Reload this Page >
BUSA 1/4 Scale Fokker Dr 1
Old 01-30-2014, 07:59 AM
  #201
akbowen
My Feedback: (7)
Originally Posted by vertical grimmace
Sure, once you get it covered it should only take about a week to get her flying! What's the hold up? lol
I'm watching paint dry.
Raining here yesterday and today. Not so good for painting.
Old 01-30-2014, 12:31 PM
  #202
FlyerInOKC
FlyerInOKC's Avatar
Heat lamp?
Old 01-30-2014, 02:56 PM
  #203
jeffEE
jeffEE's Avatar
I'll take the rain. We got 7 inches of snow. Now thats not so bad, but the snowplows put about 4 feet of snow into my driveway. 2 hours of hitting the shovel that could have been spent on the tri plane.
Old 02-04-2014, 03:00 PM
  #204
akbowen
My Feedback: (7)
Originally Posted by FlyerInOKC
Heat lamp?
Problem is that I have to work in my garage. My wife keeps her car there. That means I paint outdoors with a rattle can.
Old 02-04-2014, 03:06 PM
  #205
akbowen
My Feedback: (7)
Moving along with the painting. Now, I'm not the artist or craftsman that VG is, but I'm pretty happy with the way things are looking. Also, I'm really happy with how the latex paint is working out. Very easy to work with.
What do you guys think? I chose the white patch for the balkencruz background mostly because it was easy. Some Dr.1s had the white patch, others a white cross background. With the fuse almost painted, I can start assembling the model as I paint the wings.
Old 02-05-2014, 05:21 AM
  #206
flygilmore
flygilmore's Avatar
Looking very good. I am about 60% done framing up my second BUSA Dr.1 as we speak. I went with natural Solartex this time as I had someone give me (4) 2m rolls of it. Comparing it to the Linen, there is very, very little difference between them. I guess I will experiment with the streaking as I get closer and see if I may need to add a slight brownish wash over the natural Solartex to get a good factory Fokker finish. I may end up not having to.
Still deciding which mount I want to go with. Been looking real closely at 413/17 but cannot decide which scheme is correct. I have seen a couple diff. pics, one shows the struts, cabanes and wheel covers black and the other shows them dark olive brown/green.
I'm also still debating how I will do the gear. On my first one, I went with GTM struts and bungeed it, may still bungee it but using the stock wire. I will def. be narrowing the gear stance a bit for a more scale appearance.
Old 02-05-2014, 06:34 AM
  #207
FlyerInOKC
FlyerInOKC's Avatar
Paint job looks great to me I wouldn't change a thing.
Old 02-06-2014, 05:12 PM
  #208
akbowen
My Feedback: (7)
Got her up on her feet, to say! I'm loving the colors.
Old 02-07-2014, 01:06 AM
  #209
jeffo
My Feedback: (68)
I did Lothar's color scheme also on my tripe,nice job!! jeffo
Old 02-07-2014, 04:27 AM
  #210
vertical grimmace
vertical grimmace's Avatar
Looking good. Are you gonna get a Lothar pilot from best pilots?
Old 02-07-2014, 07:31 AM
  #211
FlyerInOKC
FlyerInOKC's Avatar
I do believe Lothar and his brother would give her 2 thumbs up!!
Old 02-07-2014, 10:16 AM
  #212
akbowen
My Feedback: (7)
No, that's a few more bucks than I wanted to spend on a pilot. I got on to the Ace of Iron busts.
Old 02-07-2014, 02:21 PM
  #213
R/C Ray
Vertical,
llllove what you did with the nose. I plan to build one in the future and want to make the nose more scale. Great job, where did you get the dummy cylinders from? Have you flown the plane yet?
Ray
Old 02-07-2014, 05:00 PM
  #214
vertical grimmace
Originally Posted by R/C Ray
Vertical,
Ray
Thanks! The front end was a lot of work. No way around that. The cylinders are Williams bros. Then I made a mounting ring to attach them to. This has long bolts that go through to the firewall. The Cowl is GTM, and takes some time, but well worth it in the end.
Yeas, I think I have around 8 flights now. It flies as good, or better than my first one. I added around 5 degrees positive incidence to the tail to eliminate all the down elevator trim. I still have a few tweaks to get things completely ironed out, but I am very happy with it.
Name:	parvin Triplane 014.JPG
Old 02-08-2014, 05:39 PM
  #215
akbowen
My Feedback: (7)
Tail feathers attached. Rudder and elevator servos and control rods installed. I've started painting the bottom wing.
Old 02-08-2014, 05:48 PM
  #216
vertical grimmace
Those Balkenkreuze save a bunch of time over the Maltese. I cannot tell you how long it took me to just do the crosses on mine. Probably at least 2 weeks. That looks really good.
How did you rig yours again? Tail, wing incidence?
Old 02-12-2014, 02:56 PM
  #217
akbowen
My Feedback: (7)
You're right, the Maltese are a PITA. I've done those before. And, since this is "sport scale," I opted for a simpler approach.
As far as wing and tail incidence, I'm going neutral all the way around. That may change if she requires a lot of down trim as some have indicated. Changing the incidence on the top wing or stab will be no problem.
Here she is with the bottom wing painted and attached.
Old 02-12-2014, 04:13 PM
  #218
vertical grimmace
Nice!
With the wings at zero, you will be fine. Just fly it. What I mean by that is give it the stick that it will need, and trim accordingly. This plane is so dirty, it will never be hands off trimmed anyway. Kind of the charm of it really. Using the rudder is a lot of fun as well. The BUSA does not need as much in the turns, but it is fun to just fly it with rudder. If this is your first tripe, you are in for great fun.
Old 02-13-2014, 07:20 AM
  #219
akbowen
My Feedback: (7)
Sort of like flying a helicopter.
Old 02-13-2014, 08:37 AM
  #220
FlyerInOKC
FlyerInOKC's Avatar
Lothar called he wants his plane back! Good job!
Old 02-15-2014, 01:12 PM
  #221
akbowen
My Feedback: (7)
Mid wing painted and attached. Only one more wing to paint! I will be doing touch-up work for a while.
ID:	1968744   Click image for larger version
Old 02-15-2014, 02:38 PM
  #222
vertical grimmace
It is kinda nice after one of these builds to have a project that only requires one wing! lol
Old 02-21-2014, 04:17 PM
  #223
akbowen
My Feedback: (7)
Although I still have a couple of crosses to paint, here she is:
Pretty much, all that is left is radio gear installation. My club has a fly-in on March 7-8-9, so I'm planning on a maiden flight before that. I will install the pilot so that the weight is about right, but machine guns and cockpit coaming may have to wait until later.
ID:	1970956   Click image for larger version
ID:	1970957   Click image for larger version
Old 02-21-2014, 04:37 PM
  #224
vertical grimmace
Looks very nice. I forgot how much work it was on the first one, to get it flying. Just when it seemed I would finish my second one, something else popped up. Especially when you make mods, and add detail. It is important to find a balance that makes YOU happy with the outcome. One thing is for sure, you will enjoy flying the DR1, especially after all of the work.
Great job!
Old 02-22-2014, 01:47 PM
  #225
R/C Ray
WOW!!! Just got back from the WRAM Show, you have got to see the Dr1 Triplane there! This plane was 1/3 scale, listed as kit/ scratch, Kookos to the builder! Drop dead gorgeous, the detail is unbelievable! If there is a chance to see this on the internet. Don't miss it!
Ray.
