Go Back  RCU Forums > RC Airplanes > RC Flight Simulator Software
Aerofly Pro Interface for USB? >
RC Flight Simulator Software Discuss rc flight simulator software here. Aerofly Pro, RealFlight G3, XTR, Reflex, etc.
Old 08-15-2003 | 12:58 AM
Default Aerofly Pro Interface for USB?
Is any one using Aerofly Pro adapted to a USB connection? Just ordered this sim and from what I read the interface to use my own Tx connects to a nine pin serial plug. I have that on my desktop but would like to use it on my laptop (maybe practice a little at work when the boss isn't around). I'm using a 2.4 gig Compac Presario but it only has 2 USB and no serial. I'd probably need a USB driver from Ikarus I guess. Any suggestions?
Old 08-16-2003 | 02:04 AM
I'm in the same boat here with the port problems.
I am getting ready to order a "USB to Serial" adapter cable from Newegg.com, $22.99 with shipping. It comes with the necessary driver for the adapter according to the photos on their site.
Go to their site and do a search for it and you will get to see it.
Found on locally but they wanted $40 for it so found this one at Newegg. Buy all of my computer stuff from the and real good products and service. Usually if I order on Sunday night I have stuff on my doorstep on Wednesday night. They are in CA and I and in Indiana.
Just my $.03 ( used to be .02 but inflation you know)
Old 08-16-2003 | 08:10 PM
Default Prabably, adapter will not work...
Gentlemen,
Before ordering any "USB to Serial" adapters, contact the sim manufacturer and verify that their cables will indeed work with such adapters!
I am almost sure that AFP cable will NOT work with "USB to Serial" adapter. The cable, besides carrying/converting the signal from the transmitter to the PC, also serves as a copy protection device, a "dongle". Such devices are programmed to access the hardware at very low level and may not work with a "virtual" serial port of a USB adapter.
I'll be gald if I'm wrong.
Old 08-19-2003 | 09:29 PM
Default Re: Prabably, adapter will not work...
Originally posted by bluesky123
Gentlemen,
No, your not wrong.
I bought a usb adapter and no joy. Same problem, serial at work, usb at home.
No joy from the manufacturer either.
Regards
Rob
Old 08-19-2003 | 09:49 PM
I think you are wrong I have got a usb to serial convertor set to com3 and my AFP interface was found by the software without any trouble.
Old 08-20-2003 | 03:31 PM
I also use a USB to serial adaptor on my Laptop and it works fine. It did not initially... as the adaptors software set it to com9 as the default. Changing it to com3 fixed the problem.
Old 08-26-2003 | 04:55 PM
Default USB Adapter
I don't want to turn my original question into a debate so I'll just add this:
I contacted Ikarus with my question and promptly received an answer from Mike Fontinini of ikarus-USA. He informed me an adapter will work and recommended one with the manufacturer's drivers included.
Bought a Radio Shack 6 ft. USB to serial cable (part # 26-183) and it works fine.
I was flying the AFP f16 at work and the boss had to give it a try untill it crashed on takeoff, then it was, "turn that off and get back to work".
Thanks all for the input (pro or con). This is how we learn new stuff.
Old 08-31-2003 | 02:00 PM
What are the adapters that everyone is using with AFP, aside from the RadioShack one already mentioned?
Old 08-31-2003 | 07:52 PM
I need an adapter for the dummy Tx (15 pin to USB). All RadioShack had was a 9-pin to USB which would work with the interface cable. Anyone using a USB adapter for the dummy Tx (Game Commander)???
Old 09-01-2003 | 01:14 AM
patternflyer1's Avatar
Default radio shack 15 pin
I just bought the usb 15 pin adapter at radio shack. The number is 26-164 Game Port USB Adapter. I can't get it to work yet though. Don't know if it's compatible with my Windows xp. We'll C!!!!!! Hope this helps vroom
Old 09-01-2003 | 02:03 AM
Is that the one with a 4 position slide switch on it? If so, I already tried that and it didn't work because it doesn't come with any driver software.
I guess basically RadioShack has the right adapter w/o software, or the worng adapter with the software. Anywhere other than RadioShack that anyone got theirs at?
I also downloaded the upgrade on the Ikarus website to supposedly allow the use of USB, but with no luck.
Old 09-01-2003 | 02:31 AM
Yeah, 4 position slider. I have it onnumber 2 joystick a. I figured out how to get it working. Had to go into the transmitter menu on realflight and change it from the standard controller to usb using; simulator settings, controller, controller setting. Hope this helps, I just bought it today and it's working now. Good luck
Old 09-01-2003 | 02:33 AM
Forgot;;;;; Mine didn't come with software, as I said I'm on windows xp and it loaded automatically, no software needed. Also I just checked in the directions and it says no sofware needed. Hope this helps too...........
Old 09-01-2003 | 04:44 AM
you said RealFlight... I need it to work on AeroFly Pro... any luck on that sim?
Old 09-01-2003 | 11:15 AM
My Feedback: (15)
Yes, Aerofly pro will work with Windows XP and a USB port.
I purchased a used Belkin Serial/USB adapter on Ebay for $6.
It worked great on my laptop - Compaq 910, AMD 1.5, Radeon mobility. Being a senior I am very computer challenged!!!!!!!!!!!
It took several weeks of communication with RCU and Ikarus, Germany before I got it operating. When I finally got it installed and working I decided it wasn't worth the effort and sold it!!!!!!!!!!!!
