 K 80 programing help >
Old 06-25-2011 | 07:13 PM
Default K 80 programing help
Wanted to find out if anyone is running the new none flight works pumps. I have two and wanted to know what are the start and run perameters?
Todd is healing and wanted to see if I could get some help with someone running them already.
Old 06-26-2011 | 03:32 AM
Modellbau USA's Avatar
Default RE: K 80 programing help
If your motor came with the Hausel pump it should have been calibrated at the factory. If you are converting from Flight works to the Hausel pump parameters should be the same but I will confirm on Monday. Please give me a call on Monday so I can get the parameter from one of our airplanes.
Old 06-26-2011 | 05:57 AM
Henry,
I have one of each in a Twin F18 yellow. Somehow mine came with the wrong ECU so I have one that has never been programmed.
Todd is out with his surgury so I would need to wait till he is back at work. Trying to get it programmed and test run before that if possible.
Have Hausel pumps for both now.
Old 06-26-2011 | 06:53 AM
lov2flyrc's Avatar
My Feedback: (24)
Kevin,
I'll be back in the office Monday, at least for some of the day and will confirm settings for you.
Todd
Old 06-26-2011 | 09:22 AM
Take a look here.
http://www.rcuniverse.com/forum/m_96...12/key_/tm.htm
Old 06-26-2011 | 12:31 PM
I ran down to the Office to deliver and airplane so I got theparameters for you it is for a K80F
<u>START</u>
Pump Start Point- Auto+2
Pump start ramp- 002
Glow Plug Power- 7.0V
Low Batt Volts- 7.0V
Start Power at Ignition- 120
Fuel Pump Power- 140
RPM 100% starter power- 25.000 RPM
RPM off starter- 22,000 RPM
RPM to reconnect starter- 20,000 RPM
RPM Ignition K.- 3,000 RPM
Pump PW ignit K- 025
engine min flow- 50%
EGT end Preheat- 120C
RPM pre heat K- 5,000 RPM
RPM Fuel Ramp K- 10,000 RPM
Pre Heat Fuel- 045
Ignition Time out- 27.5 S
Start Mode- Auto Kero
<u>RUN
</u>
Full Power Speed- 145,000 RPM
Idle Sped- 45,000 RPM
Stop Speed- 30,000 RPM
Start Min/ Temp- 100C
Max Temp- 800C
Accel Delay- 6
Deccel Delay-4
Stability Delay-100
Pemp Limit- 0248
<br type="_moz" />
Old 06-26-2011 | 01:46 PM
Thanks guys. This is a gas start engine not kero. Does that effect the parameters?
Todd, great to here you will be back. I will wait to hear from you.
Old 06-26-2011 | 02:14 PM
Yes it does, but not for the main pump only for the start numbers. The start fuel is substituted for Gas. So the run parameters for the main pump should be the same. I have not run one of these with propane start and hausel pump but im sure either Barry at King Tech can help you or Todd. If there is anything else I can do please feel free to give me a call.
