Official Mayhem Thread
#927
AZ
The blues are lighter than the purples by a little bit. They will provide later engagement, and thus more aggressive launch. I ran the blue ones before I got my Mugen shoes, and both seemed similar in performance.
#928
I swear, I give up. YOU ARE RIGHT. Now I screwed up. I bought JP2 for my buggy thinking it would give me better throttle response.
Sorry for my behavior.
"Downtroddin" Rockman
#930
ORIGINAL: Rockman
JP-2 is a very good pipe when you combine it with some top end engines.
Jay Halsey use this pipe on his car.
Greg degani also use this pipe.
i believe in the straight line you'll be hungry for top speed, right ?
if i can say, you'll get linear power with this pipe
#932
FL
hey i was at the track for the first time today and everything was goin good.. and after about 10 laps it went out of control and then i was able to control it.. brand new duracells, battery pack wraped in electrical tape,no losse conections of anykind.. ill start it up and rev it about half way and then itll go by its eself then idle down.... i put a new throttle servo in and still does it.. the guy at the track really never saw that before, he said it might be the cyrstals in the reciver afetr thoses hard hits might have srewed it up...it only does this when motor is running... im clueless??? any ideas.. thanks
#934
No doubt its the crystals I had a set go bad on me and same type of problem not exactly but close those crystal are very fragile and they have a very thin wire like a fuse in them that breaks easy.
#936
My Feedback: (14)
NY
ORIGINAL: the geek
Planning on getting a mayhem.....
What upgrades should i get first??
Get the freakin car first, drive it, then decide! It needs no stinkin hop ups! LOL
#938
OK,Great choice ,you will really enjoy your new Mayhem ! This is my answer to your question about what to buy next. Rechargeable batteries for transmitter and car, a fail safe,a good set of tools,after run oil ,and locktite(red + blue). Above all read everything you can get your hands on about R C breakin and maintance. Take the best parts from all the information out there in mags and internet and use alot of common sense .Have Fun with it ;it's a great hobby!
#939
FL
hey i got a quik questiuon.. i dunno if anyone have a savage but i need help adjusting the 2 speed. rather the 3 speed.. i just got it and it doesnt shift at all and that engine gets very hott by not doing soo.. any ideas??
#942
I wasn't being anything You wouldn't go to Mcdonalds for A taco So don't ask questions that don't relate to this board Is all Don't be such a girl and take it personal. Try this link I did your homework for you... Your Welcome
[link=http://www.hpisavageforum.com/forums/]HpiSavageForum<-- For lazy people[/link]
#943
hey guys, please .....
mayhem madness, check your internal 3 speed clutch, it might be worn or something.
read your manual. multi speed tranny have it adjustment point according to your need.
for speed number 3, you must lean your engine enough to get power of last shifting.
OR, your one way bearing in the tranny broken (like mine ... last time).
That's why i never want to deal to 2 or 3 speed anymore. they kinda complicated to set and maintain also.
hope this could help
#944
ORIGINAL: the geek
pro or RTR ?
PRO doesn't need anything to upgrade unless you like some cosmetic parts like graphite this and that ...
And the RTR Shocks Tower need to be upgraded with the pro part (the stock one could easiliy bent) ...
hope this help
#945
brian kadows..
FRONT;
DIFF 5000
SHOCKS 70WT STOCK PISTONS
RED SPRINGS
OPTION FRONT TOWER MID HOLE
OUT ON THE ARM
UPPER ARMS MOVED FORWARD .080
OPTION ACKERMAN PLATE REAR HOLES
CENTER;
DIFF 7000
STOCK BRAKES
REAR;
DIFF 2000
SHOCKS 50WT RED SPRINGS STOCK PISTONS
STOCK REAR TOWER UPPER MIDDLE HOLE
IN ON THE ARM
1 1/2 OPTION ANTI SQUAT SHIMS
3 DEG TOE
HUBS CENTER
HIGH BITE TRACK RUNNING C-SWITCHES
FRONT;
DIFF 5000
RED SPRINGS
OUT ON THE ARM
CENTER;
DIFF 7000
STOCK BRAKES
REAR;
DIFF 2000
IN ON THE ARM
3 DEG TOE
HUBS CENTER
#950
FL
hey guys.. im looking for some upgrade parts for my mayhem but dont know what to get.. here are my options.. tuned pipe,cooling head,high torque steering servo,mugen clutch assemble....thats all i could think off.. whats the first thing ya'll upgraded??
