C-ARF Ultra Flash build Thread + Video
#6576
I don’t know KingTech motors, but if that is a small case motor then you wont get the best performance, you would be better off with a Joker
Dave
Dave
#6587
Hi Dave: I have a query concerning the fact that you've mentioned a few times that the UFlash requires Down Elev trim with FULL FLAP. Firstly, did I understand you correctly ? As a long time full size pilot (and also modeller) when the aircraft is slowed to approach speed with full flap extended UP elevator trim is usually needed to balance the nose drop (we need to forget the fact that many model pilots select initial flaps at too high a speed causing a 'balloon' requiring Down Elev).
Secondly I'm curious as to why the UF requires down elevator trim with Full Flap? This must be due to a quirk in it's aerodynamic properties I imagine. Lastly, does this down trim condition change with reducing airspeed?
Sorry for all the questions: I set my full flaps to 105mm as you advised. I'm unsure what the intermediate setting measurement is - so I've eyeballed it.
What I'd like to know is how much down (mm deflection) is required on the Elev Trim?
thanks,
Leon
thanks,
Leon
#6589
Every aircraft is going to be different, as far as aircraft design goes. Some might require up elevator but in my experience the vast majority require down.
I work on bombardier CRJ aircraft and Embraer aircraft for a living. Both automatically change the incidence of the stab with flap input, positive incidence(down trim).
the Ultra Flash has a manual. Whatever it recommends, which is an amount of down elevator, add a millimeter and go from there.
You are right, there is a ballooning effect if you overspeed the flaps, and can make flap/elevator mix quirky. But once you get to short final, it's all personal preference. Some like to fly to the runway, cut throttle, and then flare. Some like to maintain a slightly positive aoa and modulate throttle all the way to ground effects and then cut throttle and land.
Adjust to your landing style.
Mick Hargreaves (08-17-2020)
#6591
Leon
Yes, down is required, at 105mm 4.5-5mm measured at the tip of the elevator. Balance position will change it a tiny bit.
Generally down is needed, Up on BobCat/KingCat. Normally nothing on split flaps or properly designed Hawks nothing is needed. It’s all aerodynamics that dictate this, tail height, incidences, etc
Dave
Dave
#6597
The flap settings for the Ultra Flash are:
The Ultra Flash requires down elevator with flap. Take off 1.5mm and Landing 4.5-5mm measured at the elevator trailing edge tip. Exact figures will be affected by balance position.
Movements ailerons 15mm up and 18mm down-Expo 35-40%. Elevators 15mm up and 16mm down 45-50% expo, Rudder 45mm each way 30-35% expo. Ail/Elev tip joint. Rudder lower TE point.
Yep, what I wrote in the manual 🙂
#6598
Hello Dave,
Maybe it is already asked, I don't know but do you known if the new EVO fuel tank (3,5l) fit the "old Ultraflash". I can image that you have to sacrifice a part of the inlet duct and by-pass.
I am getting tired of the the "2 fuel tank system" and this looks like a great solution.
Do you know if this fuel tank is in stock in Europe.
Brgds Didier
Brgds Didier
#6599
My Feedback: (53)
Hello Dave,
Brgds Didier
Brgds Didier
