C-ARF Ultra Flash build Thread + Video
#1801
RE: C-ARF Ultra Flash build Thread + Video
What do you guys think about RX set up? This is what my options seem to be:
I want to run crow so ideally this is what I would want:
Ch 1 - Throttle
2 - L - Elevator (Or combine L/R Elevator on one channel and mix Rudder and NWS)
4 - R - Elevator
5 - L - Aileron
6 - R - Aileron
7 - L - Flap
8 - R - Flap
9 - Rudder / Nosewheel steering
10 - Gear
11 - Brakes
12 - Smoke
In order to do this I would need a 12 CH Rx. Here are the options for that:
1. Powerbox Royal Spektrum 12K DSMX - $850 (STUPIDLY Expensive)
2. AR12200 12 Channel DSMX Cockpit - $639
3. R1222X 12-Channel DSMX Receiver + 2 Sahara Regulators + Switch - $430
Or I can use a 9 Ch RX with a Powerbox
Ch 1 -Thottle
2 - L/R Elevator
3 - L - Aileron
4 - R - Aileron
5 - Rudder / Nosewheel Steering
6 - L/R Flap
7 - Gear
8 - Brakes
9 - Smoke
In order to do this these are my options:
AR9210 9CH DSMX PowerSafe Evolution + Matchbox Twin Pack - $510 ( Minus Matchboxes $400)
R922X 9-Channel DSMX + Powerbox Competition 40/24 = $570 I like this one because it allows servo matching for the Elevators and flaps eliminating Matchboxes.
R922X 9-Channel DSMX + 2 Sahara Regulators + Matchbox Twinpack = $420
I like the AR12200 12 Channel DSMX Cockpit - $639 because of it's simplicity. All in one package and reduction in wires.
What do you guys think?
Ch 1 - Throttle
4 - R - Elevator
5 - L - Aileron
6 - R - Aileron
7 - L - Flap
8 - R - Flap
10 - Gear
11 - Brakes
12 - Smoke
Ch 1 -Thottle
2 - L/R Elevator
3 - L - Aileron
4 - R - Aileron
6 - L/R Flap
7 - Gear
8 - Brakes
9 - Smoke
#1802
OK
Because I use 7955's I just programmed them all and y'd the elevators and flaps. I used the behotc brake/gear valve that came with the gear which works good and keeps things simple. I have my steering on a seperate channel so I can trim the steering independant of the rudder. still stayed under 10 channels.
#1803
That would allow me to use:
R922X 9-Channel DSMX + 2 Sahara Regulators + Switch = $350
Or
AR9210 9CH DSMX PowerSafe Evolution = $400
The 9210 would be the least amount of wiring.
That's pretty reasonable. Any reason to want a 4 x remote antenna setup over the 3? This is my first venture into 2.4 with composite.
Or
#1804
My Feedback: (10)
NV
IFlyEm35,
This is what I would do (and I am doing...)
Using a 1221 RX, SmartFly EQ10, and 2 A123 batteries you can do the following:
Ch 1: Throttle
Ch 2: Right Aileron
Ch 3: Right Elevator
Ch 4: Rudder
Ch 5: Gear
Ch 6 (aux 1): FLaps. R flap on channel A, L Flap on channel B
Ch 7 (aux2): Left Aileron
Ch 8 (aux3): Brakes
Ch 9 (aux4): Nose Wheel Steering
Ch 10 (aux5): Left Elevator
Ch 11 (aux6): Smoke
Ch 12 (aux7): Gyro gain
Using the EQ10 you can do all of this easily and with flaps you can reverse a sub-channel within a channel. You can also set up end points independantly for each servo within a channel. No need for regulators or match boxes. Honestly, if you are not using a EQ10, you are making more work for yourself.
We have well over 1000 flights on the exact set-up and have had ZERO issues.
Ch 1: Throttle
Ch 2: Right Aileron
Ch 4: Rudder
Ch 5: Gear
Ch 8 (aux3): Brakes
Ch 11 (aux6): Smoke
#1809
The PowerBox Sensor switch handles that.
[link=http://powerbox-systems.com/e/powerbox_systeme/powerbox_sensor/start.php]http://powerbox-systems.com/e/powerbox_systeme/powerbox_sensor/start.php[/link]
[link=https://duraliteflightsystems.com/index.php?_route_=powerbox-systems/powerbox-systems-switches&product_id=99]https://duraliteflightsystems.com/index.php?_route_=powerbox-systems/powerbox-systems-switches&product_id=99[/link]
#1811
My Feedback: (10)
NV
ORIGINAL: AFTERBURNER1
Nice n clean but the bee hive is still buried beneath...
ORIGINAL: IFlyEm35
Very nice Selleri!
What type of batteries are you running?
Very nice Selleri!
#1813
ORIGINAL: InboundLZ
Yep! Good luck when you have to service it or trouble shoot....
ORIGINAL: IFlyEm35
Very nice Selleri!
Very nice Selleri!
Actually i did have to do some service work on that model at the weekend, the underside was just as neat and everything was easy to access after the removal of just 6 screws. So i guess Sverrir has the best of both worlds. I can't stand a model that has everything bear on top of the tray as it' always looks a mess, plus any fuel splillage is on top of everything making it difficult to clean properly.
#1814
Wish I could have Duncan full time as my mechanic, makes life so easy, thanks for the help mate!
Pictures of the "rat nest".
#1816
Consoleworld I also used my Gopro with Ultra Flash, but in a different way, I put it in the head I
Video is handsome, but they have to try to mow the grass more or otherwise going to break many landings trains!
https://www.facebook.com/photo.php?v...type=2&theater
Best regards!
Best regards!
#1817
Hi Rayman
me too i have the gopro to my head ,only in the UF video , yes i now for the grass is 6cm height but no big problem with the P120SX .
here is one more video with the gopro , but this time in the bottom of my third jet .
[youtube]http://www.youtube.com/watch?v=fbu4u2Vm5yI[/youtube]
Christian
Christian
#1818
ORIGINAL: IFlyEm35
Is it better to run smoke in the wing thank and fuel in the saddle tanks? Vice versa? Doesn't matter?
Rob.
#1825
My Feedback: (30)
Finally test flew my Ultra Flash 2 weeks ago, very happy with the aircraft and its performace, got total of 4 flights so far . Ultra Flash has Jetcat P80se, JR 8411 all around. The aircraft flies plenty fast with P80se, had no issues pulling out of sight verticals!!!
Landing was very predictable.
Here are some pictures!!
Asif
Asif
