Reload this Page >
Sig Spacewalker 1/3 scale (by rookie)
Old 11-12-2014, 08:40 PM
  #601
Leroy Gardner
"OH YEAH" finishing up the cussing stuff and on to the fun stuff. When you get into the cowl it's always interesting setting it up. fuel lines, choke, throttle, ignition and batteries often with limited room to work in. You'll do well, just like the rest of it. I think your on the road home, it's been a trip, you think.
Leroy
Old 11-13-2014, 02:58 PM
  #602
joebahl
joebahl's Avatar
I would always slow down for some reason when it came to the motor and servo connections . just not did not do it enough i guess and wanted everything to work smooth . I wish some of my old tools they use to make were still being sold to you new builders Keven ,they did not use plastic or cheap metal back then . My landing gear wire bender with two different size bending blocks from small wire to 5/16 and a bigger handle so you did not pull anything bending it. This is my small one made in the USA and you get the idea and could build one some day. Clamp the block in a vice and bend away but the ones i see now are plastic from china. joe
Name:	a  wire bebding tool.jpg
Old 11-14-2014, 04:45 AM
  #603
VincentJ
VincentJ's Avatar
Very cool Joe!
Old 11-14-2014, 06:10 AM
  #604
FlyerInOKC
FlyerInOKC's Avatar
The K&S bender is made in the USA and is all metal.
#323 1/8" and smaller
#326 bends 1/8" to 1/4" winder 1/8" to 3/16"
Old 11-16-2014, 03:37 PM
  #605
Melchizedek
Melchizedek's Avatar
Joe, Nothing like the old school tools. There were built like a tool should be built. Tim the Tool Man Taylor Tuff.
Mike, Thanks for the K & S post. I will need to get me one and then mod it to the Binford tool standard.
Well I have been working on the Top Notch Continental engine kit. When I saw it hanging out of Leroy's SW. I had to have it.
The Kit is outstanding in quality and well thought out. Worth every penny.
Started on the kit last weekend and finished it today. I then cut the holes in the cowl and made pockets for the engine.
The Pockets hold each engine half and isolate them from the DLE 55.
I will eventually glass the pockets to the cowl on the DLE side. This will permanently secure them and fuel proof them.
The walls of the pocket are Balsa and the back is 1/8 light ply.
I used the template that came with the kit to mark for the cutout. It allows for 1/4 gap all around.
I cut it to specs but wish I had made the gap 1/8 instead. I think it would have looked much better. Oh well.
Since we are talking engines. I ordered an EME 70 twin for the next build. Teaser
Kevin
Name:	m_Engine cowl 140 001.jpg
ID:	2047952   Click image for larger version
Name:	m_Engine cowl 140 003.jpg
ID:	2047953   Click image for larger version
Name:	m_Engine cowl 140 004.jpg
ID:	2047954   Click image for larger version
Name:	m_Engine cowl 140 005.jpg
ID:	2047956   Click image for larger version
Name:	m_Engine cowl 140 006.jpg
ID:	2047957   Click image for larger version
Name:	m_Engine cowl 140 007.jpg
ID:	2047960   Click image for larger version
Name:	m_Engine cowl 140 008.jpg
ID:	2047962   Click image for larger version
Name:	m_Engine cowl 140 009.jpg
Name:	m_Engine cowl 140 010.jpg
ID:	2047964   Click image for larger version
Name:	m_Engine cowl 140 012.jpg
ID:	2047967   Click image for larger version
Name:	m_Engine cowl 140 013.jpg
Old 11-16-2014, 04:20 PM
  #606
acerc
acerc's Avatar
Once you get the shrouds on the gap is not noticeable.
Old 11-16-2014, 04:34 PM
  #607
Melchizedek
Probably not going to do the shrouds. I really like The Harley Look.
I might do a beauty ring to dress up the cut outs.
Kevin
Old 11-16-2014, 04:47 PM
  #608
Leroy Gardner
Yes that is a pretty nifty dummy engine and I like the bare bones look. Don't be surprised if someone at the field asks what size is it, they look so real.
Leroy
Old 11-16-2014, 04:57 PM
  #609
acerc
acerc's Avatar
Kevin
I left mine open as well. But I also did not cut out such a monstrosity of a hole. LOL!!!
Old 11-17-2014, 04:45 AM
  #610
VincentJ
VincentJ's Avatar
I like it! I didn't think the opening was so large, am I missing something?
Old 11-17-2014, 05:59 AM
  #611
Melchizedek
Hi Vince.
I like the look too! That dummy engine in the nose gives the sw a look of realism.
I think Roberts just giving me the business.
I personally would prefer the gap to be a tight 1/8.
The gap at 1/4 is probably spot on for engine vibration on the model and the real 3/4.
Since my engine will be vibrating with the cowl and not contrary.
1/8 gap would yeald a nicer fit and finish. My preference.
Currently I am disposed to tightening up that gap. But that might change by the time I get around to it.
Kevin
Old 11-17-2014, 06:27 AM
  #612
acerc
acerc's Avatar
Lol!!
Old 11-24-2014, 03:40 PM
  #613
Melchizedek
Houston,the monstrous holes have been patched.
It was a tedious job but worth it. These engines will be a major focal point on this plane. So it was important to me that the holes not look like a whoopsy.
On version 1 the upper edge of the pocket was hallow. Left it that way cause of the complex shape and it really would not be seen.
But since I was wrapping the holes with 1/8 balsa I needed a solid wall (roof) to glue to.
First up was to fit a balsa block up in the pocket. Then I filled the remainder with a mixture of epoxy and micro balloons.
Then I wrapped each pocket with 1/8 inch balsa. The balsa was glued in place with slow cure epoxy. Once that was set it was sanded flush with cowl.
Once I was satisfied with the fit. The balsa ledge was sanded beneath the surface and then a slurry of epoxy and micro balloons was smeared over the balsa ledge and cowl edge.
Then it was sanded to the outer contour.
Bellow is version 1 on the left version 2 on the right.
Kevin
Name:	m_Engine pokets take 2 001.jpg
ID:	2049867   Click image for larger version
Name:	m_Engine pokets take 2 002.jpg
ID:	2049871   Click image for larger version
Name:	m_Engine pokets take 2 003.jpg
ID:	2049874   Click image for larger version
Name:	m_Engine pokets take 2 004.jpg
ID:	2049875   Click image for larger version
Name:	m_Engine pokets take 2 005.jpg
ID:	2049876   Click image for larger version
Name:	m_Engine pokets take 2 006.jpg
ID:	2049889   Click image for larger version
Name:	m_Engine pokets take 2 008.jpg
ID:	2049890   Click image for larger version
Name:	m_Engine pokets take 2 009.jpg
Old 11-24-2014, 04:15 PM
  #614
acerc
acerc's Avatar
I like the left one, just looks more like an engine in there. But the right one looks good also, just closed off.
Hope ya don't mind an honest opinion.
Old 11-24-2014, 07:21 PM
  #615
Melchizedek
No sweat Robert. Don't mind at all.
Was just my preference to tighten things up. I like tight tolerances on almost everything.
The other thing that was done on version 2 is, 1/4 inch was removed from the bottom of each engine half.
This was done to bring the dimension from port valve cover to starboard valve cover to the scale dimension.
Kevin
Old 11-24-2014, 08:06 PM
  #616
Leroy Gardner
Well now aren't you a crafty one, nice job closing up the gap. Must be where the saying, where there's a will there's a way came from. One thing you have demonstrated through out your build is getting things done and you are good at it.
Leroy
Old 11-25-2014, 04:30 AM
  #617
VincentJ
VincentJ's Avatar
Old 11-25-2014, 08:31 AM
  #618
FlyerInOKC
FlyerInOKC's Avatar
+2!
Old 11-25-2014, 01:24 PM
  #619
Melchizedek
Thank you for the kind words Leroy, Vincent, Mike, Robert.
You guys motivate a guy to press on.
Kevin
Old 11-26-2014, 05:55 PM
  #620
Melchizedek
To All who have been following.
From my home to yours. Happy Thanks Giving
Kevin
Old 11-27-2014, 03:09 AM
  #621
VincentJ
VincentJ's Avatar
Happy Thanksgiving Kevin!
Old 11-27-2014, 08:42 PM
  #622
Melchizedek
Got to spend a little time in the shop today.
Worked on the engine control linkage.
A few months back I had set it up for steel cable. Since then have read a few posts that this is not a good idea for gassers.
So I got some Golden rod from the LHS. Drilled the cable ways a little bigger to accommodate the casing.
Then It became clear that the choke lever was to close to the firewall to have room for the clevis.
After pondering it a little while. I turned a piece of maple into a 9/16 dowel. Then drilled a 1/4 inch hole into it to create a pocket for the clevis.
Then drilled a 9/16 hole in the FW and epoxied it in.
http://youtu.be/PfwK8llFmPY
Kevin
Name:	m_Engine Linkage 130 001.jpg
ID:	2050634   Click image for larger version
Name:	m_Engine Linkage 130 002.jpg
ID:	2050635   Click image for larger version
Name:	m_Engine Linkage 130 003.jpg
ID:	2050636   Click image for larger version
Name:	m_Engine Linkage 130 004.jpg
ID:	2050637   Click image for larger version
Name:	m_Engine Linkage 130 005.jpg
Old 11-27-2014, 10:11 PM
  #623
Leroy Gardner
Looks like that should work Kevin, one thing you might consider is the vibration effects on the nylon clevis which has a very small pin in it, (speaking of the throttle) it's a good place for a ball link with a safety washer on it to prevent it from ever coming off, a piece of cable with it's flexability might be a better choice connected to an easy connector at the throttle arm, it's very easy to adjust also. I solder a good inch of the cable where it goes through the servo connecter, it helps to prevent slippage and cable frays.
Just an idea to kick around.
Leroy
Old 11-28-2014, 07:40 AM
  #624
Melchizedek
Thanks Leroy for your suggestions. You always leave thoughtful posts, I so much appreciate you for that my friend
I probably will go with the ball link on the throttle arm. The swing puts just a smidge of a bind in the control arm. The ball link will eliminate that for sure.
Also will take your suggestion on making sure connector is bullet proof. Yesterdays shop time was focused on making the geometry correct and finding potential problems like the choke arm. Then cementing the tubes in place. The final tweaks will come at up fit after primer/paint.
It is interesting the school of thought on engine control linkages. Like I stated in the above post I intended on steel cable. This is what I am familiar with. But Some believe (if I am reiterating it correctly) that steel cable introduces the potential for the electronic static from the ignition/spark to get into the electronics and cause problems. I have no actual experience with this but felt it safe to avoid it (this is my first gasser) Having just tried the Golden Rod. I like it. It slides effortlessly. With the short throw, I don't anticipate any slop.
The other school of thought was the steel verses plastic clevises. The guys in my club don't like the steel cause they believe it is more prone to vibration issues. So they say plastic. Most of these guys are flying 60 size glow mostly. This is why I opted for the plastic. The Golden rod came with metal clevises.
The plastic ones in the above pics come with the fuel line snippets as a keeper so that the clevis does not separate. Also the metal clevises have keepers that are tiny and hard to handle and easy to loose (Balloonia) . I think that with the light duty of throttle/ choke the plastic will never fail and that with the rubber keepers will not vibrate apart or loose. Could be wrong on this though.
In any event, I will be going with the ball link on the throttle and keeping the plastic for the other 3 clevises.
One thing with having to remove the cockpit module to assemble and disassemble the plane. I will see regularly at least the servo side of the clevises.
And will make sure the carb side is bullet proof. Hopefully no missiles will be fired. Hard to make things missile proof .
Kevin
Old 11-28-2014, 07:52 AM
  #625
acerc
acerc's Avatar
Kevin, I completely agree that plastic is risky for throttle and choke be it gas or glow. The biggest issue is not so much the ignition or radio noise but rather the noise the metal can create itself at certain vibrations. I use the bolt on ball link type as seen in the pic, they are bullet proof. I would also like to suggest you get all these type things done prior to prime and paint in case something needs adjusting so as to not risk scratching or other damage.
