official smartech buggy thread
#551
MO
What is a very small amount and how long was it left?
I hope someone has an answer for him as this has been one of my concerns as well. (how long can you and how "empty/dry" does it have to be?)
#552
well I've left fuel in my tank for a like a week stright b4, it was like half full... No harm done, and that was a couple weeks back and shes still runnin fine
#553
god! lol i always leave fuel in my tank, even if im working on the car, i put large screws in the pipes so fuel doesnt leak everywhere.
Ryan.
Ryan.
#556
ya the nitro is bad for rubber and plastic
dont spill any on the brake. upgrade to a metal one if you can.
once again i will profess my love for this cheap buggy. $1.99 for two front knuckles. how can you go wrong. and my engine has been very reliable. having to tune it every time i run it is horrible. but other than that it fires up great.
http://www.excelhobby.com/excel_hobby_027.htm
anyone recommend some tires??? beefy like ryans but not actual truck tires. I want to keep it looking like a buggy. thanks guys
#557
MO
CHARGING THE BATTERIES IN THE TRANSMITTER
Can I charge the Batteries in the Transmitter with an adapter like this? http://www.radioshack.com/product/in...entPage=family
It says for 10V. THe 8aa's would be 9.6v. And there is a small plug outlet on the transmitter that I can't think would be for anything else.
It's kind of a pain to take them out and put them back in
THanks
THanks
#558
Only charge batteries in the transmiter with the charger supplied. Using a different charger with your transmiter might damage it. It doesnt take a lot to take them out and charge them in a battery charger.
Ryan.
Ryan.
#561
yea, there is a little round port for a charger in the smartech controller (the one with the gold rim and tyre for the digital steering control on the controller). The port is right next to the on/off switch on the side
#563
Hi guys
This ones for the the UK posters. Has anybody seen the smartech buggy, truck & touring car for sale in the gadget shop yet????? i couldnt belive it when i saw it!!!!
#564
nope i havn't seen it andy[X(]....how much was the buggy?...and was it a two speed or one speed?..oh yeah.....do they do spares?
#567
Expensive!! as for the parts from the shop, they will probably buy parts from www.excelhobby.com and then beef up the price.
Ryan.
Ryan.
#568
MO
OK - Please help!
It seems like my car is only getting harder and harder to start. This last time it took about 50 pulls to the starter cord to get it to run. Once it does it seems to start up better but not always. When I first got it it took a few pulls
My air filter is clean.
The idle is set good
The main needle and micro needles I'm not sure of.
I guess the things I'm wondering about is -
Am I priming enough fuel to the engine? I pump it just till it gets to the carb and then pump once more. I have been afraid of flooding it
OR - is the cord not working right? It seems when I first got it it was very tough to pull at times. Now at the toughest point it is just enough to make it "grind" a few times (a short gurgle sound almost or clearing your throat.) Is this not enough resistance and do I need to change or clean the bearing or whatever it is?
The glow plug is new and getting hot enough (I even checked the old one and it glowed right away so the new one should be fine).
Please hlep - I am gettin gtired of pulling 50 times + to get this thing going
Thanks again guys
Thanks again guys
#569
MO
One other thing. I got this fuel filter http://www.globalhobby.com/public/xt...ery/148051.asp
How do I know which way to install it? It didn't say in any kind of directions. The car ran either way. The inside looks something like this image
#570
Hi everyone, i just bought a smartech winner sport and after two days i broke the left rear fender...part no. 114953...and i can't seem to find it anywhere! rcmart/dinball don't have the part, so i'm stuck! does anyone know where i could get this part from?[&o]
#571
trpastor - Check your glow plug, even if its new, it could still not get hot enough because the coil inside might be different to your old 1. So put in your old glow plug and try it. As for the hard pull starting, you might be flooding your engine.
abray84 - Do you mean you've broken an A-arm? anyway here you go http://www.excelhobby.com/excel_hobby_024.htm
Ryan.
Ryan.
#572
] my buggy is not staying idle.....and my controller trim is set right....and also the engine gets to hot ...and when i give it throttle the engine starts dieing...
so can anybody help and could someone please post the pages of the manual which show all the engine needles (all 3) and how to set them because i just realised i have lost it[:@]
why is it when u need something....it goes missing[:@]
] my buggy is not staying idle.....and my controller trim is set right....and also the engine gets to hot ...and when i give it throttle the engine starts dieing...so can anybody help and could someone please post the pages of the manual which show all the engine needles (all 3) and how to set them because i just realised i have lost it[:@]
#573
CA
trapstor- is your cooling head all the way on, because that happened to me and it wouldn't start for a very long time. My manual says pump fuel to the carb. and then pump twice more. you can always pull the throttle back spray some wd40 in to help ignite the engine, it might work.
e_v- i will try and post the pages from the manual this weekend. You should also see if your controller is on reverse because when you are pulling the throttle it is just hitting the brake causing it to die, it happened to me.
#574
CA
trapstor- sorry, spray the wd40 in to the carb when you are pulling on the throttle, and only do it when its not starting or else when you spray it while the engines running it might make a big ball of flame
#575
hey zachanafien... thanks but its ok now ....andy sent me the pages i needed...but feel free to do it because some1 else might need it in the future e.g. me
if i accidently loose the file on my pc
