 Strange Servo Behavior >
Old 10-06-2004 | 02:02 PM
My Feedback: (12)
Default Strange Servo Behavior
I'm trying to get a new Funtana 40 to fly reliably, however I've run into an odd servo problem, at least I think it's a servo problem, perhaps someone else has seen this before.
The behavior is this....at the limits of range testing the radio equipment, everything is stable except that when I activate the rudder, the aileron's will twitch. Doesn't happen up close. Additional info, rudder and elevator servos in rear of fuse, both Hitec 85MG's, aileron servos both Hitec 605BB's, receiver Hitec 555 (has been swapped out, no change) transmitter is Futaba 8UAF. Battery is a new 5 cell NiMh. Like I said, this is what happens on the ground, however, the last time I flew the plane, it really had some strange behavior, and I'm lucky to have landed it safely. So I swapped out the receiver, but I don't think I fixed it. I've also checked for any mixes I might not have known I had, but found nothing.
Anybody seen this type of thing before?
Sotos
Newport News, VA
Old 10-06-2004 | 02:12 PM
Default RE: Strange Servo Behavior
It depends on what you class as 'the limit of range'. My Futaba instruction book recommends 100' as the maximum (with AE down). I have tried going further away and have at 150-160' experienced the same as you, servo's fluttering when another channel has been operated. However it has (touch wood) never affected the flight handling.
Old 10-06-2004 | 02:27 PM
My Feedback: (12)
I'd estimate that this ocurrs somewhere between 75' and 100'. Also, we were comparing transmitters at my field the other day, with the 8UAF, the antenna goes completely inside the transmitter, nothing but a button sticking out, a buddy's older Futaba only collapsed down to the last segment, leaving at least 6" of antenna still exposed. That's gotta mnake a difference.
