C-ARF Ultra Flash build Thread + Video
#1552
NJ
RE: C-ARF Ultra Flash build Thread + Video
ORIGINAL: Ramz
How do you guys transport your Ultra Flashes? (Mainly the fuselage) I am going to build something... Perhaps some sort of cradle that will double as a stand for assembly and disassembly at the field. My UF will be transported in a trailer with lots of room. The major thing I am concerned about is making sure the paint does not wear or scuff when the trailer is rolling down a bumpy road. Pictures would be nice!
Thanks.
Thanks.
#1553
Just need to make sure the aft end of the fuselage is not resting on the elevator control horns. If so, you will probably cause delamination in the horizontal stab.
Regards,
Gus
Regards,
Gus
#1555
I simply use a wooden storage box bolted to the bottom of the trailer. I also made a cradle with white insulating foam (found at building materials stores). The cradle is removable so that I can insert any other shape for different planes. I secure it with a couple of belts. Just check the pictures.
#1558
Hi,
did anybody flown the UF with the saddle tanks?
I am wondering if you have to check the CG with the tanks or if you can easily fuel and fly?
Best regards
Philip
Best regards
Philip
#1559
ORIGINAL: Philip Baum
Hi,
Best regards
Philip
Hi,
Best regards
Philip
Rob.
#1560
Had a great weekend at Wangaratta Jets in OZ over the weekend.
I know there is some debate about speed in prior posts, however my UF can do 400 kmph.
Here is a screen shot of my GPS reading Multiplex set for Spacial 3D max reading and horizontal max GPS speed. You can see they are very close readings so it is ACCURATE.
Note I did not fly to get a max reading, was just having fun!!!!
Mav
Mav
#1561
Great - your UF can do 240 MPH in Australia. But, the fact is, we have an AMA restriction of 200 mph in the US and we need to adhere to that rule for a lot of really good reasons, not the least of which is the FAA's scrutiny of our hobby here. Anyone who ignores the AMA restriction and excedes it is jeopardizing this wonderful hobby for everyone, and that is unacceptable.
Regards,
Gus
Regards,
Gus
#1562
ORIGINAL: mtnflyer14
Regards,
Gus
Regards,
Gus
Not debating your governing body rules AMA, rather confirming the UF can reach 400 kmph plus quite easily!
This should satisfy some of the skeptics out there!
Mav
#1563
What is the correct level of fuel left in the fuz tank to lank with without risking a flameout?
Rob.
Rob.
#1564
ORIGINAL: Mavrik!
Mav
Mav
Rob.
#1565
Regards,
Gus
Regards,
Gus
Rob.
#1566
To be honest, I don't know if the AMA or FAA attend jet fly-ins to monitor the airspeed of the jets. But given the FAA's interest in 'unmanned aerial systems', we don't want to give them any reason to get more involved in our hobby.
Regards,
Gus
Regards,
Gus
#1568
FL
basil i maidened the ultra lightning..wow what a nice plane.. easy to fly and very fast with the 180...so how are you makeing out with the flash...when doyou think you are comming up this way to fly?...pat
#1569
ORIGINAL: Robrow
Rob.
Rob.
I usually run my fuse tank down so that it shows 15-18mm of fuel at the front sitting on the deck, I can run lower with minimal air in the header, but it comes down to the fact I do very few long verticals in the last minute and a half of the flight, loops and 8's are fine as fuel is under G. I have never had more than a tiny bit of air in my header using the kit tank set up
Dave
#1571
ORIGINAL: Dave Wilshere
Rob
Dave
ORIGINAL: Robrow
Rob.
Rob.
Dave
Rob.
#1575
FL
ok looking at my lightning with saddle tanks..you will have two sets of tees.. one will tee off the vent.. one will tee to the uat...looks pretty simple.. i didnt build this but it looks easy...pat
