Official Rustler Thread
#8401
RE: Official Rustler Thread
ORIGINAL: hindupimp2384
Hey
I want to know what are some great tires for Concrete and/or Asphalt, and also good all Terrain tires. Links, product names/item and anything that will help me find the tires. And also i do alot of barrel rolls what can i do to stop it or limit it. and also some good shocks. My car is the Rustler in the Vid above.
Hey
www3.towerhobbies.com/cgi-bin/wti0001p
#8402
NY
when i said the green light is in the stock wall charger , and no neither the wheels nor do i have changed the batteries in the radio , have been using it for around 3 months , but the runing time in total of the rustler is around lets say 4 days ( divided in 25 to 20 min runs ) so that would aprox be around 2o times iv used the rustler with trhe same batt in the radio
#8403
if your motor is spinning but your tires arent then check to see if one of your hubs or rims is stripped out.
from there go to the pinion and spur gear, see if either of those is stripped or is missing teeth.
it's all a process of elimination
#8404
the screws that hold the motor in could have come loose and it backed the pinion gear away from the spur gear. that happened to mine.
#8405
So guys another video is up this one is more extensive [youtube]http://www.youtube.com/watch?v=eCIQF407Y4o[/youtube] let me know what you think of the handling. 11min 34sec long video.
Do you have a infrared temp gauge? Good temps are around 150F upto 165F and to the touch it feels hot 'really hot' but this is the perfect running temp for brushless motors. Shreading your tyres? The tyres are not good quality and/or the internal foams are bad and you get too much distortion under throttle. My 1/8 buggy tyres have taken a beating and all the halfshaft twiting, snapped yokes and snapped stub axles prove the amount of torque the 4s setup is throwing to the tyres these are my tyres. Moulded foams very durable tyres awesome grip and great wearing.
ProLine Dirt Hawgs are the best all rounder tyre road and off-road is great but word of warning if your setup is powerful this is what will happen to them . "Pizza anyone"?lol. I recommend getting tyres and wheels not preglued on and tape the inside of the tyres to help keep form under acceleration. But for more stock setup these will be fine. My 1/8 buggy wheels are the best I love em.
A small dab of thread lock 'just a small amount should help you.
Dude the 3s on the SV2 sucks its raises the heat super fast even at 14/90 gear and shreads my tires.. 2s LiPo are the best at 14-19/86-90 gearing.
And Yes am still using the plastic yokes, halfshafts and stub axle
Hey
Hey
ORIGINAL: Karontu
hey guys, i'm having trouble keeping my tires on my rustler, i run a 3s and it seems every time i run it i'm tightening the lock nuts down, any tips on what i can do to keep em on?
#8407
ORIGINAL: thehuntingterminator
i got some bearings and an RPM bumper today, and thinking about getting a diff locker too, since i stripped the plastic diff.
#8408
it was the fully plastic one. i have 2 more, but i might just spend 15 bucks and get a steel locker that will give me more traction and never strip.
#8409
MO
TIREINSERTS
http://cgi.ebay.com/ws/eBayISAPI.dll...=STRK:MEWAX:IT
[/b]
[/b]
Let me know what type of rims, i dont want the to keep breaking from jumps, rocks and everyuse.
and is that Tire insert good, do you recommend any better.
[/b]
Pro-Line Road Rage 2.8 (30 Series) Street Truck
cgi.ebay.com/ws/eBayISAPI.dll[/b]
Pro-Line Dirt Hawg 2.8 (30 Series) All Terrain Truck
[/b]
#8411
MO
REVISED
TIREINSERTS
[/b]
[/b]
Let me know what type of rims, i dont want the to keep breaking from jumps, rocks and everyuse Also 2.2" or 2.8" Tires? and is that Tire insert good, do you recommend any better.
[/b]
TIREINSERTS
[/b]
#8412
REVISED
TIREINSERTS
[/b]
[/b]
Let me know what type of rims, i dont want the to keep breaking from jumps, rocks and everyuse Also 2.2" or 2.8" Tires? and is that Tire insert good, do you recommend any better.[/b]
REVISED
TIREINSERTS
#8413
have you looked at the hpi geolander tire i have them on my nitro MT2 and i had them on my other rustler before i sold it and they worked great.
Think about it
Think about it
#8414
NY
ok installed new batteries , charged again the nimh batery with the stock charger ( its the only one i have and until now seems to be functioning right , takes time and is slow but charges ) by the way did not charge much around 2 min and then the red light from the charger turned green , because by the way it was already charged before but yust in case gave it a little juice . cheked the pinion gear was ok on the spur gear ,the sliper nut was ok the battery srews were on their place every thing was ok , but still the motor did not didnt work it only made that whimmmm whimmmmm sound , so i took out the the motor and and conected to the battery turned the pinion by hand and turned so nothing seems stuck on it , so then gave on the throtlle and still that whimmm whimmmmm sound looked at it closely and the motor looks as it wants to turn but does not turn so i gave it a little of finger spining to get it runing gave on the throtle and the it turn by it self , its like it needed a manual start : P jejeje to work , but it did not do that before , what could the problem be ?????? the motor is a stock brushed titan motor , pleaseeee would apreciate your help : (
ps my rustler is a XL5 basic not the vxl and its a brushed motor with blue XL5
#8415
NY
#8416
Worn brushes is my guess connect the battery directly to the motor should spin full throttle if still same problem then motor faulty prob brushes buy new motor if it spins full throttle then your problem is most likely a dud ESC (XL5). hope this helps
#8417
NY
ORIGINAL: Aljo
#8419
Banned
PA
#8421
ORIGINAL: computerkid
ok when you say conect the battery directly to the motor , which lead wire of the motor should i conect first to the battery the red one or the black ???????
ORIGINAL: Aljo
#8422
ON, CANADA
Just a note to all make sure your antivirus and maleware software is up to date the site been under attack lately if you have not noticed the admin knows about it and have been trying to stop it. There is a thread open to report the threat so just let them know there so they can take the right mesures to stop the threats.
#8423
ORIGINAL: Muskokarc
#8424
MO
www.suku.info/index.htm
www.ionz.info/index.htm
www.tuow.info/index.htm
^^ these are the virus on this site lately.
#8425
OK so I received my MIP Duty-X CVD kit and a BIG problem has reared it's head. The kit is not long enough for the ProTrac A arms (2nd from furthest right picture). But the Traxxas Nitro Rustler Rear Suspension Arms are shorter and will fit them perfectly and I keep my toe in but loose some width (Furthest right picture). A bit disappointing but for the power I am running I have no choice. *sigh* oh well report back when all fitted.
I have ordered these http://www.integy.com/st_prod.html?p...44&p_catid=109 they widen the stance I just need it for the rear, I know Integy is not the best but I don't know any other option.
The shortest one of the Integy pack will do, my current ones are a pretty large offset here is how the offset is at the moment Pretty dramatic but it drives well took it out didn't get any footage worth uploading hope to have some soon from a track run. Needs to be cleaned Here is the running weight of the car so far also here are some changes I completed last night this is the car after paddock bashing today needs a good clean. Here is the car before I took it out for a bash it was ready for action, hehe
I forgot to put the MIP stickers on will do it after all is clean. Test run went 100% fine though I left the slipper the way it was before just to break it in but will be tightening it up next.
