,
SS
I did...thanks and it works really well absorbing the stall landings I do a lot of with that plane. The set in the picture was all aluminum and I had a hard time holding some of the parts together. (bonding Aluminum is tough) It eventually broke so I fabricated a new one from drill rod that is easier to hold together with solder. I don't have a lot of closeups but I'm happy to take a few to give you a better idea of how I put it all together.
