Superstar folded
A fellow at the airfield had his hobbico superstars wings fold at the center after pulling up from level flight. We looked at the wreckage and two of the guys said their superstar planes had steel pins at the wing joiner and screws holding the vert. fin on. This one didn't nor did it have any way of putting pins or screws in. He said it's a new ARF but is it possible he got an older version off the shelf before they made strength improvements on th plane? Were superstars known for folding at the wing joiner?
Mark
Mark
FL
Trainers always get subjected to high-G pull-outs. That's the nature of training. I don't know why so many ARF trainers have wings that are so heavy yet weak. Really bothersome.
Some earlier versions of the Superstar had the wing halves permanently joined with a sturdy wood joiner epoxied in. For extra support a thin metal strap could be screwed across the joint back near the trailing edge. Others have also fiberglassed the joint. Makes for more inconvenient transport but there is more strength. Either way, avoid those high G manuevers.
