Electric Pattern Aircraft Discuss epowered pattern aircraft in this forum
e-Neptuno
Old 01-17-2010 | 11:37 PM
Default e-Neptuno
After many months of prototyping I finally received the production version of the e-Neptuno. It arrived safe and sound this past Friday afternoon. I will be using this as a build thread for the Neptuno. I'm currently building the glow Neptuno as well... so I'm building two planes at the same time. My hope is to have both planes ready in the next 3 weeks or so. Here are some pictures of the e-Neptuno and some weights of all the components. I'm the importer of the Neptuno into the USA - cost of the e-Neptuno is $1500 excluding shipping. It is a composite plane as you will see and it is a large bodied plane. Included with the kit are all the goodies one needs to finish the plane such as control horns, spinner, tail wheel, axles, pull-pull cable for rudder, etc.
Some pictures...
ID:	1358658   Click image for larger version
ID:	1358659   Click image for larger version
ID:	1358660   Click image for larger version
Old 01-17-2010 | 11:54 PM
Default RE: e-Neptuno
Some weights of the components...
Fuselage - 945g
Rudder - 55g
Wing tube - 40g
Left wing - 400g
Right wing - 410g
Left stab - 115g
Right stab - 145g (includes stab tubes)
Spinner - 95g
Wheels - 20g
Wheelpants - 30g
Landing gear - 105g
Accessories - 135g (nuts/bolts/screws/control horns/clevises/motor mount, etc.)
I'm estimating that with a Hacker 14XL and all servos, wiring, batteries, etc. the plane should come out around 4860g.
Picture of the accessories, stabs, wings, fuse front, wing mounting area (including adjusters), stab mounting area, fuse rear and the removable rudder.
ID:	1358664   Click image for larger version
ID:	1358665   Click image for larger version
ID:	1358666   Click image for larger version
ID:	1358667   Click image for larger version
ID:	1358668   Click image for larger version
ID:	1358669   Click image for larger version
ID:	1358670   Click image for larger version
ID:	1358672   Click image for larger version
Old 01-18-2010 | 12:05 AM
Some more pictures of the plane and interior...
Front half of underside of the canopy, rear half of the underside of the canopy, inside the nose, landing gear plate, exit holes on the bottom of the fuse, nose of the plane, crutch running down the fuselage, rudder servo mount, front nose of the plane without the canopy, rear exit holes on the bottom of the fuselage and nose of the plane.
ID:	1358684   Click image for larger version
ID:	1358685   Click image for larger version
ID:	1358686   Click image for larger version
ID:	1358687   Click image for larger version
ID:	1358688   Click image for larger version
ID:	1358689   Click image for larger version
ID:	1358690   Click image for larger version
ID:	1358692   Click image for larger version
ID:	1358693   Click image for larger version
Old 01-18-2010 | 01:25 AM
Gorgeous, a well thought out ship it would seem.
Is it on sale yet or is this the first production cab off the rank?
Old 01-18-2010 | 01:32 AM
It's on sale now... this is probably #5 or #6 that was produced.
Old 01-18-2010 | 02:08 AM
patternflyer1's Avatar
Nice Derek!
I actually put some of these pics in my article. lol
I want one!!!!!!!!!!!!!!! I'll know this week as I have to order something this week as I'm going on a cruise to Mexico next week.
Thanks for posting!
Chris
Old 01-18-2010 | 08:44 AM
rgreen24's Avatar
Hey Derek who is the maufacturer and do they hvae web site?
Thanks in advance
Old 01-18-2010 | 09:41 AM
Silent-AV8R's Avatar
I saw the nitro version up close at the AMA show in California last week. It is a very nice looking plane and the quality looked very good.
Old 01-18-2010 | 10:27 AM
hi
way is the Glow version more expensive???
Old 01-18-2010 | 10:53 AM
Because it weighs more. Holy cow, Dave was right[X(]. lol. jk obviously.
No seriously, the glow price came from Adrian. Not saying he isn't correct, but Derek will be able to tell us the glow price.
Chris
Old 01-18-2010 | 01:59 PM
ORIGINAL: rgreen24
Thanks in advance
The manufacturer is [link=http://www.jetlegend.com]Jet Legend[/link].
Old 01-18-2010 | 02:00 PM
ORIGINAL: Torben Parsberg
I'm assuming because it is wood built up, glass covered and painted. The EP version is composite.
Old 01-18-2010 | 02:26 PM
hi
thanks!![8D]
Old 01-18-2010 | 08:44 PM
Ok, so here goes with the build... I'm starting off with the back of the plane and I'll work forward. Why? Just because... Actually, I sent my 14XL in for service and I'm waiting for it so it doesn't make any sense to hold off on the build until I get it back so I'm starting at the back and my hope is that by the time the motor comes back I'll be ready for it.
The pictures pretty much tell the story... stab servo installation and control horn setup. I never made one modification or enhancement to the installation. This whole process took me about 20 minutes at the most per stab. Photos are:
1. The parts packets that will be used
2. Servos that will be used
3. Servo outlet on the stab
4. The stab root has foam covering which makes a tighter fit when the stabs are mounted to the fuse
5. Removed the covering over the servo box with an Xacto knife
6. Total weight of the servo and assorted bits and pieces - total weight of the left stab was 115g before any equipment was installed
7. Total weight of the control, rod and clevises
8. Servo trial fitted in the stab - as you can see there aren't any screw holes marked yet
ID:	1359215   Click image for larger version
ID:	1359216   Click image for larger version
ID:	1359217   Click image for larger version
ID:	1359218   Click image for larger version
ID:	1359219   Click image for larger version
ID:	1359220   Click image for larger version
ID:	1359221   Click image for larger version
Old 01-18-2010 | 08:57 PM
I then marked the screw holes with a fine point marker and used a heated pin to "burn" the servo mounting holes in the plywood brackets. In went the servo afterwards with the screws. Next step was to put the control horn in - I used the supplied bolt and associated hardware. I used a little Loctite on the threaded rod to ensure it stayed in place without backing out. The next step was to make up the control rod using the supplied ball link clevises. Everything is the right size and no cutting was needed. The only additional time taken was to ensure the rod was the right length and the stab was "flat" without any up/down trim.
Pictures are as follows:
1. Servo screw locations marked
2. Pin used to "burn" through the plywood to ease the servo screw access
3. Pin is heated
4. Holes made using the pin
5. Servo now mounted
6. Control horn for elevator
7. Partly screwed in
8. Screwed flush with the top of the elevator
9. Mounting the underside of the control horn
10. Adding Loctite to ensure the bolt doesn't move
11. Hardware mounted on control horn
12. Ball bearing part of clevis mounted
ID:	1359234   Click image for larger version
ID:	1359235   Click image for larger version
ID:	1359236   Click image for larger version
ID:	1359237   Click image for larger version
ID:	1359238   Click image for larger version
ID:	1359239   Click image for larger version
ID:	1359240   Click image for larger version
ID:	1359242   Click image for larger version
ID:	1359243   Click image for larger version
ID:	1359244   Click image for larger version
Old 01-18-2010 | 09:00 PM
Stab work continued...
Photos are:
1. Control rod completed
2. Servo arm installed
3. Control rod installed and showing the weight of the completed left stab half - 150g. We started off at 115g so we added 35g total with the servo and associated hardware.
4. Both stabs finished and joined on the stab tubes
5. Installed hardware
ID:	1359251   Click image for larger version
ID:	1359252   Click image for larger version
ID:	1359253   Click image for larger version
ID:	1359254   Click image for larger version
Old 01-18-2010 | 09:04 PM
Next step is the installation of the removable rudder and also the control horns, cables and servo. Here are some pictures to get you started... work on the rudder will start tomorrow and continue through the next couple of days. I'll take weights later...
Pictures are:
1. Rudder control horn and associated parts
2. Servo, cables and servo arm to be used
3. Everything in one picture
ID:	1359256   Click image for larger version
ID:	1359257   Click image for larger version
Old 01-18-2010 | 09:41 PM
hi
Because glow is better than electric ...
Old 01-18-2010 | 09:59 PM
woodie's Avatar
I think the moderator should ban Riot3D from even looking at the e-pattern posts!!!
Old 01-19-2010 | 01:46 AM
ORIGINAL: woodie
I know you missed flying glow, Woodie. Don't worry, I'll let you fly my Altair next time ...
Old 01-19-2010 | 03:51 PM
Jason Arnold's Avatar
Derek,
Not sure if it's my eyes or not but the roots of both stabs look a little rough in the photos. [:'(]
Also, why would you make the holes with a hot pin over a drill bit? [&:]
Cheers
Jason.
Old 01-19-2010 | 04:56 PM
ORIGINAL: Aussie_Knife_Edge
Hey Jason,
It's your eyes! See one of my earlier posts - the root is lined with foam that's why it looks rough. As for a hot pin versus a drill... personal preference (less messy) and also the one side would be difficult to get a drill in there since it is positioned slightly under the lip of the root.
Old 01-19-2010 | 11:54 PM
Did you fly it yet Derek? Did you? Good to see you building! U have a lot of projects!
C
Old 01-20-2010 | 12:00 AM
RC_Pattern_Flyer's Avatar
if that is building... i want to build my pentathlon that way! hahaha
Chuck
Old 01-20-2010 | 12:11 AM
ORIGINAL: RC_Pattern_Flyer
Hey, I'm "building" 2 planes at once - that should qualify for a wooden roach build...
