Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > RC Electric Off-Road Trucks, Buggies, Truggies and more
Reload this Page >
MM Esc + Velineon motor thread. (Problems, and solutions)
RC Electric Off-Road Trucks, Buggies, Truggies and more Discuss electric RC off-road, buggies & trucks here. Also discuss brushless motors, speed controllers aka ESC's, brushed motors, etc
Old 05-19-2008, 08:31 PM
Redvanmafia
Default RE: MM esc + Vxl motor question thread.
I may try this, to see what this Velion is all about, compared to my 7700 can the motor hook right up to the MM esc?
Old 05-19-2008, 08:32 PM
Nik.
Nik.'s Avatar
the vxl motor will not be fast. its only 4200kv(?)
Old 05-19-2008, 08:34 PM
Hardin Valley Magic
Hardin Valley Magic's Avatar
I believe it is 3500.... Could be wrong though...
Old 05-19-2008, 08:37 PM
Redvanmafia
No it wont be (3500kv), but aparently in stampedes and rustlers it runs 70mph
Old 05-19-2008, 08:47 PM
Nik.
Nik.'s Avatar
they only go fast because of super high voltage lipos and mega tall gearing.
a mamba would be even faster with the same battery/gearing, we are talking 120~ here. The motors will keep winding out untill it reaches about 90 thousand RPM and the rotor shatters.
Old 05-19-2008, 08:53 PM
  #31
Redvanmafia
exzactly, so i think i'll sick with my mamba
Old 05-19-2008, 09:58 PM
  #32
Always Dreamin
ORIGINAL: Nik.
Ya, the MM couldn't keep that tall gearing for more then one speed run. If that. It will explode. It's top end vs low end. The low end can be just as fast, you just gear up. I have never seen a MM owner gear their MM even close to what I can gear my vxl.
The vxl is 3500kv.
Old 05-19-2008, 09:59 PM
  #33
Always Dreamin
ORIGINAL: Redvanmafia
No it will not. The vxl uses 3.5mm plugs and the MM uses 4mm plugs. You need to find some way to get around that.
What vehicle would this setup be in?
Old 05-19-2008, 10:23 PM
  #34
Always Dreamin
All I have on hand is a 30 watt solding iron. Will it work?
Or will I have to buy my own 60 watt?
  #35
Redvanmafia
stampede,
Old 05-19-2008, 10:29 PM
  #36
ohgrfreak
ohgrfreak's Avatar
I couldn't think of doing r/c stuff with a 30 watt, definately go 60.
Old 05-19-2008, 10:36 PM
  #37
Always Dreamin
stampede,
The vxl does great in a Stampede. I must say. Do you have one sitting around? Or were you talking about BUYING a vxl motor?
Let me just give you an example. What do you gear your MM (whatever the kv is here) motor?
Old 05-19-2008, 10:38 PM
  #38
Always Dreamin
ORIGINAL: ohgrfreak
My dad says "it must be crimped on". I keep telling him, no, it's only a 30 watt iron. He will not allow me to buy MY OWN 60 watt iron. I need to prove to him that his little 30 watt will not get the job done. I will wate until I get more replies then show him.
Old 05-19-2008, 10:44 PM
  #39
Nik.
Nik.'s Avatar
look, a 30watt iron wont cut it. you will have cold joints and solder everywhere. Pick up a weller 40W or higher, or just go to radio shack, you can get cheap irons for like 5 bucks there.
Also, be sure to use 60/40 rosin core solder and use heat shrink tubing. tin the wire and the connector, slip the wire in and heat them together. If you cant do it your LHS should be able to help.
Old 05-19-2008, 10:46 PM
  #40
ohgrfreak
ohgrfreak's Avatar
crimped on, lol. if you have a poor connection, you have poor power, it's just that simple. if your father can't see that, then hey, they're only 7 bucks or so for a hobbico brand iron, if you can get to your local hobby shop, grab one up for yourself, I'm sure you can scrape up 7 bucks ish.
Old 05-19-2008, 11:00 PM
  #41
Redvanmafia
right now 17/86
Old 05-19-2008, 11:07 PM
  #42
Always Dreamin
right now 17/86
Thats high for a 7700kv! I'm geared 23/86, but I thought you would be geared much lower. If you don't have one, it's probably not worth you buying one. They do perform great though. Never trust anyone when they tell you that it's SLOW because it's a low Kv. It has more power then most people can handle.
Old 05-19-2008, 11:10 PM
  #43
Always Dreamin
What batteries are you running? Also, what's your temperature after a run?
Old 05-20-2008, 11:08 AM
  #44
Redvanmafia
Trakpower 4900 2s, It levels off in The mid 150's (motor), esc is 120ish battery doesnt go to much over 100
Old 05-20-2008, 06:17 PM
  #45
Always Dreamin
Update.
I have just ordered myself a 60 watt soldering iron. (hobbico)
I checked out the Wellers, and they are pricey! I also picked up some rosen core solder.
Just want to make sure it's the right one.
It's 40% TIN 60% LEAD ELECTRICAL SOLDER. Hope it's the right stuff.
Old 05-20-2008, 06:20 PM
  #46
SavageX78
SavageX78's Avatar
The solder should work. Ive heard you can use either 60/40 or 40/60. I use 60/40. But as i said what you got should work for ya.
Old 05-20-2008, 06:30 PM
  #47
Always Dreamin
I thought I remembered 60/40... 40/60 was all they had.
Old 05-20-2008, 06:32 PM
  #48
SavageX78
SavageX78's Avatar
ORIGINAL: Wipe Out
Ya Im sure it will still work.
Old 05-20-2008, 06:34 PM
  #49
Nik.
Nik.'s Avatar
60% tin and 40% lead solder.
Be sure to get a chisel tip for your iron.
weller pencil irons are not really that expensive, look at Hakko soldering stations (but they are NICE!!!)
Old 05-20-2008, 06:35 PM
  #50
Always Dreamin
I have never soldered before, so I just want something that will get the job done easily. Is there anything wrong with what I got?
