C-ARF Ultra Flash build Thread + Video
#4226
Does anyone know if the Behotec C40 electric gear with its struts will fit the UF? Would there be significant modification to be done to the retract rails? I understand the C36 electric sets are a better fit but have thinner struts. I have the opportunity to purchase a C40 all electric set with a direct drive steering servo.
Any advice would be appreciated.
Mike
Mike
#4229
Mike
Answered PM. Don't think they will fit. The C-36 are more than up to the job. My Classic flash had 300+ flights from grass and are still going strong!
Dave
Dave
#4233
Stan
Depends on throttle use, people are on the throttle way longer than needed and the turbine uses a lot of fuel wide open.
I guess 100oz would give 6 1/2 minutes mixed flying
Paul
Yep, pretty good. customer collected and he's very happy. P-90Rxi going in this one
Dave
Paul
Dave
#4236
My Feedback: (57)
A buddy's & my Ultra Flash at the Big Apple Jet Ralley today. I modified my bypass with cheater holes for my K-180G, & also added drop tanks with blue lights in front & red in back. Still need to vacuum form some aerodynamic clear covers for the fronts. I'm convinced this planes flight characteristics can not be surpassed! They truly cut through the air like a knife.
#4238
Nice pics BlueBus320.
My UF flies great with a 100 in it. 180 must be insane
Would love to see it in action.
Paul.
Paul.
#4239
today i maiden my Navy ultraflash,3 flights to set everythingh to my taste.i bought it used from my friend.just 40 flights more or less,i installed k170,itīs a rocket.very light setup.two electrovalves for retract and brake,2100 mah life and hd switch.2100 mah life 9.9v for turbine very forward.no lead needed to balance.75mm flap,6mm crow, 5mm down elevator.smooth setup.lands like a dream!!! i love crow!!
#4240
How many flights can you safely do with those rx packs?
#4241
i donīt know ,i didnīt charge it yet,LoL.i was flying this 9.9v pack on the k100 and consumed around 800mha after 3 flights,today iīll charge rx and turbine batteries and i tell you
#4243
That's old school turbine with pulsing cooling, Ni pack? external Kero burner?? etc. the Bus RX type turbines and Li-Fe cells are way lower on current draw.
I always run my turbines manually to their coolest rpm before shutting down, cutting off at idle will take way longer to cool...plus we are 25 degrees on a hot day!
#4246
well i donīt fly much time,couse i have a 2lts tank,i set my timer to 6 min when i retract + 1min start-up + 1 min to landing aproach=8 min running time.at this moment iīm charging rx battery to check capacity, hope thereīs not surprise,heheh.
itīs also very fuel efficient,always 400cc left.
#4250
I usually run two life's I had the 3200 packs but sold another plane with those packs.
What at you guys using for turbine packs? I'm looking for something slim that can fit I'm the battery tray. My duralite a123 9.9volt no longer fits now that I put Velcro on each side of the battery tray.
