C-ARF Ultra Flash build Thread + Video
#6553
I did encounter a really weird trim change with gear down and landing flaps. Basically, I think the nose door is causing the nose to dive. I'm sure I'm not the only one that has encountered this. My question is what are you doing to counter it? I originally set up my flap/elevator trim on the maiden, but with gear up. And I want it trimmed that way in case I want to do low, slow fly bys. And then when I went to land and put gear down it started diving to the ground. I know I can do an ele/ele mix assigned to the gear switch, but then I'd be way out of trim until the gear came down fully.
Ideas?
Ideas?
weather permitting I'll give it another go this week...
#6554
September is 10 years since this thread started...so I thought I should build an Evo. Iconic scheme for an an Iconic aeroplane.
The following 2 users liked this post by Dave Wilshere:
Canadian Man (07-16-2020),
Tom ling (07-16-2020)
#6556
I need some help, I had not so good of a landing on my last flight of the UF, (broke main right retract pin) nose gear needed some adjustments,
now when i retract the nose gear it want to twist about 1/4 of an inch making the nose wheel hit the fuse, I don't have a programmer for my Behotec c-40 retracts.
any ideas? on how to fix this.
#6559
So the steering servo is through the Behotec controller? I don’t see how the heavy landing made the controller change the neutral position between steering on and off to retract. The steering still works with the gear down? Switches off gear up?
Dave
Dave
#6560
yes the steering servo is through the controller , the steering works fine, tomorrow im going to go direct steering and do a mix so its disabled when the gear switch is activated going up
#6562
#6564
bodywerks (07-29-2020)
#6566
#6568
Dave, can you tell me what the max flap setting was that you settled on for your UF?
And are the ELEV and AIL deflections measured on the inboard of each surface...tks
Mi-25 (07-30-2020)
#6574
80N turbines are OK, The JetCat P-80 works fine, but the new small high efflux turbines the stock tail pipe is too big and you will lose lots of static thrust.
P-80 powered Classic Flash I set up and flew Saturday. It was off in 300’ on grass.
