Go Back  RCU Forums > RC Airplanes > Profile and Fun Flying Planes
Engine for OMP edge? >
Profile and Fun Flying Planes If you're a profile fan or into fun flyers than this is the forum to discuss those topics.
Old 12-16-2002 | 04:24 AM
Default Engine for OMP edge?
I just ordered an OMP 40 size edge. What engine should I use for it? I have an OS SF .46 that I could use. Would that be enough power? or would I have to buy a 50 sx?
Old 12-16-2002 | 05:29 AM
Default You Know
You Know the answer to that.
Jess
Old 12-16-2002 | 05:43 AM
My Feedback: (33)
i ahve a tt pro .46 on mine and its more than pleanty.
just for reference
Old 12-16-2002 | 05:55 AM
Default Yea, it is enough
OS46 FX. Think it is enough?
Old 12-16-2002 | 06:02 AM
looks like more than enough.....I just don't know if the sf .46 has that much power.
Old 12-16-2002 | 06:09 AM
any ball bearing .40 size will work on this ship. Mine wieghs 4 lbs right on the money. Some are sub 4 lb. Its not that demanding of a ship. run what you brung.
Old 12-16-2002 | 06:20 AM
Ragz's Avatar
I have a spare OS70FS...I am planning to try this one out too. Mine weighs in at 3.7lbs. I have a apc 14x4w for this setup.
Anurag
Old 12-16-2002 | 12:25 PM
3.7 is pretty dang light. What servos do you use? I have standard BB servos that I plan on using.
Old 12-16-2002 | 12:55 PM
Ragz's Avatar
Im using 148's on the ailreons...hitec 225mg's on the rudder and elevator..and a futaba micro servo on the throttle...I use foam wheels, dura alimunium gears...also a spinner...with a apc 1225x375 prop.
An OS 70Fs will increase weight by 200gms. Approx 0.4lbs.
Anurag
Old 12-16-2002 | 03:10 PM
m.gramling's Avatar
My Feedback: (8)
Jess,
that picture makes me jealous.
Old 12-16-2002 | 04:22 PM
Default Thanks
Mike, thanks, I think.
My set up is HS-225mg all around. I have blown the motors on both aileron and the rudder servos.(Hitec replaced, no charge.) HS-81 on throttle. Started jittering, also replaced.
OS46fx for power. Had the bearings come apart in a low hover. It stayed running. Got it on the ground and let it idle(like an idiot)and my buddy and I stared at it and scratched our heads and said "wonder what happened?" Took the head off and there were pieces of the bearing case on the top of the piston. Sent it to hobby services, replaced for free. (My fault due to poor upkeep.)
Weight before lead. 3lb 13oz. After 4lb. Will build a replacement next year and mount the engine as per plans instead of upright.
Great profile.
Jess
PS Thanks to WGeffon for resizing these pics.
Old 12-16-2002 | 04:25 PM
I can't wait to get mine now.....
Does it fly somewhat like a big plane? is it really stable in high alpha stuff? My pro twister wasn't that great at high alpha rolls...
Old 12-16-2002 | 05:59 PM
My Feedback: (33)
mine is great for that kinda stuff, i love mine, mine is gettin beat up from playing to much, i ahve gotten now where i will flat spin all the way to the ground and land it that way but i just broke my landing gear so i ordered a set of krazy legs from tethrite.
thx
chris
Old 12-16-2002 | 07:10 PM
Default Mine is almost done!
I'm hoping it will be ready for next weekend. I have a 46FX and a 12.25x3.75 apc for it. I will try the standard muffler and see how that will go.
But I'm curious as to how a 52 OS 4-st will perform on it. I have a 12x6 a 12.5x6 and a 13x4w that I can try with the 4-st which btw is lighter than the 46fx with mufflers.
Anyone tried that small of a 4 stroke on it?. I know all about the 72 saito and what it can do in this bird but i haven't heard anyone talk about a 50 size 4 stroke.
Old 12-16-2002 | 07:50 PM
Jaco's Avatar
I have a OMP 540 on order. Plan on using a os 50 SX w/mac's black muffler. Is there anything I should look out for during assembly?
Old 12-16-2002 | 07:52 PM
if your going to run a lighter motor than the 46fx you will need to put mini servos in back or put the tail servos in the wing.
I have stock servos in mine and the motor is all the way forward. Im still working on balance. I rufuse to put lead in it.
Let use know how the small 4stroke works. That sounds like a good idea.
Old 12-16-2002 | 08:01 PM
the only thing i would do diffrent is put a chunk of wood in the fuse above the wing at the cg. Seems to be where i all ways grab it. Now the sheeting is getting soft there and i can feel it buckle. i would allso put some wood in for the aftermarket landing gear. Even if you plane on using the stock wire gear.
Has any body else notice that it harriers alot easyer with out any mix on the wing???( flaperon or spiolers )
I was having a hard time and tryed it without the mix and it was a LOT easyer.
Love the plane and cant say enough about it.
Old 12-16-2002 | 08:23 PM
m.gramling's Avatar
My Feedback: (8)
I saw vr1vrv2 fly his omp edge at propbusters field in memphis,
He was doing harrier rolls about 10ft above runway. And torgue rolling it inches above the ground. I actually saw him T-rolling a stock stick arf inches above runway. I got pictures.
He is one of the best pilot I have seen. Just about anybody can T-Roll a 40%. But it takes skill to get a .40size profile and a stick arf as low as he does.
I am a fan of his.
Old 12-16-2002 | 09:19 PM
My Feedback: (33)
i would also recomend a block of wood above wing( where canopy is) cuz that is also where i pick mine up and catch it out of air and it is sof t and balsa is weak there its hollow, i never used stock gear, i used alum. now i am using krazy legs
Old 12-16-2002 | 10:32 PM
I plan on using the sf 46 and all standard sized servos (futaba 148s) should I go ahead an put them in the tail? I really do not want to out them in the wing.
Old 12-16-2002 | 11:04 PM
ya stock servos are light ( 1.2 oz ) its the more expensive ( read more tork ) that are heavy ( 1.9 ) thats when you get in trouble. I have stock servos in the tail in mine and its fine.
Old 12-17-2002 | 12:46 AM
m.gramling's Avatar
My Feedback: (8)
Here is v1vrv2 OMP edge down low.
Old 12-17-2002 | 02:27 AM
i gotta get some pics of me flying. maybe soon the weather will break so i can get some.
Old 12-18-2002 | 01:19 AM
What about a Towerhobbies .46? Think one of those would do the job?
Old 12-18-2002 | 01:25 AM
The magnum .46 FSR looks like a clone of an FX .46 http://www2.towerhobbies.com/cgi-bin...?&I=LXBUX6&P=0
